Weird Sounds maybe steering?
Old Mar 11, 2005 | 01:19 PM
88yotaboy's Avatar
About 3 weeks ago i installed a rebuilt napa power steering pump and a rebuilt steering box. About a week later it started making weird grinding noises that usually go away after the engine is warm.... Now another strange sound is coming from the same area. Could it just be the belts? Or do i have a defective steering pump?
Thanks
Andy
Old Mar 13, 2005 | 08:13 PM
88yotaboy's Avatar
Bump
Old Mar 13, 2005 | 08:22 PM
4Crawler's Avatar
Did you check the condition of the idler pulley on the p/s belt? If not, pull the belt and give the pulley a spin and check for grittiness or looseness while turning. If found, you can replace the bearing, I carry bearings for most of the idler pulleys Toyota uses.
Old Mar 13, 2005 | 08:37 PM
88yotaboy's Avatar
Ill check that thanks for the info.
Up&Down
Aug 5, 2015 06:20 AM
RBK
Aug 1, 2015 01:55 PM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
