PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Replacing my transmission next week. Any tips??
  2. Cat back Exhaust question
  3. Front and rear 3" ome lift toyota 4-runn
  4. $30 combustion leak test
  5. Lifted runners & child seats, hard to use?
  6. Inline coolant heater install on 3.4L
  7. Oxygen Sensor Plug Removal - Help!
  8. Radiator hose clamps ?
  9. my own FIELD MONITOR UNIT
  10. why does a tacoma 3.4 sound different than a 4runner 3.4?
  11. Rear Leafs
  12. $950 for 4.56 Gear, new seals and bearings
  13. Pioneer AVIC-D3 install
  14. Gen 2 Door Lights in Gen 3
  15. 97 Tacoma will not start, wierd buzzing sound
  16. Gotta love the CFC program
  17. Finally pics , 3-4" lift and 285 km2's
  18. programing a remote from a 2001 4runner to an 02 Highlander
  19. Very serious about 4wd conversion
  20. Pics of new 2002 SR5 Sport 4Runner
  21. changing cabin air filter
  22. Dual Batteries: Installed
  23. 3rd gen Capable of having remote powered rear window?
  24. Rock slider question...
  25. Help Wiring Apexi S-AFC to 5VZ
  26. Gears interchangable?
  27. Optima battery install
  28. 2001 Limited 4wd broken !?!
  29. P0300
  30. CD Player #34224 - stopped working
  31. Heater Squealing
  32. 3.4L Swap bogging/bucking maybe misfires
  33. 3rd Gen 4Runner Light Bar
  34. Cold air or throttle body spacer
  35. 95 Tacoma auto tranny problems, need some help
  36. 3.4 Drive Belt Diagram Help
  37. Front Seat Extension?
  38. 99 vsv sensor number.
  39. Dang! Rebuild Cylinder Head?!
  40. Help! No heat issue, not a basic concern
  41. Bad Bearing
  42. 03 tacoma- projector headlight ideas?
  43. Need part Numbers..
  44. front end noise
  45. To Charge or not to Charge?
  46. 10 years and 100K later......gotta love Toyota!
  47. CEL and rough running
  48. Headlight collecting moisure.. turning into ice!!
  49. High idle switch anyone ?
  50. TRD Tundra coils for lifting a 3rd gen
  51. IAC Valve or IACV Inspection and Testing
  52. Replace gaskets when changing diff / txfer case oil!
  53. failed emission test help/vacuum lines/egr?
  54. Turn off ABS on a 96. NOT the "andy mod" for VSC or trac.
  55. Trailer converter part number
  56. Auto to Manual trany conversion..i need help!
  57. Radius arm hitting front coil under compression
  58. Sway Bar Bushings Problem
  59. Headlights Going out While Driving !
  60. Broke: Lower Ball Joint :(
  61. 99 runner - alarming lower control arm issues
  62. Rear Heater Not Working
  63. 97 4Runner Clutch/Trans issues
  64. Winter temps / Summer temps affecting bushing noises
  65. Alternative to OME N91SC?
  66. Unique situation. P0171 CEL, but will my URD screw a new Primary O2?
  67. CB antenna mounting help
  68. 2008 Tundra coils?
  69. gauge lights?
  70. Magnaflow, p0171, p0420 and p0500
  71. Lifted my 4Runner
  72. Custom Autometer Guage cluster
  73. Fixing my horn after the airbag went off
  74. 97 4Runner Manual Trans leak
  75. Transmission help?
  76. All A340F trannys the same?
  77. new differential gears breaking-in
  78. Dual Battery isolator problems!
  79. Grinding noise...
  80. New 4Runner won't start!
  81. HELP! Line running on the underbody busted and is now leaking pink
  82. surface rust?? advice?
  83. IAC Valve Problem
  84. Correct part numbers for OEM radiator?
  85. Noise behind dash??
  86. Max Speed While in 4WD 98 Limited?
  87. on the trail
  88. Brake Line Help
  89. Suspension Questions
  90. 3.4 V6 - Poor Fuel Economy and High Idle
  91. Maintenance Questions
  92. 98 4Runner wouldn't start...
  93. Transponder key
  94. Who's running alcohol injection??
  95. Thermostat backlight going dim
  96. Broke this off my valve cover - what is it?
  97. coil spring vs torsion bar
  98. Modified my TJM T-15 Bumper - WabFab Style
  99. O-nex hid kit install 02 runner
  100. Rear Lift option, need to change
  101. '99 or '00 LIMITED w/ Rear Diff Locker?
  102. 4WD won't engage
  103. *** Bittersweet Front 1.5" lift. ***
  104. New remote start. OEM keyless entry won't work.
  105. High pitch squeal on start up?
  106. A Multitude of difficult to diagnose problems, coolant, starter, brakes, etc.
  107. 4runner with 50 series Flowmaster.
  108. part name??
  109. Flowmaster 50 series on 5vzfe.
  110. Help with diagnosing rear end noise
  111. Transmission Maintenance
  112. how to split the front diff?
  113. 4runner rear bumper
  114. ARB Fog Light addition
  115. Fitting 2nd gen arb bumper on 3rd gen?
  116. 16" TOYOTA TUNDRA TRD WHEELS on a 99 4Runner ?
  117. 99' 4runner V6 cold start rpms
  118. 98 4Runner - Fuel Pump
  119. license plate bolt sheared off
  120. Has anyone installed the TRD Trans cooler
  121. 5vzfe Rod Knock?!?!?
  122. Looking for ECM part# for 96-98 Runner, 3.4, manual, 4x4
  123. part number -- backlight bulbs for ECT /Defrost and Rear Window Up/Down buttons
  124. Finally Found A Replacement Truck!
  125. 3rd Gen tailgate
  126. 3rd gen projectors.
  127. locker harness question
  128. Slow Start when Cold - 3RZ-FE
  129. more photoshop help
  130. Why am i still losing coolant?
  131. 3 Catalytic Converters in 6 months!!
  132. ADD problems 01 taco
  133. Confused on radiator/tranmission cooler fixes
  134. Help me with my tune up, please
  135. 1998 4runner - How to change key tumbler?
  136. Oil in intake , pics
  137. parts diagram for you tacoma/3rd gen runner guys
  138. stainless steel brake lines
  139. please post pics of 3rd gen 4runner with 305/70R16's
  140. TRD taco rear in 4runner..
  141. Help needed with major motor problem...
  142. Got a deal on an e-locker
  143. 3rd Gen Crash Test Video
  144. 285's and lift on but... CV problems.. PICS
  145. How much oil is too much or Am I the dipstick?
  146. 02 t4r remote start + keyless wires
  147. Tacoma Fender Flares on 3rd Gen 4 Runner?
  148. Looking for pics of stripped out interior of 4Runner
  149. e-locker switch mod
  150. What kind of fuel?
  151. highlander v6, interference engine or not?
  152. keyless entry
  153. Some flat black Rustoleum paint and spray can mod
  154. wheel well height from ground with lift?
  155. Jardine exhuast for an 02'
  156. New wheels and shoes installed with pics!
  157. Vanishing Coolant in 3RZ
  158. 02 radio
  159. A340F transmission issue: solenoid? ECM? TPS?
  160. What mounts did you use for ARB compressor?
  161. exterior emblem help needed
  162. any recalls due to rust on 3rd gen runners?
  163. My painting plans; matching paint/colors?
  164. Cold High Idle
  165. For anyone thats having keyless entry issues
  166. Snugtop Camper Shell
  167. Tranny/Brake Problem ???
  168. Just picked up 285 km2's , now time to lift , PICS
  169. HVAC Control Lights
  170. Key stuck in ignition switch
  171. External trans cooler questions and people who bypassed the radiator get in here!
  172. First time CoilOver Owner with question (Icons)
  173. Bumper retrofit?
  174. mod to clear 15" wheel
  175. CV removal, need help!
  176. Making the Switch! Questions...
  177. Save some cash on Tundra brakes
  178. 96 4runner headlight issue
  179. Changing Oxygen Sensor when nuts are rusted
  180. 99 has hard time turning over
  181. 3rd gen rear brake question
  182. Red Line 75W90 GL-5 Gear Oil in transfer case?
  183. 1st Gen Roll Bar Installed!!!
  184. New guy with breather question
  185. 3.4 to 2.7 motor swap questions...
  186. Keyless remote won't work
  187. Rear Differential w/elocker
  188. Side view mirror glass replacement?
  189. ARB Tacoma vs. Prado Bull Bar
  190. Shaking at highway speeds
  191. 2000 4Runner Transmission Rebuild..
  192. Work Rigs?
  193. Manual Xmission Noise -- '96 4Runner 3.4L V6 4WD
  194. 02 replacement question
  195. 1996 4runner to 2002 tundra motor swap Help Help please
  196. 95 1/2 tacoma battery/ alt. problem need help!
  197. P0446 code - what have you replaced to fix?
  198. more 3rd gen 4runner tundra brake Qs
  199. 33-10.50x16 TsL's on stock Taco wheels
  200. Does the RR locker imply a gear ratio?
  201. Bumper parts needed for 2000 to 2002 Sport or Limited
  202. Magnaflow Exhaust 15810
  203. 4cyl "bucking"
  204. ABS light is on
  205. Cruise Control Question
  206. There's a spider in my TPS!
  207. For those of you with weak hatch struts
  208. 4runner - 1, Deer - 0
  209. E-Locker axles
  210. Anyone know of a good Toyota machine shop in Vegas???
  211. I hate to even ask
  212. 1997 4Runner Odd Problem with Rear Hatch Door Please help
  213. Tundra TRD Coils with Bilstein 5100 Adjustables
  214. 02 4Runner needs a lift
  215. MY NEW TRUCK!! 99 4x4
  216. First time to Moab..
  217. brake groan
  218. # of Coils in Stock 96 Taco front springs??
  219. Dirt cheap supercharger fuel mods
  220. Ignition Cylinder Replacement Question
  221. Automatic shifter overdrive button/ shifter swap
  222. Look at this Alignment printout and see if it makes sense
  223. Replacing valve cover gasket
  224. I put a 99 fat lip bumper on a 97
  225. 02 sensor replacement - 01 TACO Dbl Cab
  226. P0171, Cleaned MAF, Check 02, hunting RPM when cold
  227. *** Need some Recco's. Am I heading the right direction? ***
  228. Where to buy Denso or OEM parts (besides dealership)
  229. Installed New radiator.. Have questions
  230. got my rear differential fixed
  231. 99 Tacoma clutch issues
  232. how did i manage to not have Rear Diff...
  233. CEL and VSC lights on !
  234. Whats good compression?
  235. Beach Explorations (Pic Heavy)
  236. Squealing from alt belt!
  237. Valve clatter from 5000-5500 RPM under hard accel in 3.4L?!
  238. TRD SC Longevity
  239. TRD Snout rebuild?
  240. Brake Wheel Cylinder Piston Seals 1998 TRD
  241. Axle Seal - What do I need to replace?
  242. Where are the Alabama 4runners at?
  243. Catalytic Converter Removal
  244. Pic request, 2.5 or 3in lift with 31 tires
  245. Will tacoma 3" lift spacer fit my 4runner?
  246. 890 w/N86
  247. Oil Filter Housing Seal leak? also fuel filter
  248. Rock carnage and roll cage ???
  249. swapped 882 for TRDs. Rear end Alignment ?
  250. Lifting a 2000 4runner
