I broke my speedo
Old Feb 8, 2009 | 08:02 AM
wolfpack10's Avatar
Question I broke my speedo
So I was puttin LED's in my dash and I accidentally twisted my spedometer needle. I got everything back in (the LED's look nice) and my speedo stays stuck on 0. What do yall think I need to do? It's a 2001 SR5 if it helps.
Old Feb 8, 2009 | 12:32 PM
wolfpack11's Avatar
2. Flaming And Bashing
Our policy is no flaming or bashing - either publicly or by private messaging.
This includes members and staff.
Also, posting to "egg" members on or to entice bashing will not be tolerated.
If you have a beef with a member, take it outside of YotaTech.
The same goes for bashing other message boards or mocking their content.
Last edited by DeathCougar; Feb 8, 2009 at 11:02 PM. Reason: Please re-read the rules
Old Feb 8, 2009 | 01:46 PM
02_Limited's Avatar
Originally Posted by wolfpack11
Edited by DeathCougar
Lol?
I would say that you are just gonna need a new gauge cluster
Old Feb 8, 2009 | 01:51 PM
wolfpack10's Avatar
Old Feb 8, 2009 | 01:55 PM
wolfpack10's Avatar
Originally Posted by 02_Limited
Lol?
Yeah I think I'm going to end up at a junk yard. For now I have the GPS to keep me from speeding.
Old Feb 8, 2009 | 06:35 PM
02_Limited's Avatar
Another way to check speed is RPM's. On 265/70's I'm doing about 63 MPH at 2,000 RPM. I figure it would be about the same for you on 255's?
Old Feb 8, 2009 | 06:49 PM
texcat101's Avatar
No one should wear a speedo... it's a good thing it broke!
Old Feb 8, 2009 | 11:03 PM
DeathCougar's Avatar
Alright guys, posts edited. Lets keep this thread clean and on topic.
Old Feb 8, 2009 | 11:44 PM
98runner210's Avatar
how do u think u broke it?
what exactly did u do to the needle?
make sure the needle isn't pressed to far down and is agaisnt the face. this might keep it from moving ( happened on a camaro)
Old Feb 9, 2009 | 12:27 PM
wolfpack10's Avatar
ok so I opened her back up yesterday to see if there was anything I could do to it. I tried cleaning the leads with isopropyl, making sure it wasn't rubbing on something, staring at it for half an hour, etc. Not only does it still not work, but the odometer has now quit working.
I don't know if it is related, but about the same time the speedometer quit working, the VSC OFF and VSC TRAC lights came on. This may be unrelated though as I've had trouble with them before (got an oil change and a Jiffy Lube employee ripped all the wiring out of my wheel well to get to the filter, needs a routine dose of electrical tape).
Any new ideas?
Thanks for the help so far.
Old Feb 9, 2009 | 01:15 PM
02_Limited's Avatar
Any new ideas?
If all that electrical wiring was messed with and you then noticed multiple lights coming on the dash, this may be a bigger problem. The failure of the odometer got me thinking too: the speedometer and odometer are linked to the ABS sensors, I believe, to keep track of mileage and MPH. Maybe one of those wires that was ripped out at JL is one of the wires causing your problem
Old Feb 9, 2009 | 01:24 PM
wolfpack10's Avatar
No, the Jiffy Lube incident happened a while ago. I was just saying that VSC may or may not be related. It could be coincidencidental that the VSC cables have come loose again.
But that does make sense, because I think when both VSC lights come on it means ABS system may be off too. Does the speedometer and odometer connect to the ABS system in the dash? It could have been me that messed up a connector.
Old Feb 9, 2009 | 01:27 PM
wolfpack10's Avatar
I figured I'd get a wisecrack out of the title.
Old Feb 9, 2009 | 03:47 PM
Speedo? Crack?
This thread is for the dogs!
Old Feb 9, 2009 | 07:04 PM
02_Limited's Avatar
Originally Posted by DeathCougar
Speedo? Crack?
Damn, this thread is getting
Obmi
Oct 4, 2015 11:30 AM
puddlepirate
Sep 29, 2015 08:02 PM
charlie_fong
Sep 27, 2015 10:06 PM
mtrdrms
Sep 26, 2015 07:12 AM
yoterr
Sep 15, 2015 03:47 PM
