PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. How many miles on your clutch?
  2. Calling All Caps!
  3. Anyone seen this color before?
  4. theremostat installation problem
  5. Intermittent Chirping from AC compressor?
  6. 3.4 hard to start
  7. Leaking Axle Again
  8. Speed Sensor location, 97 Tacoma
  9. How to dissable power locks
  10. Seat Tacoma Question?
  11. condensation problem
  12. Timing belt
  13. Epic 4Runner Saga: Repair job gone wrong?
  14. what size diff gear to put in?
  15. Cylinder misfire only when idling???
  16. 2000 4Runner CA catalytic converter mystery explained | Catco vs. Miller??
  17. automation transmission problem...need help!
  18. 2 sets or 1 set of tire chains on 4x4
  19. Toyota Aftermarket Switch??
  20. Help diagnosing problem w/ our "new" 4Runner
  21. installing bull bar and tow hook bolts
  22. U-Joints...proof the devil exists
  23. HELP!! need to find a support bracket for exhaust
  24. 3.4 - Non Interference confirmed
  25. steering rack??????
  26. Questions about valve and intake gasket replacement on '98 4Runner
  27. tryna identify springs on a 96
  28. SCUBA's New TACO !!
  29. Front suspension questions: Wandering
  30. popping sound from front wheel
  31. Gear ??'s and BudBuilt skids ??'s
  32. Anyone running Hankook MT 295/75/16's on stock wheels?
  33. '96 4Runner Rear Axle Issues
  34. Good 12 Compressor?
  35. 99 Tacoma 4x4 - NEW TO ME
  36. Light Questions?
  37. 4 New Hella 500's
  38. how to disable the steering lock?????
  39. O2 Sensor
  40. Window Switches
  41. Toggle for ADD??
  42. *** OOoOooOo! Another Safari Rack in the works! SICK BUILD PHOTOS! ***
  43. Oil Analysis for 3.4L... coolant in oil
  44. 97 4runner passenger rear window rolls down on its own?
  45. Rear Shock install Question
  46. 2003 prerunner 0-60 video
  47. Who's in NC? Looking to wheel!
  48. g.p.s./ laptop??
  49. How do spring spacers add preload?
  50. Crap...more trans issues. 4WL isn't engaging??
  51. solid axle swap
  52. hatch lift support
  53. 4gen spoiler on a 3gen 4runner?
  54. My .02 cents on rear spring sag...
  55. 1997 5 speed rack, key issues.
  56. 3rd to O/D up-shift comes and goes
  57. rough idle.. coil packs?
  58. Exhaust Manifold Trouble On A 3.4 V6
  59. 4.7 gears for a 97 tacoma?
  60. will this straight axle work on my 98?
  61. Loose steering on highway speeds.
  62. Oil Sludge Monster Attacks!!
  63. scratch Repair / Matching Paint / Clear Coat
  64. Switch from 16" to 15" on 3rd gen 4runner
  65. Headers, Sorry!
  66. Problems with multi-mode 4wd 99 4runner ltd
  67. Tokico strut bolt sheered off !
  68. Strange noise
  69. Roaring noise when driving over 2.5krpm
  70. Do I have a 1999 California emissions 4runner?
  71. New OME suspension and bushings
  72. CLUNKING!!! Tacoma?
  73. Doesn't anyone have "ventshade" in channel rain guards on their 96-02?
  74. Extremly simple eletrical question.
  75. Where to buy...?
  76. 1998 yota lift help?
  77. Got my ARB Bull Bar installed finally (Pix)
  78. Group for Philips HIDs
  79. Canadian tacoma 01-04 owner read this
  80. Remove wind deflector bumpers
  81. 4runner brake upgrade
  82. Bilstein 5100 and 882 lift
  83. EGR Valve
  84. 285/75/16 KM2s
  85. What are my locker options for my 1997 tacoma v6?
  86. WTB/ Bumper questions/ I got rear ended... again.
  87. Is there a easy way to change brake fluid?
  88. quick brake question
  89. Brembo rotors
  90. Door Speaker Sizes?
  91. Buyback info you didn't know
  92. Alarm trouble. Help!!!
  93. 95 2.7 taco cracked manifold (same old story)
  94. Grinding the caliper to fit factory 15's?
  95. will stock shocks work with lift?
  96. JAOs Rally Style Mud Flaps....
  97. 99 4 runner with issues
  98. Stuck Brake Line
  99. Excel vs K&N
  100. Complete 3rd Gen 4Runner Suspension thread? Need affordable 1-2"
  101. Do 86-95 PU leaf springs fit on a 96 PU?
  102. price check
  103. Search engine of all search engines!
  104. Rear Axle Advice
  105. Wheel fitment: FJ to 4Runner?
  106. Rear Axle Seal Advice
  107. 33"s w/ PP Coils?
  108. tune up 96 4runner
  109. Towing w/ 3rd Gen --- How much is OK?
  110. New plug wires,how necessary?
  111. Ticking Only when in drive or reverse
  112. How to test Igniter module?
  113. egr delete issue
  114. Oil Filter AHHHHHHHHHHHHHHHH!
  115. s c sale
  116. Bulb replacement for headunit?
  117. Valve cover stuck?
  118. Panhard Bar Measurements
  119. Installed KENWOOD eXcelon KDC-X492/Audiocontrol Epic 150
  120. 8+ foot bed conversion
  121. Hid's 95-97 Tacoma/rocksliders
  122. Tacoma clutches
  123. Hi, new to the 2.7L. Need advice
  124. 5 lug 2wd tacoma lifts
  125. Selecting oil type for 3.4 with unknown history
  126. 99 "Tallest" Spring Part Number
  127. hissing/whining
  128. Gas guage problems with 2003 taco?
  129. (homework) Looking to replace ailing 3.0 4runner with a 3.4 runner...
  130. Replacing a rusty 3rd gen rear bumper & hitch ?
  131. May buy a 04 DC Taco TRD today...couple ??
  132. Just lifted my 02 4runner, now I have warning lights on...anyone have this happen?
  133. 98 4runner yakima rack
  134. Rear Shock Removal
  135. 2000 4runner hi/lo hid drl disconnect
  136. Anyone tried this style of HID conversion before?
  137. OME 882 with Toytec top plate spacer what shocks work ??
  138. viberation when stopped at red light with car in gear
  139. Axle Issues
  140. Sagging Springs
  141. Who's 3rd gen?
  142. has anyone ever heard of CEL turning off
  143. Ghost Lights
  144. Holes in muffler causing vibration?
  145. Larger Gas Tank
  146. Seat belt retracters...
  147. Need a new muffler
  148. 00/02 4runner Grilles interchangeable???
  149. Rattle
  150. *** Best Shock Absorber 3G 4R? ***
  151. Radio replacement
  152. 2002 Tacoma 5 speed, how much fluid and MTL or MT-90
  153. 3rd Gen. Fan write up
  154. Rear window down with aftermarket keyless entry system!
  155. Bump feeling/pop sound when decelerating and coming to a stop!
  156. Wanted: '97 4runner skid plate
  157. swapping 3rd gen 4 runner body on to 2nd gen frame?
  158. TRD Throttle Body "O" Gasket
  159. Factory Tag.....worthless
  160. 2wd to 4wd
  161. anyone have sound system in the 4runner?
  162. dash light upgrade pros and cons
  163. Wife knocked off my rear wing with garage door!
  164. E-locker light is blinking and won't engage. This ever happen to anyone?
  165. Need help on a 02 Lift
  166. Steering Column Re-built anyone?
  167. stupid E brake light
  168. Where to mount ScanGuage 2 in 4Runner?
  169. Camping Sleep Deck 3gen
  170. Packing front wheel bearings?
  171. Does a 2001 Tacoma prerunner have timing belt?
  172. Need lift help fast.
  173. Am I getting a bad deal on this tacoma???
  174. Factory stereo died. Is it stereo or electronic failure?
  175. Anybody have any fab ideas??
  176. Need help finding roof rack parts for 3rd gen
  177. Has anyone ever done this?
  178. 1" spacer for rear
  179. Decrease in mpg
  180. tacoma storage solutions?
  181. My 4Runner mods......with pics
  182. How To Drop Transmission Pan And Flush ATF - New Write-Up For Review
  183. Need a quick answer on manual transmision
  184. Dealer says I need both cats and a TPS.
  185. Running boards 98 4runner
  186. '01-'02 4Runner Sport options
  187. question on part swapping (96 from a 99)
  188. Grind going into 4L and back into 4H w/selector lever
  189. NTK/NGK oxygen sensor fitment
  190. Urget help needed!!!
  191. OEM Tire Size on '98 Tacoma?
  192. changing plugs and wires, need help!
  193. header to stock system on a 22re
  194. What is the difference between the 96-98 and 99-02 Radio bezel, any other upgrades?
  195. Rough Idle in drive
  196. I broke my speedo
  197. 2001 Toyota Tacoma Double cab
  198. My last straw with VSC!!
  199. help with an keyless entry, remote start, alarm
  200. Shock question?
  201. FS: PP 1" Lift Kit
  202. 2.7 intermittent misfire
  203. i need some help on what to do with my 96 'runner
  204. V8 swap... whats it take
  205. Ressonating drone in the truck cabin?
  206. Transmission delay 2-3..need another opinion
  207. Good Deal? Or Too Good
  208. New Yota, few questions
  209. 2001 4runner clicking
  210. 4wd vsv location
  211. 96 4runner hot start problems
  212. 3rd Gen gets updated dual battery tray and National Luna Solenoid
  213. Holy Crap - Transmission Fluid Looks Like Used Motor Oil (Pics)
  214. New Springs 101
  215. KZN185 rear door latch not working
  216. Photoshopped Runner
  217. Lockers For An 01 4runner
  218. Info needed from those running 35" tires
  219. Confirm Bodyshop Diagnosis?
  220. Difference between Toytec and Revtek top plate spacers?
  221. Please help with unusual key situation!
  222. Fluid Change Help
  223. 99 limited dash lights for climatecontrol
  224. Bumpers (or lack thereof)
  225. 99 tacoma engine / fuel problem
  226. Need Help! Alignment Just Done But Not Right
  227. snow plow on 974runner
  228. My new yota's
  229. Opinion of 97 Runner I might buy - Help
  230. Deer + 4runner = new bumper
  231. Need help with transmission issue!!
  232. 2000 4Runner Keyless Entry Issues
  233. How to fix high idle?
  234. Shaky at high speed
  235. 96 4rnr for sale, not sure where to put this...
  236. Old Member, New Rig
  237. Catalytic Converter
  238. My ABS does not work. Anti lock brakes
  239. my engine stalls/dies when i initially start it. ideas?
  240. Need new/used ECM
  241. TPS removal tips?
  242. 99Limited 2Hi&4Hi but no 4HL or 4LL HELP
  243. New Guy
  244. 99-02 4Runner LTD Bumper
  245. rust spots on truck?
  246. 3rd gen.....can anyone set this gass issue straight?
  247. Wheeling trips in idaho???
  248. New truck, new ideas
  249. where did my shifter GO!!??
  250. 2002 4Runner - sounds like an airplane under hood
