can't shift 4H to 2H on the fly
Old Nov 19, 2005 | 07:36 PM
javadoody's Avatar
MT and manual hubs. as per owners manual, i can get into 4H below 25mph no problem. i'm supposed to be able to shift out of 4H at any speed. clutch or not, double-clutch, still no way, it's locked in there tight. push as hard as i can and it won't move. only way is to stop, rock it into reverse and shift.
do i need an adjustment? got any specs? couldn't seem to find anything on the search.
thanks to all for your help.
Old Nov 19, 2005 | 10:14 PM
Elton's Avatar
hmm mine works just fine there must be something thats needs lubed or adjusted
Old Nov 19, 2005 | 11:03 PM
miket223's Avatar
Are all 4 of your tires worn VERY evenly and the same size?
Old Nov 19, 2005 | 11:24 PM
superjoe83's Avatar
thats normal, just drivetrain bind, next time it does it put pressure on the shifter and bounce the throttle, that technique usually works for me
Old Nov 20, 2005 | 12:19 AM
Fix_It's Avatar
mine has always done the same it shifts into 4wd hi like silk but i have always had to stop then shift back into 2wd . its getting into 4wd i need most up here then leave it till spring lol
Old Nov 20, 2005 | 06:50 AM
kyle_22r's Avatar
it's usually pretty easy when you're rolling with no load(take your foot off the gas) and push it in, at least for me.
now, when i test drove a V6 truck with a chain drive case, it was a nightmare no matter what way you put it.
Old Nov 20, 2005 | 07:08 AM
javadoody's Avatar
yep, tires are very even.
Old Nov 20, 2005 | 07:19 AM
trx125's Avatar
If I remember right gear driven r shift on the fly, but chain driven are not!
javadoody's Avatar
hey elton, do you know the adjustement specs? anyone?
thanks to all for the suggestions. i'll give 'em all a try next time, whether or not i can solve it with a wrench. i've tried various ways of taking off the load, maybe just haven't hit it right. colder it is the worse it seems to be too--course that's generally when it need it (snow+ice).
Old Nov 20, 2005 | 07:32 AM
Glenn's Avatar
Sometimes it helps to drive in a straight line so that both the front and rear axles are rotating at relatively the same speed.
Old Nov 20, 2005 | 08:39 AM
runethechamp's Avatar
I'm pretty sure that's not correct. All the V6 transfer cases are chain driven and they do have shift-on-the-fly capabilities, both to 4H and 2H. When driving to go skiing I do this all the time at 40-50 mph with no problem.
Old Nov 20, 2005 | 08:44 AM
4rnr's Avatar
Ive got a 3.0, auto, chain drive and I can shift into and out of anything at any speed. Though obviously ive never tested shifting at highway speeds or anything.
Old Nov 20, 2005 | 10:27 AM
kyle_22r's Avatar
well, technically the chain drive cases are shift-on-the-fly but the geardrive cases really aren't.
however if you have manual hubs or drive flanges, you can shift on the fly with a geardrive case. it's more importantly the hubs you have. auto hubs need to have the truck stopped to engage.
Old Nov 20, 2005 | 10:51 AM
JamesD's Avatar
Same here. My old 87 with stick was shift on the fly. Worked great but every now and then it would get stuck just like he said. Sometimes I had to rock it back in reverse then forward again to get it out of 4Hi. Not all them time, just once in awhile.
James
Jody
Mar 11, 2010 10:08 AM
JohnRaven
Dec 22, 2008 10:08 PM
90-4runnerv6
Jul 15, 2008 07:13 PM
Bill
Dec 5, 2006 08:30 PM
