No start after frame swap
Old Aug 10, 2020 | 04:10 PM
aowRS's Avatar
My buddy is wrapping up a frame swap on his ‘99 4Runner. I wasn’t there throughout the process, but he claims that he disconnected pretty much every electrical connection from the engine back.
At this point, the truck does not start. Only faint clicking within the fuse housing (in the engine compartment). No starter solenoid clicking or anything.
All other electrical items seem to function as normal.
Any thoughts?
Andreas
Old Aug 10, 2020 | 06:16 PM
fierohink's Avatar
What have you gotten yourself into?
  • all the grounds?
  • ecu connectors?
  • starter?
  • any connections from the column for the ignition cylinder?
was this just a frame swap? When I did the frame resto on my 94 pickup, I unplugged the harness at the ecu and fished everything out the firewall and laid it across the motor. Where did they split for this?
Old Aug 17, 2020 | 12:38 PM
aowRS's Avatar
Yes, just a frame swap, but he admitted unplugging way more than he needed to.
After fiddling with it, trying to jump it, replacing the starter relay, nothing worked. Then his son noticed that the gear indicator in the instrument cluster didn’t match up with what the shifter displayed....
Adjusted the shift linkage underneath and the truck started right up.
Andreas
Old Aug 17, 2020 | 03:09 PM
fierohink's Avatar
Ahhh the invaluable second set of eyes
Old Aug 18, 2020 | 04:03 AM
aowRS's Avatar
Third set. My set was useless.
Andreas
bone collector
Jul 15, 2020 02:19 AM
EWAYota
Apr 20, 2017 08:21 AM
MadMax92
Aug 9, 2014 02:24 PM
91 tonka
Jan 22, 2010 06:10 PM
