Drive without front diff?
Old Jun 24, 2021 | 07:20 PM
Highny's Avatar
Hey everyone,
I recently picked up my first 2000 4Runner. It has a pretty bad oil leak from what appear to be oil pan leak. I’m planning on doing the fix soon.
From my search I need to remove the front diff. But I found that the front main seal or oil pump mounted to the block may also cause a leak like my(pretty bad leak). Which is a bit troublesome.
My question is, if I remove the front diff, both cv axles and front driveshaft. Then install old cv axle stubs(broken old cv axles) to hold the wheel bearing. Could I still drive it in 2WD? This way I could still drive the car while ordering parts.
I mainly work on Honda’s so transfer case and 4x4 is still new to me.
Thanks for reading!
Old Jun 28, 2021 | 08:07 PM
aowRS's Avatar
Yes, if you install old stub axles to keep the wheel bearings clamped, you should be fine.
Andreas
ference21
Sep 23, 2014 12:00 PM
scottishb
Mar 19, 2011 09:11 PM
KrashDH
Jul 5, 2009 01:45 PM
4Runner202020
Jan 1, 2008 03:57 PM
Tiger Paw
Sep 8, 2004 09:27 PM
