Cruise Control needs tuning???
Old Nov 13, 2005 | 10:33 AM
nermalgod's Avatar
Day after I picked up my truck I returned it to the dealer because the cruise didn't work. They drove it around and said the cruise worked fine. It still doesn't work in my opinion. The nuance that I have learned is that I need to hold the cruise stick in the set position for as long as 8 seconds for the cruise to actually take control and sometimes it still won't. I haven't driven with a cruise on many other Toyotas but doesn't this sound wrong? I'm used to a milli-second depression of the cruise button on my old dodge. The resume/accelerate feature kicks in pretty quickly and this is on a manual. I figured my problem had to do with the clutch indicator button thing but it's doing what it's supposed to do.
Is my cruise defective or is this normal?
Is this fixable and how do I go about tuning it?
One thing I have noticed is a cable running from the cruise box under the hood to the throttle has a lot of slack in it. If I knew more about auto mechanics, this would be my prime culprit. However I don't so I'm asking the grease monkeys for help.
Old Nov 13, 2005 | 10:50 AM
garrett1478's Avatar
my cruise works after just tapping the stick towards the set postition. however, i dont get to use my cruise all that often bc of mainly city driving, so i dont know if it works after using the clutch start cancel button or not.
Old Nov 13, 2005 | 03:21 PM
nermalgod's Avatar
I can't believe another deck plate mod question is getting more views than this. Anyone feel like pitching some ideas to me?
Old Nov 13, 2005 | 04:07 PM
bump for some help!
Old Nov 13, 2005 | 04:35 PM
https://www.yotatech.com/forums/f2/cruise-control-issue-68878/
check out christian's post, post #5
edit:
also found here, https://www.yotatech.com/forums/f2/jerky-cruise-control-51488/ (post #4)
Old Nov 13, 2005 | 05:04 PM
nermalgod's Avatar
Hey thanks Garrett. If I didn't know better I would say you're priming me for a favour.
I guess I really need to read further down the threads when I do searches.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
kcaudill
Oct 10, 2015 02:39 PM
the_supernerd
Oct 1, 2015 09:20 PM
Shagool22
Sep 28, 2015 07:53 PM
