02 4Runner cold start issue
Old Jul 11, 2022 | 09:16 AM
Yotamur's Avatar
02 4Runner with the 3.4 very long crank to start when it hasn’t ran for awhile. Runs good after it starts. Vehicle has 200k miles and sat for a couple years before I recently purchased it
Old Jul 11, 2022 | 11:56 AM
2ToyGuy's Avatar
That's normal. The fuel pump has an anti-flowback valve that can very easily fail, or leak down faster than when new. The FSM only specifies that the fuel system hold pressure for 5 min after the engine is shut off, anyway. It sounds like yours is acting normally, and bleeding down as expected. Just takes a few extra seconds to pressurize the system properly when you go to first start it after sitting for a while.
If it really bothers you, you can replace the fuel pump, which should solve the problem. Remember to only use OEM parts!
Does that help?
Pat☺
02 polish ss
Mar 20, 2012 05:53 PM
jeetS
Apr 16, 2011 06:03 AM
tb
Oct 10, 2010 10:03 AM
bigt
Nov 28, 2007 05:16 AM
Glina
11
Aug 15, 2005 10:02 PM
