wheels size fitting?
Old Nov 16, 2005 | 08:17 PM
yotarunner96's Avatar
i have a 96 SR5 with the stock 16" wheels. Is there any way that a 15x8 with a 3.75 backspacing aftermarket wheel fit on my 4runner?
Old Nov 16, 2005 | 08:21 PM
garrett1478's Avatar
no. unless you want to grind brakes, stick with a 16" wheel.
Old Nov 18, 2005 | 08:40 AM
4Peanut's Avatar
And even then, not all 16" wheels are the same: https://www.yotatech.com/forums/f2/true-false-all-aftermarket-16-wheels-will-rub-calipers-3rd-gen-4runner-69835/
I tried Mickey Thompson Classic II's in 16x8 with 4-7/16" backspacing, and they did not clear the calipers on my '96. I have heard that folks with newer 3rd generation 4Runners do not have the same caliper issue. I ended up with similar looking Pro Comp Xtreme Alloys in 16x8 with 4" backspacing. Wheeler's Off-Road (www.wheelersoffroad.com) sells them, though I bought mine through a local shop.
4Peanut
Old Nov 18, 2005 | 08:58 AM
well i have a 96 that came with stock 15 inch wheels. when i got my lift and tires i just got 15x8 extreme alloy 1069 wheels. a bubby of mine wants to trade wheels, he has a 2000 4runner highlander 5spd 4wd with the stock 16" wheels. is there any way that we could do this trade?
Old Nov 18, 2005 | 09:07 AM
ebelen1's Avatar
If yours came with stock 15" wheels, then you should be fine. You can go from a 15" wheel to 16" w/ almost no problems but you can't go the other way around because of the bigger brakes on the stock runners with 16's.
Old Nov 18, 2005 | 09:15 AM
so my buddy with the highlander will not be able to fit my 15x8 aftermarket wheels?
Old Nov 18, 2005 | 09:23 AM
ebelen1's Avatar
No, he would not be able to fit your 15's if his came with 16" stockers.
Old Nov 18, 2005 | 09:58 AM
well shoot, i wanted to trade with him. would he be able to grind his calipers a little bit, or would it not be enough to fit the 15s
Old Nov 18, 2005 | 10:13 AM
what was your stock wheel size? post #1 you said 16"... post #4 you said 15"...
Old Nov 18, 2005 | 11:53 AM
my stock size is 15, and my buddy that i want to trade with has stock 16
Old Nov 20, 2005 | 01:10 PM
Flamedx4's Avatar
Trial fit 'em and see. Only takes a minute.
It is not always true that if it came with 16" wheels then 15" won't fit. The bigger brakes did not come on all 16" equipped vehicles.
Try them and then you'll know.
Old Nov 20, 2005 | 01:24 PM
MTL_4runner's Avatar
I would try it and see how much they are off if they don't fit. I may grind a bit on a caliper but be careful not to take off too much material.
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
coffey50
Jul 28, 2015 10:55 AM
94yotaMI
Jul 21, 2015 05:47 AM
Yotoder865
Jul 9, 2015 07:51 PM
