Oil Filter AHHHHHHHHHHHHHHHH!
Old Feb 16, 2009 | 04:09 AM
kawicowboy's Avatar
I picked up a 96 Taco with a 3.4 in it and decided to do quick oil change on it, Oil came out fine but the filter wont budge, I managed to get some channel locks up there but only managed to crush the filter, punched a hole through it and broke my screw driver. I was soooo mad I had to get up and walk away this thing is Welded On!. The filter is pinched and has holes in it so what are my options now, anyone know any tricks.
Last edited by DeathCougar; Feb 16, 2009 at 08:06 AM. Reason: lets keep the F bomb out of it
Old Feb 16, 2009 | 05:26 AM
GSGALLANT's Avatar
What did you try before the channel locks and the screwdriver. Did you try an actual oil filter wrench? I have yet to find a filter that I couldn't remove with my filter wrench... and there have been some tight ones.
At this point, I would try a bigger screwdriver in the hole you made through the filter.
and quick reminder... lefty loosey, right?
Old Feb 16, 2009 | 06:09 AM
kawicowboy's Avatar
Well Ive never had to use a filter wrench, allthough I have tried befor. Which one would you suggest, one that is like a big sockett, the strap one or one of those swivel ones.
Old Feb 16, 2009 | 06:44 AM
wizzells's Avatar
Strap Wrench. I've never had one that I couldnt get off with one, there have been some seriously tight ones!
Old Feb 16, 2009 | 07:37 AM
y2kltdsport's Avatar
I'd suggest the strap type w/ swivel good luck
Old Feb 16, 2009 | 07:52 AM
atistang's Avatar
http://www.sears.com/shc/s/p_10153_1...pecialty+Tools
normally these work great
if it comes down to it and all you have is the part of the filter that meets the block left, then you can use a hammer and chisel to turn the filter out, just be careful you don't go through the filter and hit the mating surface
Old Feb 16, 2009 | 08:37 AM
kawicowboy's Avatar
I like that chisle idea, and atistang those look good, I like the fact that it fits different sizes but im leaning towards the strap type, I think it may be more versatile.
Thanks guys Im going to give the chisel a try and hopefully not damage anything.
Old Feb 16, 2009 | 10:40 AM
skjos's Avatar
I had a similar experience the first time I changed my filter. My buddy brought over a universal oil filter wrench that looked like this:
http://www.tooltopia.com/index.asp?P...OD&ProdID=5622
After a couple tries the filter came out. Mine was semi-mangled, but it still came out with this wrench.
Old Feb 16, 2009 | 05:48 PM
DailyDrive's Avatar
Best filter wrench is the socket type, that has a 3/8" or larger drive and is made of metal. They usually fit loosely, as filters of the same size still vary a little bit.
Next step is to get masking tape, and start putting layers of it on the inside of the socket. When it gets close to being slightly smaller than the filter, take a hammer, and hammer the socket onto the filter. Then use anything you have to drive the socket.
Old Feb 16, 2009 | 06:33 PM
BigBallsMcFalls's Avatar
busted a screwdriver ?
now, usually the screwdriver trick is the end-all final answer. that filter
is coming off. (though messy)
stop buying your screwdrivers at the dollar store
Old Feb 16, 2009 | 07:01 PM
RunnerUp's Avatar
yeah... i actually had to use a screw driver to get the filter of the 07... guess i put it on a lil tight last time, my filter wrench just wasnt cutting it, my hands werent doing it, so i stabbed through it with a philips head and that broke it loose
Old Feb 17, 2009 | 03:11 AM
kawicowboy's Avatar
Well I used the chisel and it worked like a charm, Thanks for that idea, I dont think I ever would of come up with that.
It was a cheapo screwdriver.There really isnt much room to manuver up there, more than most but still was limited.
Old Feb 17, 2009 | 09:26 AM
97ltd4x4's Avatar
I use this type,I don't think its ever failed to take a filter off,Used in conjunction with a flex-head 3/8 drive long handle ratchet.
http://www.amazon.com/Lisle-63600-Ca...4894999&sr=8-2
Old Feb 17, 2009 | 09:42 AM
Motayota's Avatar
Hopefully you don't tighten this thing up with an socket attachment, wrench or strap, I hand tighten mine, as long as you pre-oil the seal you should have no leaks with hand tightening it. Makes it easier to change out.
Old Feb 17, 2009 | 10:02 AM
rdlsz24's Avatar
Glad to hear you got it. On my wife's Jeep Compass the oil filter was crazy tight from the factory. I would have never got it without my Pennzoil strap wrench from AutoZone. I use that tool all the time. Heck I used it last night to hold the flywheel from turning while taking apart an atv engine and a couple weeks ago I used it to open a screw-on paint can lid that got stuck on when the paint dried lol.
Rob
Old Feb 17, 2009 | 10:33 AM
jct61765's Avatar
The 3.4's have the worst location for their oil filters that I have ever seen. Maybe think about an oil filter relocator if you are going to keep it for a long time.
Old Feb 19, 2009 | 08:36 PM
skjos's Avatar
I see you were able to get the filter off, anyhow I thought I would contribute another filter removal tool to this thread: http://www.wattora.com/index.php?page_id=15
Old Feb 20, 2009 | 04:56 AM
kawicowboy's Avatar
Yeah that looks interesting, I wonder where I could find one around here in Toronto area. As far as the filter, I only use toyota filters and only snug it up hand tight, I like the fact that they come pre greased on the seal.
Old Feb 20, 2009 | 05:00 AM
bigt's Avatar
my diesel filter is 30 bucks so i change it every 2 oil changes...
how much is the 3.4 one...
mine is for a forklift
Old Feb 20, 2009 | 07:19 AM
kawicowboy's Avatar
Its 8 bucks here and comes with a new washer for the oil pan plug.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
