Jerky Cruise Control?
Old Feb 9, 2005 | 09:40 PM
TacomaTRD's Avatar
FYI/FWIW on my 98 TRD the cruise was jerky when setting/resuming/coasting, turned out that the cable had quite a bit of slack. The adjustment now is about 3/4+ and cruise is much smoother...
Old Feb 9, 2005 | 10:22 PM
RobT2k's Avatar
How did you make the adjustments?
Mine only feels jerky if I press cancel or coast once it is already set.
How did you tell if there was extra slack? simply visually?
Old Feb 10, 2005 | 03:57 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Also FWIW, I had a GM that had a speedo cable that would bind occasionally causing the cruise control (and me) to through fits...
Old Feb 10, 2005 | 04:06 AM
TacomaTRD's Avatar
visual, I noticed it when I removed my throttle body to clean and replace the D shaped gasket.
When setting the cruise there was always a delay, to make a smooth transition to cruise I had to hold my foot on the throttle longer. If I didn't the truck would slow down and then kick in causing it to have to throttle back up. Same for resume and coast as the system measures speed when you hit the switch and the the slack caused a delay.
Adjusment is easy, on my truck the cable comes from the passenger side, adjust like a throttle cable.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
