Towing w/ 3rd Gen --- How much is OK?
Old 02-16-2009, 05:24 PM
BushPig's Avatar
Question Towing w/ 3rd Gen --- How much is OK?
I have a 3rd Gen w/ 3.4L V6, 5-speed manual, and factory tow package.
I want to go pick up a car this weekend and tow it home w/ my 4Runner. The car weighs approx 2600lbs, and I can borrow a friend's dual-axle steel trailer.
I'll tow the empty trailer to pick up the car, about 110 miles one-way. Then tow the car + trailer the 110 miles home.
Will this be too much for the 4Runner to tow?
What do you guys think?
Thanks!!
Old 02-16-2009, 06:17 PM
SoCalPaul's Avatar
Depends on the weight of the trailer. I believe the tow rating is 5000 lbs. Just remember to have some good tie down straps & set the car to have about 200-250 pounds on the tongue. Stop once or twice & double check your straps. Also make sure the trailer has a Flat 4 connector or get an adapter.
Good Luck,
Paul
P.S. What kind of car is it?
Old 02-16-2009, 08:26 PM
crolison's Avatar
you should be fine. tow rating is around 5k
Old 02-16-2009, 08:52 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
well thats good to know.
to the OP, man, that must be a rare machine, the 5 speed and the Highlander Edition and the locker... nice!
Old 02-16-2009, 10:45 PM
98runner210's Avatar
keep in mind the biggest and most apparent weak spot is going to be the brakes. For 100 miles I might invest in a brake controller. Whole lot safer and easier going. Never know...
Old 02-16-2009, 11:21 PM
scuba's Avatar
Towed this 1500 miles with my dads 2.7 5 speed. prolly 4 k total. not to mention the 10+ guitars and a few amps in the back of the runner. it wasnt fun, but doable.
Old 02-17-2009, 01:42 AM
pkt1213's Avatar
I towed my parts car a few hundred miles with my 98. It's a V-6 5-speed too. It probably close to 5000 cause the dual axel trailer I used probably weighed between 2-3000 lbs. It was up and down hills on the highway and interstate. Just take it easy and you'll be ok. I've also towed 5-6000 lbs a few times just a couple of miles.
mojo4x420
09-16-2015 08:07 AM
izzmee
08-17-2015 10:20 AM
vanion2
07-29-2015 06:17 PM
Stealth TDI
10-28-2003 02:42 PM
Quick Reply: Towing w/ 3rd Gen --- How much is OK?
