popping sound from front wheel
Old 02-24-2009, 07:22 PM
spaugh's Avatar
I have a popping sound coming from the driver side wheel when I turn left. I assume its a bushing or somthing in the steering rack or a arms. It doesn't seem to be a problem, but I'd like to replace whatever parts are worn. Any ideas what the sound is? Its probably a common thing for high milage trucks.
Old 02-24-2009, 07:36 PM
gary96360's Avatar
does it make the sound when your turning sharp like in a parking lot. if it is, it could be the cv joint.
Old 02-24-2009, 08:13 PM
okie81's Avatar
sway bar bushing.
Old 02-25-2009, 02:58 AM
terminator's Avatar
I second the swaybar b/c I had an endlink break and it would hit the LCA on bumps and pop.
Old 02-25-2009, 04:57 AM
Fink's Avatar
Steering stops.
They're notorious on the 2nd gens and IIRC I had the same problem on my '99.
Glob on some grease or try and order some of the stupid little plastic covers that are supposed to stay on but never do.
Do a search for "turning popping steering" and see what you come up with.
Fink
Old 02-26-2009, 02:02 PM
spaugh's Avatar
Ill look at the sway bar. But it makes the sound when I barely start to turn. Not into the turn yet at all. I doubt its my CVs. They are obvious when they go bad.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
horunner1x
07-10-2015 06:33 AM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: popping sound from front wheel
