PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Seized front diff?
  2. Swapped Transmission mount, got P0171 Code.
  3. Help me figure out how to save her! (+/- head gasket)
  4. Front Clamshell Differentials - Are these compatible?
  5. Front brakes activating
  6. Radiator leaking, again
  7. Airbox Intake Question
  8. 2003 Tacoma brake issues. I could really use some help
  9. Front Struts/Coils
  10. 99 tacoma hesitation at 2300 rpm all gears.
  11. 1997 Tacoma 4x4 3.6l V6 auto 140k
  12. Cv axles too short after manual-hub conversion on 96 4runner
  13. Control Arm/Bushings
  14. HELP! 4 runner wheels locking up by themselves when going around curve
  15. Do I need new rotors? Also a leak in the rear diff?
  16. 2004 Tacoma to 1997 grill
  17. Terrible timing
  18. 97 Tacoma Motor
  19. Transfer Case Nightmare
  20. 97 LTD 4Runner 4WD Not Engaging
  21. Regear?/
  22. Proper fuel pressure regulator operation on 3.4l.
  23. Stalled out and popped EFI fuse
  24. P0171 Help
  25. Steering wheel rattle
  26. Yota
  27. Advice for replacement cat catalytic converter 2000 3.4 SR5
  28. 97 4Runner Limited Intermittent Wiper Malfunction
  29. Clutch
  30. Struts
  31. Manual Swap with 2nd gen parts?
  32. Transfer Case Switches
  33. Engine swap
  34. Please Help!? Cruise Control Doesn't Work!
  35. Ignition Timing Problem
  36. Transfer case leak - mystery part
  37. Tacoma Backfire and No Cold Start
  38. 99 4runner V6 code 300 & 303 help needed
  39. Front Bumper a little lopsided. And other issues !
  40. Where do you buy OEM Toyota parts?
  41. Tie Rod Shakedown
  42. Auto to manual conversion help
  43. HELP! Trouble shooting high fuel consumption without OBD2 scanner (3.4 5VZFE)
  44. Passenger side cam won't rotate all the way after timing belt broke.
  45. Convert Elocker to air actuated. Anyone interested?
  46. 2001 4runner gear swap question
  47. Name this thingy (parking brake pivot?)
  48. timing marks not lining up
  49. 2001 Tacoma 2wd 2.4l starts and runs then dies
  50. Headlight Upgrade
  51. U-joint replacement woe$
  52. Question about JDM 5vz-fe swap
  53. 5z-fe Misfire - what next?
  54. Knock Error both banks (Engine Harness Help)
  55. 03 Taco Dome Light Not Working..help
  56. 1999 Tacoma MT R150F Clutch Fork Vibration
  57. 97 4Runner 5vz-fe iac high idle?
  58. O2 sensor on 5vzfe with dual exhaust
  59. Codes after timing belt swap
  60. Could use a little help.....Stuck in 4wd ( or AWD since the differential lock is off)
  61. VSS convert Square wave to Sine wave?
  62. Need a VSS to ECM on custom swap
  63. Rear Air bags w/ brake equalization cable
  64. What wheels are these?
  65. Jaretstuff’s 1999 Highlander Build Thread
  66. 1994 4 runner transmission acting crazy
  67. 01 4Runner transfer case swap
  68. Passenger Side front wheel doesn't stick out as far
  69. Where to add power for extra lamps?
  70. 2001 Tacoma 3.4L Transmission Slip....?
  71. My 4Runner Camper Conversion
  72. Valve Cover gaskets
  73. Confused about oil pressure
  74. Tire Upgrades
  75. 3.4 evap canister lines diagram
  76. 99 4runner Rocking left to right on the highway
  77. Frame rust on ‘99 Taco - Opinions?
  78. 3.4 swap 1988 samurai wiring.
  79. 1996 4Runner door latch
  80. pcv hose collapse
  81. 01 4runner limited auto climate blower fan issue
  82. Brakes: Need Advice
  83. 3rd Gen 4Runner - major rear end vibration
  84. Towing capacity
  85. ABS pump not priming after brake job
  86. 4x4/Tacoma Configurations
  87. Hello need help???
  88. Fuel pump not pumping
  89. bad MAS?
  90. Swapping a 96 5vz for an 03
  91. Swapping a 96 5vz for an 03
  92. BEST 2020 3rd Gen 3" lift?
  93. Tire Shortage?
  94. 3rd Gen 4runner stuck in 4wd
  95. What a night...
  96. '96 Tacoma SR5 4x4 V6 3.4 Won't rev over 3k rpm
  97. 99 runner 4wd V6 brake pedal rock hard / Booster issues?
  98. Valve Cover Bolt Question
  99. 1998 4Runner Suspension Rebuild and Rust Mitigation!
  100. ‘01 4runner only engaging reverse at high rpm
  101. axle code
  102. Coolant Temp sensor
  103. RPMs dropping out and no pedal response on extremely HOT days, ends in a stall
  104. 99 Tall Coil woes
  105. Cell Phone Booster Mount?
  106. SRS troubleshooting 2004 taco 2wd
  107. 3.4 Vacuum Line Clip Part Number Help
  108. 99 4runner Rack n Pinion replacement options needed
  109. 4x Innovations
  110. 96 Taco 2.4l with 5 spd AND ignition issues
  111. No start after frame swap
  112. Lost keys! Help!
  113. 2001 4runner 4wd issues
  114. E-Locker
  115. Thinking about boosting a 97 2.4 Tacoma
  116. old mid west taco - new to yotatech
  117. Snapped bolt on valve cover gasket job
  118. 99 4Runner V6 4WD Erratic power loss and RPM drop.
  119. 2003 Tacoma owner saying hey
  120. Coiled brake line
  121. Brand new heads
  122. proper valve clearance
  123. Somebody help please
  124. Found my next mod
  125. Shout out to McGeorge Toyota
  126. Bottom
  127. 4Runner wiring harnesses
  128. 1990-2002 Toyota 4runner Auto to Manual Conversion
  129. Flexplate blow, New TC & now Solenoid?!
  130. Throttle body interference
  131. IAC Idle Air Control Valve
  132. A little help with a Cam bolt torque setting please.
  133. 2000 4Runner SR5 - Front Differential noise & grind
  134. Why does my AC compressor keep eating pulley bearings?
  135. Stuck idler/tension pulley
  136. Tires: Mileage vs wear vs tread vs...
  137. 5vz valve shims
  138. Lift/Tire Fit Questions
  139. 2002 4Runner Starting Issue
  140. Chipped crackshaft still usable?
  141. Chipped crackshaft still usable?
  142. Squealing whistling 3.4
  143. Is anyone running 255/85R16 tires?
  144. Loud lifter tick after injector install
  145. inner Cv boot mod
  146. Did I break my brakes?
  147. Door Latch
  148. 2000 4Runner SR5 - 4x4 issue
  149. Wheel fell off.
  150. Can somebody please help
  151. Looking to do Fuel Injector replacement
  152. Unable to get rear differential fill bolt free
  153. Running Boards
  154. 99 runner ....wheel weights flying off
  155. Idle issue, occasional stalling
  156. 99 V6 running rough, throwing codes and flashing
  157. 96 2wd 4cyl auto taco transmission issues
  158. Power steering idler wheel.
  159. 2002 Tacoma hesitation/stumble/misfire
  160. ADDCO Front Anti-Sway Bar fell today
  161. 3rd Gen 4Runner Electrical Connections
  162. K&N Air Filter Issue
  163. What is this in my glove box ?
  164. Brake Fluid Flush Question
  165. Hello...New Owner of a 2002 4Runner
  166. 5VZ-FE idle adjustment?
  167. Blowing fuses! Help!
  168. Ignition Key Sometimes Fails to Release
  169. Trans or transfer
  170. '99 3.4 5speed transfer case compatibility
  171. 97 4Runner accessory belt issue
  172. 1st gen tundra seats
  173. Crazy vibrating
  174. Will not idle
  175. 97 four runner
  176. Reboot: Formidable 2002 Thundercloud Sport TRD Supercharged 2.1” Pulley Build
  177. Brake issues
  178. Drive shaft play 97 Toyota 4Runner 4x4 5 speed manual
  179. Steering Rack Control Valve Leak
  180. 3.4 coolant temp sensor
  181. CEL Codes and Rough Running
  182. TRD Supercharger vacuum and air hose question
  183. 99 runner v6 4wd strange cold start issue
  184. What to check if I'm feeling "drag"
  185. SRQ Fabrications Fender Flares?
  186. Check out this bumper cutout!
  187. Cold start problem
  188. Tundra Brake Kit
  189. How do I get behind the INTERIOR fuse box?
  190. 1999 3rd gen 4runner stuck in 4wd w/lights flashing
  191. 99 3.4 - M/T &4wd speed sensor picture
  192. 1999 T4R Limited transfer case woahs
  193. Timing belt
  194. Sunroof not fully closing
  195. Does anyone run a full-time power inverter for in-cabin AC voltage?
  196. P0172 won't go away...
  197. Hilux sfa 1996 2,8diesel
  198. New to the forum ‘97 4Runner Limited
  199. Axle Confussion
  200. 3rd Gen T4R OEM 4 Pin Flat to 7 Pin Blade Conversion...
  201. 4WD help needed -- 4WD won't dis-engage
  202. Bilstein 5100 OEM Coil spring orientation
  203. Front Driver Side Tire Clicking at Full Turn
  204. Radiator replacement- how do I know if it’s needed?
  205. A340f failure
  206. Is my e-locker engaging?
  207. Gen 1 dual batteries?
  208. 4x4 lİghts & center dİff blİnkİng
  209. Help
  210. 5ZVFE engine shudder at idle HELP
  211. 3rd gen 4Runner hesitating with slip indicator
  212. Asian hubs
  213. She’ll Rotella t6
  214. 4R Bilstein 5100 and related components
  215. 4R Limited Climate control bulbs
  216. Spring issue
  217. How to test for a leaking 3.4 injectors
  218. 3.4 clutch disc install direction
  219. White smoke from Tailpipe
  220. 96 4Runner no start, no crank [video]
  221. engine noise
  222. Rare 3rd Gen 1996 2.7L 4runner with broken LSPV / missing parts
  223. 4 Cyl engine available in 2001 4runner?
  224. Advice on buying.
  225. Drivers side needle bearing ecgs tool ?
  226. 3rz 2.7 motor swap
  227. 3.4 camshaft installation ? (Please help)
  228. 99 4runner body on an 05 Tacoma frame?
  229. 1998 Toyota 4Runner keeps turning off.
  230. 1997 4Runner P0330 keeps coming back even after new knock sensors and harness
  231. Vibration in wheel- new
  232. 4th cylinder misfire issues
  233. 2000 Toyota 4 Runner Limited 3.6L Will not Start
  234. Replacement fobs
  235. 95 SR5 4x4 ABS Question
  236. Rear heat hose size?
  237. Toyota ignition lock repin-repair
  238. 2000 4Runner SR5, 5spd - Transfer Case (4x4) Issue
  239. 99 4runner Fault Code Coolant Temp
  240. 99 4rnr rear wiper motor problems
  241. 3 pin tps to 4 pin tps
  242. 98 4runner ltd flickering battery light
  243. Another starter R&R
  244. How to fix busted sensor mount?
  245. 99 Limited 4x4/Locker Issues
  246. 2000 4Runner 3.4L misfires cylinder 1,3,5
  247. 96 tacoma 3.4
  248. 2000 4runner ABS problems
  249. Replaced car battery, now A/C has weird smell???
  250. Are 96-2004 Tacoma's same cab/bed mounting positions?
