Speedo and tach after regear
Old Mar 13, 2005 | 04:14 PM
standarche's Avatar
Will a dakota digital work in a 91 pickup v6 4x4 or is the speedo cable driven? Also how would I install a small practical tach for my truck, and are there any brands you guys would recommend
Old Mar 13, 2005 | 08:12 PM
4Crawler's Avatar
One way to tell, get under the truck, passenger side and look up at the transfer case. If you have some wires connected near the rear output flange, then it is electronic, if there is a heavy, stiff speedo cable, it is mechanical.
Old Mar 13, 2005 | 08:16 PM
Yamaha+Toyota=Fun's Avatar
My friends 91 v6 4x4 pickup has a cable driven speedo, mine however is electronic.
Old Mar 13, 2005 | 08:53 PM
retardedspleen's Avatar
is it possible to swap out an electronic speedo sensor to an actule speedo cable? or is that unrealistic? or too hard?
Old Mar 13, 2005 | 09:00 PM
4Crawler's Avatar
Probably possible, you would need to swap the speedometer out as well and get the VSS for the back of the speedo if needed (e.g. cruise control).
Old Mar 14, 2005 | 11:35 AM
standarche's Avatar
well mine is cable driven, are there any options or am I stuck?
Old Mar 14, 2005 | 12:08 PM
4Crawler's Avatar
You have a few. #1 re-gear the axles for the size tire you are running. #2, get a recalibration gear box for the cable, a good speedometer shop or on-line places have them. #3, determine how far off you are (GPS works great) and just account fhr the difference.
shisha1999
Mar 3, 2016 07:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
charlie_fong
Sep 27, 2015 10:06 PM
imhousing
Sep 10, 2015 02:04 PM
