- mirror needed
- Which 3rd Gen is best?
- New to YotaTech but not to Toyotas. Pictures of my rigs and some Questions!!!
- 1st gen rear window
- buying an 85 runner
- info
- Can a vacuum leak cause a high idle?
- Call Toyota & demand a Diesel!
- 0 for 2 today- leaking seal and brake cylinder...
- Questions about using rust converter...
- Marlin Crawler shipping charges
- Speedo and tach after regear
- Gauge clusters?
- 15x10 rims on 10.50 tires
- 97 taco airl/fuel gauge install (sensor wire?)
- Fender Flare options
- Lets see your 4runner front ends...
- Friends 4Runner HOW WOULD IT LOOK?
- Check Engine Light.......
- 22re idle problem found
- The Grill is done! (Pics inside)
- 89 4Runner Fiberglass cap for sale?
- installing third member - question
- I've installed the SS FTC, need the stock ECU map
- help - installing running boards?
- What tranny fluid for my 84 pu 4speed 22r
- Anyone looking for Piaa lamps needs to check this out....
- Engine (22R) damage, could use advise on
- 87 4Runner front end lift via torsion bars????
- front bumper for '80?
- How much does 1st gen truck bed weigh?
- torsion
- Who wants to see my huge dirty hole?? And other pics.....
- steering extension - body lift - help!
- Brake swap
- Could they fit?
- trouble shifting in 4wd
- 2005 Tacoma security system
- 2005 Tacoma wiring question?
- Fast, light, intermittent clicking noise under dash
- 88' engine swap probs??
- "CHIRPING" sound under my truck
- Replacing Front axle Boots
- Help!! Hunting For Idle 1997 4 Runner 3.4 Liter
- To Paint, or not to paint
- 1st gen bumpers on 2nd gen runner?
- Pics from this moring
- clutch forcibly slips out of 1st sometimes
- Junk Yard Score of the Day...
- Sqeaky brakes, why?
- TRD headers (installed)
- Should I pull my injectors?
- Dual Gauge Pod
- 33's tire options
- installing a stock swing away tire carrier on a 2nd gen that didnt come with one
- 4 Corner Wheelers?
- 33x10.50's ???
- !Help! return ye tranny...
- Haul'n Gass in Mexico
- FSM Pic or instructions
- Truck Box Opinion POLL
- ¿Homemade mesh grille?
- 2005 Tacoma - No more xtra-cab?
- Crazy fuel gauge
- Putting a diesel in my 82 from 81 diesel.
- Before and after....sort of
- Pitman arm issues
- Hi-lift mounting question
- Piaa 540 Lamps...Need Feedback
- ?? Aftermarket door panels and elbow removal
- going topless.
- 17 inch rims on a 3rd gen???
- Regearing time?
- Weird Sounds maybe steering?
- Throttle Position Sensor Broken??
- Coolant Temp Sensor locations on 22RE
- Towing (2) Atv's, OD on or off????
- Spedometer Change elec and cable
- Starter Woes...Help!
- 86 Truck??
- Important Question!
- 3vz valve shimming pt II
- How to tell between Type II, III or IV hitch?
- tACOMA 2005 FOG LIGHT SIZE
- Clogged cat-damage?
- selling a non running vehicle
- Reminder: It's time to lube your spare tire lowering mechanism
- 1990 Cherokee 2-DOOR Vs 1990 Toyota 22 R super-charged
- You guys think my frame is bent?
- Downey HD Coil Misalignment
- One more OME lifted 3rd gen w/pics
- 1981 Diesel won't start.And 1998
- CF kit is finally here
- Full Downey Catalog
- Toyota 4X4 Truck Photo request
- Good deal?
- Warn® Rock Crawler Front Bumper
- 81 yota wiring
- Swapping gauges clusters (1st Gen)
- In Need of Fuel Sending Unit!!!!!!!
- Help!!! Alternator harness is gone!
- Flex-a-lite 210 Wiring
- Okay, let's say my 3.slow is fuxored
- wheel spacers
- oil filter relocation kit
- OEM and OME
- Silver first gen in Grapevine TX today? with can-back?
- Using injector cleaners...
- 2000 4Runner and 265/65/17s?
- Extending brake lines (flex hose)
- Air filter box what years?
- 'Engine Restorer & Lubricant', does it actually work?
- Is my starter on its way out??
- Unidentified Hole in my bumper
- New Gauges
- Edlebrock Shocks
- Found out the hard way
- update to problems.
- Offroading with a toddler?
- Group Buy for IPT Valve Body???? I'm still interested!
- Pull both heads at same time.
- Settling on the OMEss
- Winch solenoid install in Tacoma engine bay
- Hella 500 wiring diagram (color) for installation
- 97 2WD SR5 Needs Tips
- coil over on pre 85
- Belts squeeling
- Cheap Tachometer for the 82
- Was going to buy 95 runner, but took it back...
- Want to rattle can my undercarriage
- OME lift quick ?
- high revving idle... help!
- 99 4runner-extended cranking time to start?
- Which rack for a camper shell?
- holy crap mpg suckage!!!
- Strange thing !
- O/D light and speedo squeal like a piggy
- Bushing-27mm Sway bar
- Rear drum removal
- 91 3.0 auto t-case?
- repair leather seats
- Stuck PCV Valve
- 3.4L swap wont stay running need HELP!!
- A/C Troubleshooting
- Please make your thread topics easy to read and understand
- OBX Pedals
- 04 4-runner Transmisssion VSC Trac VSC off lights
- Quick question...
- Newbie questions for 4runner 3rd Generation
- 22r Alternator Upgrade
- Replcmnt springs for '93 2.4l 4x4 5 spd p/up
- 3rd Gen aftermarket Exhaust
- Rough idle/Idler screw?
- e-locker
- 22re stroked to 2.7?
- Igniter
- Here's what the new FJ will "really" look like
- Looking at a 95 4runner, what to look out for?
- Landcruiser Prado Turbo Diesel, Costa Rica...
- does anyone still make...
- purchased remote start, need help installing/wires
- I want a Optima but ...
- question about buying a 85 4x4
- toyota salvage in DFW area?
- ATE Super Blue Brake Fluid
- loud exhaust & horrible idle
- Anyone with 1986-1988 Toyota pick-up brochure? That i could get off you?
- Soft valved struts for 4Runner (alternative to OME)
- 3.0 to 3.0? engine swap
- 2JZ into a 3rd gen?
- master cylinder swap
- Key stuck in ignition 98 4runner
- Broken Fender Screws
- Funky electrical problems
- Back door shell`
- Anyone have this tranny issue too?
- Tundra/Sequoia 17" wheels on 2G Runner/3G Truck
- Daytime running lights needed!
- Noob here
- 15x8 or 16x8
- Squeaky Control Arm Bushings
- Plastic trim restorer results
- MPG woes seem to be fixed
- Odd electrical problem
- Signal Light Problems
- 4runner v6 Question
- ok who is this?
- Runner Bumper
- Free HP/MPG!!!
- slow to idle down when cold
- new spring question
- Moon/Sunroof Rattle
- Door weatherstripping
- Prices
- Saudering the radiator?
- ARB and Kaymar Rear Bars
- Diesel for sale in alberta
- Installing new fule filter
- Ticking noise from dash
- header gasket?
- mirror compass
- Replacement DE Fogs for 98-02 runners
- Gas tank size?
- 1986 TURBO diesel 4x4 Vs 1990 22-RE 4x4
- Finally Free from my 4, 5, 6 Runner
- Is it Possible that....
- 4Runner 4WD visuals...
- Flat spot?
- Is she Dead - HELP PLEASE
- 3rd Gen Cruise Control Wont Engage
- 89 Pickup - Really Annoying Rattle - Help!
- new member,tech question.
- Strong smell after injector clean
- Uneven brake pad wear
- crank case vent hose
- Satoshi grill mod question
- Instrument cluster upgrade question???
- Rear Windows...all the way down?
- OBD II - what do you use?
- VSC TRAC/OFF and check engine :(
- Speedometer recalibration - what did you use?
- Coil Question?
- New to Toyota NEED HELP
- Alternator fun...
- 1989 4 Runner W/ Charge Light On..??
- pothole help
- 33x12.5x15" on 15x7's?
- Magnaflow Ticking?
- Where can I get chrome molding like this?
- Front end squeeking...only when coasting
- How to
- integration relay/ power lock install
- Is it possible?
- back up light problem
- I got you good you @#$%er
- 22re Oil Pressure Question
- Transfer Case Question.
- 22r tech question.. Oil leak issue
- Suspension
- 89 Pickup - Does it have ABS??
- TinBender's build-up
- 01-02 Stock Taillights
- Educate Me Before I go to The Stealer!!
- OMe shocks a bit expensive
- My 82 yota *sniff Sniff, have to sell
- Downey 1.5" rear springs
- *HELP* Trouble Removing rack & pinion - 3rd gen Taco
- Outer ring on Cv boot for 94 runner?
- Gear Oils
- Changing water pump and timing belt on a 3.0...any gotchas?
