Stuck PCV Valve
Old Mar 9, 2005 | 02:22 PM
deathrunner's Avatar
Stuck PCV Valve
Has anyone had trouble yanking out thier PCV valve?
Mine is stuck! I tried pliers and everything I can get it to budge. Any thoughts?
Maybe I should work out more.
Also how often should I replace my O2 sensors? I have 188,000 miles on em and no check engine lights, but my mileage is starting to decrease and it is not very responsive.
Old Mar 9, 2005 | 03:08 PM
Adam F's Avatar
Is this when the engine is cold? Try letting the motor completly cool down so that the rubber/plastic shrinks.
Old Mar 9, 2005 | 03:15 PM
4Crawler's Avatar
This worked for me:
Old Mar 9, 2005 | 06:56 PM
Tacoma Dude's Avatar
I had the same exact problem last year!
In fact if you did a search you could probably find it. Let me guess... grommet is hard as a rock? I wouldn't be surprised if the grommet lip has already torn off.
I used a few sparing sprays of WD-40 with vice grips and it came out after a little bit of yanking.
Old Mar 9, 2005 | 07:01 PM
Jay's Avatar
Jay
Ya, I wouldnt even attempt without having a new grommet and valve in stock.
Its just silly to down a rig, over that stupid grommet.
Old Mar 9, 2005 | 07:42 PM
Bumpin' Yota's Avatar
I pulled my 3vze's valve cover, anchored the PCV in a vice, and went to town pulling on the valve cover and levering the PCV out....
Broke the grommet which was hard as concrete....then had to break up the ring of the grommet in the valve cover to get it out...
Old Mar 9, 2005 | 08:01 PM
How much does a grommet cost and can I get it at Kragen/Napa/AutoZone
Also does a hard grommet effect idle or mileage?
Old Mar 9, 2005 | 08:31 PM
Napa does have it... I forget for how much though.
Old Mar 9, 2005 | 09:11 PM
Jay's Avatar
Jay
Nope.
A hard grommet could leak oil however.
Should the PCV (Positive Crankcase Ventilation) valve become stuck open, usually the only symptom associated with it is excessive oil consumption.
Old Mar 10, 2005 | 03:15 PM
Originally Posted by Jay
Nope.
*raises hand* (i'm in that boat)
Mine was stuck open till i beat the snot out of it....then I drilled the b!tch out, stuck it back in the valve cover with a new grommet. Next some rubber hose will be attached to it and to another PCV valve that WONT be under the intake plenum, then from it to the plenum. PCV mod rules!! LOL
Old Mar 10, 2005 | 04:41 PM
Hey that's an interesting idea!
Old Mar 10, 2005 | 04:59 PM
payyourtoll's Avatar
mine was stuck to, not too bad though. The grommet was hard and brittle, and I could not get a grip on it to save my life; kept breaking apart. The grommet was $4 from Toyota.
Old Dec 18, 2006 | 03:31 PM
nothing1's Avatar
Honestly don't call me stupid or anything but i can't find my PCV valve! does anybody have a pic of the exact area where it is suppose to be. it's a 3.0 1990.
Old Dec 18, 2006 | 04:48 PM
Yota Runner's Avatar
Nothing1~ it is on the passanger side of the block under the intake plenium on top of the valve cover...just look at that side, see were its the most crowded...its under there. Maybe someone will post a pic?
Old Jul 1, 2009 | 09:57 PM
chuckie's Avatar
Thanks for this info, it was very useful. Just spent 2.5 hrs getting my valve out. I've got a 93 pickup. Ended up cutting the top of the pcv gasket off. Then I used a vice grips to pull up on the pcv valve enough so that I could get a heavy duty wire cutter to get underneath the lip of the pcv valve. I put a block of wood under it and used it like a lever to pry the valve out. Be careful though, when the valve comes off, the gasket will split and you'll want to be careful that it doesn't fall in.
Old Apr 15, 2014 | 07:13 PM
jonnyfro's Avatar
pcv grommet?
Yeah, what is the grommet? Is it the rubber ring that goes around the valve cover or the insert that sits in the valve cover that the pcv goes into? The rubber ring on mine is toast and I think I may have damaged the insert. It only stays in place if I pull up on the pcv. If I push down on it it kinda flops around. I hop I didn't break anything and have to get a new valve cover..
Old Apr 15, 2014 | 07:17 PM
rworegon's Avatar
Originally Posted by jonnyfro
Yeah, what is the grommet? ..........or the insert that sits in the valve cover that the pcv goes into?
This ^^^^^^
Old Apr 17, 2014 | 07:21 PM
jonnyfro's Avatar
Oh ok thanks for clarifying.
smthwsn357
May 1, 2024 07:28 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
Gargoyle_Runner
Aug 28, 2015 01:36 AM
Duppie007
Aug 20, 2015 04:39 AM
sojourner567
Jul 16, 2015 08:52 PM
