wheels size fitting?
Originally Posted by garrett1478
no. unless you want to grind brakes, stick with a 16" wheel.
I tried Mickey Thompson Classic II's in 16x8 with 4-7/16" backspacing, and they did not clear the calipers on my '96. I have heard that folks with newer 3rd generation 4Runners do not have the same caliper issue. I ended up with similar looking Pro Comp Xtreme Alloys in 16x8 with 4" backspacing. Wheeler's Off-Road (www.wheelersoffroad.com) sells them, though I bought mine through a local shop.
4Peanut
well i have a 96 that came with stock 15 inch wheels. when i got my lift and tires i just got 15x8 extreme alloy 1069 wheels. a bubby of mine wants to trade wheels, he has a 2000 4runner highlander 5spd 4wd with the stock 16" wheels. is there any way that we could do this trade?
Originally Posted by ebelen1
If yours came with stock 15" wheels, then you should be fine. You can go from a 15" wheel to 16" w/ almost no problems but you can't go the other way around because of the bigger brakes on the stock runners with 16's.
Trial fit 'em and see. Only takes a minute.
It is not always true that if it came with 16" wheels then 15" won't fit. The bigger brakes did not come on all 16" equipped vehicles.
Try them and then you'll know.
coffey50
Jul 28, 2015 10:55 AM
well shoot, i wanted to trade with him. would he be able to grind his calipers a little bit, or would it not be enough to fit the 15s
