- anyone running 16x10 285/75/16?
- Once Again Fuel Mileage
- Dyno charts w/o supercharger
- need help:done 1/2 the work but dont know still if the resistor or blowr motor is bad
- K&N DryCharger ??'s
- Installing SS Brake Line Extension
- Bigger brakes on 1st gen
- Cylinder Trouble...
- Coolant Leak in Front of 3.0 VZE
- Running rough after water pump assembly replaced
- winter is here and mpg is down 2mpg :(
- 95 Tacoma needs exhaust manifold
- Order ID: 9410226
- Rack bushing part #?
- split folding rear seats - 87 4runner
- TJM 17 install on a 3rd gen 4runner --- cut off tips?
- Anyone have Exhaust Specs or a diagram?
- i need this fuel line
- 97 4runner Vibration above 2500 rpm
- Bad Headgasket?
- How bad was this clutch?
- anybody have these rims on a 3rd gen..?
- ARB bull bar install
- Trailer Electrical Connections
- 4.5" BS on 3rd Gen..?
- thermostat install questions, spring in or out????!!
- confused on what shocks to get on my 98 4r
- highland mud flaps
- Some General Questions on the 1st gen 4 Runner
- LC Engineering Header?
- Do I Need An Egr ??
- 20r and 22 r motor
- swith for power antenna?
- 3" cornfed W/ BiLsteins..
- Anybody has 3.4wiring diagrams that I can copy
- To trade or not to trade
- how long without urd kit?
- Power Steering Question
- 3rd gen 4cyl problems
- exhaust
- Cost of an exhaust for a 3.4 swap?
- Alternative way for introducing Seafoam??
- brakes squeak when not on the pedal
- Torsion Bar Adjustments
- valve gasket is leaking
- supercharging a 3.4
- True Flow Airfilter & PIAA lights for your Runner--Great Products
- Wheels For My 97 Tacoma
- Weird noise after starting
- Check Engine, Code says Knock Sensor....
- Will an ARB bumper from 93 4Runner fit 94 Pickup?
- 3VZE poor idle tip...
- Sweet Little 1980 w/ 3.8L Turbo, D60, ARB's on ebay.
- OD problems almost solved over the weekend!!!
- Wheel well plug removal
- 3.0 with no spark
- Anyone here have a yakima rack with basket? (mounting)
- mile marker manual hub problem???
- My 4Runner Died
- '91 4Runner EGR hose ??'s
- P-settering Pump Compatibility?
- Intermittent starting on 3rd gen
- Brake job from Hell!!
- Tundra wheel on 85runner. HELP- WHEEL SPACER Q!
- ATS/Inland Truck control arm bushings
- Failed inspection for rust
- How long will a bad water pump last?
- blower fan has two speeds
- instro panel problem.
- 2 very nice 3rd gens spotted together!
- Dead spot in your head light switch ? Ive got your fix.
- 90 runner with ticking in engine
- 3 thermostats...2 years?
- can't shift 4H to 2H on the fly
- Purchased 95 4Runner with Superlift, needs BRAKE WORK and such..
- suspension/shocks problem
- 1996 runner, windows, seats, mirrors dead
- cluster swap problem
- 96-02 4Runners, Have you seen these headlights?
- dash cover
- Need Pics of 50% tint
- rev limiter on 22re?
- quick change cv mod write up?
- Considering Going Back to OEM Wheels - Advice?
- how useful is the bed in a double cab Taco????
- Help with bad brakes
- anyone have a CMH relay?
- Loose Front End
- HID(High Intensity Discharge) headlights
- 86 rear brake internals fit 89 truck?
- 2001 4Runner Inspection - Monitors Not Running
- Outer CV joint/drive shaft/steering knuckle question
- Has anyone used the lcengineering exhaust?
- Clutch Question (85 4R)
- Optima Alternatives
- CV boot or Joint
- Got my new Toyo's today!!!!!
- Where to buy tires?
- Does this rig look like a good one?
- found NEW 305 MT/Rs
- New Wheels Today
- URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks
- Going to purchase new rims..
- Bad Grinding noise at speed on the highway
- Throttle Body Overbore - TPS
- For those considering a s/c, here are some thoughts
- INFO: rear hatch strut service contact
- 2WD MT V6 possible?
- DVD Navigation Update
- are 96-01 body parts interchangable?
- Rancho 5000
- HELP! 92 3.0V6 Rnr Dies out. No cmptr reading
- What are your tire experiences?
- Axel seals
- I need some help with defining a noise
- Audio placement for 3rd gen Runner
- Cracked Mirror
- Anyway find good aftermarket replacement chrome bumpers
- Driveline issues
- Should they undercoat?
- Problem with A/C fan Switch
- fiamm freeway (highway) blasters
- Steering Column/Steering wheel moves/wiggles left and right???
- Nitrous?
- Speedo
- wheels size fitting?
- Electrical on the 3G Runner
- Tundra shocks on a 3rd gen.
- Fuse Panel under the hood
- Power antenna mast replacement is easy
- noise in 4wd
- Nice Before / After mod pics
- Help on alignment and other....
- 22re tb spacer
- Help Tjm Install Problems
- Rear Brake Problems
- direct replacement horn? - 1st gen 4r
- Getting a clunk on pass side under breaking.
- Metal plate inside an oil filler neck.
- Stupid freak'n heater
- Taco Tailgate weather-proofing
- Clutch Bracket
- 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement
- Any 2nd gen owners with front Husky liners ? READ THIS !
- HG HELP: Anyone in Dallas, TX...
- 97 4x4 taco suspension
- Solid Axle Runner and IFS Runner Decisions
- OD temp sensor bypass?
- So...if I forgot to reconnect my TPS
- sweet new bumper
- good bug/wind deflectors for a 2nd gen 4runner
- Frame Width 86-95
- Heater Core Woes? UGHHHHH!
- 3rd gen winch bumper and introduction
- brakes - wear indicators or other?
- selling all my unused CB stuff from my stupid buying spree last month ;)
- My '90 v6 is almost dead... help me!
- Live Help
- Its more of a tapping
- Remote Start - Tach wire location and window control
- motor bad on the back window
- Knocking, but may not be valves?
- flowmaster 40 series on 4 banger
- 2003 Highlander interior light timer
- 1993-150F Transmission Rebuild w150k miles
- True cost of a 3.4 swap...
- Whinning noise
- 3.4 Air Intake suggestions
- Steering Popping?
- Stock exhaust?
- Psycho Idle - '85 Runner 22REC
- OEM Cat mesurement
- OD issue, I have 2 part numbers and dont want to order the wrong parts!
- Catalytic Converter - Consequences of not replacing?
- decisions, decisions....time for some rims
- Crank pulley hell
- Aux Light Wiring
- Tacoma wheels fit on a 1985?
- not warm air
- $Runner to Truck door switch??
- Door pockets
- Crazy ˟˟˟˟˟ last weekend!
- Gen 3 Fog+Turn options for ARB ?
- DRL Switch?
- 3.4 swap and Charcoal canister ?
- Difference in 3rd gen rear bumpers?
- is the 22re an interference engine (not a stupid question)
- 01 Highlander OBD2 codes
- tint removal?
- VSC...hmmmm....
- IF I were to sell my rig...
- Water pump gasket?
- oil plug question
- 2ng gen rear window defrost
- ECU pinout diagram - 3rd gen 4runner
- antenna noise?
- Can't get starter to turn. yyyyyy?
- Play in side gear shaft
- Turbonator.. this is a JOKE!
- Front driveline slop.
- What's a fair price for a 2002 Sport Edition?
- Is it OK to let truck sit w/o any coolant?
- distrubutor square and round plugs
- I'm back...with a tacoma
- Finally got the Epic Mobile back!!!
- TRD Cat-Back exhaust for 2000 models
- addco swaybars or no?
- First roadtrip with the 3vZE...suprising results !
- Parking brake handle is stuck, and spins
- Installation of factory fender flares?
- Trans still wont go into OD, no help from dealership.. HELP! I need PNs!
- Semi Newbie with X runner ?
- Proof that different brand of gasoline might indeed improve gas milage
- Factory roof rack and MPG question?
- HELP ME, Troubleshooting?
- GM Alternator details (please)
- 3rd Gen mirror removal, need help ASAP... anybody have a Haynes handy?
- 4wd Not Working...89 Runner
- thinking of dual batteries in a 3rd gen
- air silencer removal
- Has anyone fixed the spare tire clunking issue on their 3rd gen?
- Take a look at these tires....what do you think?
- Finding an overhead console (or part of it)
- clutch replacement
- Battery warmer
- Cruise Control needs tuning???
- 3VZ-FE camry cams in a 5VZ-FE 3.4L!
- Plug wire retaining clips on coil pack
- 4 wheell drive light does not turn on .
- tire/brake help
- Battery help
- 285's on stock wheels? Is it safe?
- RIP 4runner????Maybe
- just spent 200 dollars for 4runner
- 2003 toyota seqouia cuts off in gear
- tips for banging out crunched bumper
- Turn signal not working???
- Any pics/opinions of 3rd gen OEM seatcovers
- Ball Joints and Idler Arm
- 2nd gen Passenger side CV joint
- Question for Southern cali people
- oh my god (it wont start)
- Thinking of Selling 4runner
- I Hate IFS!
- Question about tps part numbers.
- rim sizes
- Opinion wanted: CirKit Boss Fuse Block
- The Runner is acting funny
- Axle Wrap or Automatic Transmission Problems?
- How tight can exhaust valves be with before they burn.
