3.0 Hard start when warm
Old Oct 8, 2010 | 10:32 AM
tb's Avatar
tb
Hi there guys and gals,
I've searched and founds threads with people having similar issues but no one who has successfully fixed it.
Background - Truck is an 89 pickup with a 3vz, 300k kilometers starting ok cold (will start right away but sit at about 200rpm for 3-4 seconds and either go right up to 1600rpm or die and start right up when I crank it again) and starts great when hot but takes anywhere from 5-8 seconds of cranking when it's warm (been off for 20mins-2hrs). When running it runs excellent.
I've replaced the temp sensor, cold start time switch and cold start injector. Vacuum lines are hooked up correctly and there aren't any leaks (that i can find).
If anyone has any ideas on what the issue could be it would be greatly appreciated. Thanks
Tyson
Old Oct 10, 2010 | 09:43 AM
tb's Avatar
tb
Bump. I'm still not having any luck diagnosing this, any tech's out there with an idea? Thanks
Old Oct 10, 2010 | 10:03 AM
camo31_10.50's Avatar
so it's just a hard start?
you're griping about having to crank the motor for a few extra secondS?!?!? i'm totally kidding
mines doin the same thing, except mine won't idle either.
Regency
20
Jan 3, 2020 07:43 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jnkml
Jul 6, 2015 01:20 PM
marcusSRG
Jun 27, 2015 07:13 AM
