Need a quick answer on manual transmision
Old Feb 9, 2009 | 02:57 PM
pkt1213's Avatar
I've got a 98 4runner SR5. I'm changing all the fluids in the driveline and I need help on the manual trans. Is the drain plug the 24mm on the passengers side and the fill about half way up on the drivers? It makes sense up the pic if my repair manual doesn't look quite right.
Old Feb 9, 2009 | 03:28 PM
97ltd4x4's Avatar
I believe that is correct 24mm plug ,halfway up the case.
Old Feb 9, 2009 | 05:31 PM
pkt1213's Avatar
Sweet. The ones on the front diff aren't 24mm bolts are they? It looks like they have a have an insert for a hex key.
Also, what do I need besides a standard socket set and a swivel to do the spark plugs?
Old Feb 9, 2009 | 10:11 PM
JBSTRD's Avatar
The ones on the front diff are either 10mm or 12 mm hex keys. I got the one that is like a socket that goes on your ratchet wrench.
As far as the spark plugs, you will probably want to take the intake tube off so you can get to the passenger side plugs easier. That only requires a screwdriver though. Then, it is handy to have a torque wrench so you don't overtighten the plugs. Make sure not to cross thread them either.
Old Feb 10, 2009 | 04:03 AM
pkt1213's Avatar
I figured I'd have to take that tube off. Just looked a little tight over on the intake manifold side but I hadn't started yet.
I think I have a hex key socket set somewhere.
Old Feb 10, 2009 | 06:30 AM
JBSTRD's Avatar
It is also a good idea to remove the fill plug before the drain plug on all the drivetrain components. It allows the fluid to drain easier and if for some reason you were not able to get the fill plug off after draining it, you would be screwed.
jasonty
41
Dec 23, 2018 01:00 PM
delmert
Sep 30, 2015 04:34 PM
jbandt
Aug 3, 2015 03:23 PM
PlayAwhile
Jul 20, 2015 11:36 AM
colinmil
Jul 6, 2015 04:03 PM
