Need help on a 02 Lift
Old Feb 11, 2009 | 07:00 AM
Atwater27's Avatar
I have a stock 02 and just put on 265 75 r16's Revos on and want to add a slight lift. I dont have alot of money to spend. I have done alot of reading on this and have come up with 881's in font and 906's in rear. I am looking at $340 for that. What else will I need? Do I have to change the shocks? I am sure I can do the work on the back myself but I might have to bring it some place to do the front. Thanks for any help.
Old Feb 11, 2009 | 07:08 AM
gilby4runner's Avatar
You will want to go ahead and by the new shocks for the combo. I am very pleased with mine. You will be very happy with the OME!
Old Feb 11, 2009 | 07:14 AM
Gerdo's Avatar
With that little of a lift you really don't need anything else. I'm running TRDs and 891s with the stock length shocks and they are fine. Sure, I could get more rear droop if I went to a longer shock but the rear droops alot as it is.
If your shocks are old you may want to consider replacing them at the same time. especialy the fronts since the labor will be the same. The rears you could do later.
I also did...
*- a front diff drop, not needed for a small lift.
*- rear panhard bar drop, not needed for a small lift.
*- e-brake cable relocation bracket, not needed but if you wheel you may want to make one. It'll let the axle droop whith straining the cable.
Old Feb 11, 2009 | 07:15 AM
Motayota's Avatar
From your handle name, are you an Atwater fan?...if you live in Denver I can help you out with the front. Did mine, by myself, also just added a top-out spacer last week.
Old Feb 11, 2009 | 07:57 AM
Atwater27's Avatar
Thanks for the reply's. No I dont live in Denver. I am in Minneapolis. I am a big Broncos fan and Atwater was one of my favorite bronco. I wish I lived there the help would be great. Will I need the spacers in front? I think I will do the shocks in front the same time. Any suggestions on lower priced shocks?
Old Feb 11, 2009 | 08:20 AM
if you go with the OME struts and coils i would go with the OME comfort shocks. Do not skimp on the shocks.
Old Feb 11, 2009 | 08:43 AM
Gerdo's Avatar
I'm very happy with my Bilsteins.
DO NOT GET MONROES!
Old Feb 11, 2009 | 09:25 AM
Amnesiac's Avatar
I recommend replacing the shocks as well. I replaced my old stuff with all new OME and it made a huge difference.
Old Feb 11, 2009 | 12:03 PM
emptypockets's Avatar
As everyone else has said, replacing the shocks at the same time as you do the lift is a great idea. OME makes good stuff and you'll be happy with their coils and shocks. I did the 882's up front with the N91SC comfort valved shocks and have been very pleased with their performance.
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
