PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. valve cover gasket
  2. Toyota Truck & Motorcycles
  3. URD Fuel Kit Upgrade Installation
  4. Please help...
  5. Toyota Has Got To Be Kidding!
  6. Center Console Arm Rest
  7. Any Ideas?
  8. Stolen 84 PU in Seattle area: REWARD
  9. what causes O2 senosors to go out?
  10. 4 vs 6
  11. water/moisture getting inside my 4Runner
  12. What to do about gauges... Defi-Link?
  13. Changing a clutch is a PITA!
  14. Back pressure
  15. tire inflator/deflator
  16. wheres the torsion bar?
  17. SilverStars just installed
  18. Question about 4 and 5 speed trannys
  19. Wouldnt you rather go to a truck shop?
  20. Show us you’re before and after pictures!
  21. my reverse light/warning light project
  22. how to get cam sprockets off on v6?
  23. 86 runner, witch motor???
  24. 89-95 Toyota truck front pads 4 sale
  25. Converting Bench Seat to Bucket Seats
  26. Weird knocking sound
  27. alternator or battery problem?
  28. IFS 7.5'' Diff Thrust washer Part #?
  29. Proper soldering techniques
  30. Replacing my dead 3.0
  31. LOw IDLE
  32. Anyone still have the pics of bent-up rear bumper?
  33. CEL on and off
  34. best carb/intake/cam combo...?
  35. better gas milage with fuel mods????
  36. The infamous Tundra TRD coil lift on Tacomas
  37. pic of relocated 02 sensor
  38. 3rd Gen auto tranny brake lockout question
  39. heater lights on a gen1.
  40. Pitman & Idler Arm
  41. waterboy!
  42. 97's rear end is to low
  43. replacing piston rings myself reuse pistons and rods?
  44. how many times have you use 4wd on road this season?
  45. Who wants to see a decent 2nd Gen Burnout Vid?
  46. Goodby old friend
  47. Changing Manual Trans Fluid on a 2003 Tacoma 2.4?
  48. Back up lights don't work...help please!!!!
  49. Differences between JDM Hiluxes and U.S. versions....Are there any?
  50. Best Offroad mag?
  51. Tacoma Question
  52. Will this be easy
  53. Will this be stupid?
  54. How should I do this
  55. FYI: Just noticed an elocker w/ 4.10s on Ebay
  56. 3.0 alternator brush rebuild kits? such a thing?
  57. Very Impressive DYNO Run...
  58. Transfer case leaking problem...
  59. Question for you 22R experts.
  60. Difference in carburetors?
  61. Cleaning the engine after she gets dirty
  62. any one got one of these for a 3rd gen?
  63. 2.75" Rubber Intake Tubing?
  64. 3rd gen rear bearings
  65. Which is it?
  66. Will this motor fit the 88 4runner?
  67. Frame Question
  68. 3rd Gen Engine Swap? Can't Find.
  69. Loose Shifter, can it be fixed easily?
  70. Will My Gas Mileage Really Go Down???
  71. Hood scoop?
  72. Installed Clear Bumper Lenses...
  73. Cut exhaust?
  74. my crank bolt fell out!
  75. 2000 4Runner blown, need suggestions
  76. Swapping Speedometers????
  77. Can rotors warp before brakes wear out? And yes, some vibration is back at 60+mph....
  78. this sucks
  79. Could someone please explain what Toyota was thinking??? (Defrost)
  80. Updated pics of the 4runner
  81. custom crossover pipe ideas?
  82. Problems running V6 on open headers?
  83. Need help from Okies.
  84. My new 01 Sport
  85. 22r carb swap ????
  86. Were Tacoma 2WD made with V6?
  87. spark plug leads
  88. H4 Conversion Headlights?
  89. What does the ignitor do exactly?
  90. Used 4WD for the 1st time...
  91. Mud/water in my brakes
  92. question on keyless entry for a 98 4 runner
  93. Lets play guess the problem!
  94. When a good MAF goes bad: how to test?
  95. I can't win!!! Broke my truck!
  96. carb adjustment
  97. 87' EGR ?'s
  98. Automatic Tranny Problems - need a 5 speed
  99. Driveshaft U-joints. How to tell if bad?
  100. Odd Grinding Noise
  101. Front hub seals/gaskets?
  102. 22r holley carb HELP!!!
  103. Anyone catch this??
  104. '05 Tacoma on KCAL 9
  105. Whats it worth?
  106. would this carburetor work for me?
  107. When will it stop?!
  108. IFS steering box help
  109. Lexus IS300 HID conversion(sealed beam)
  110. LC Engineering Turbo Kit?
  111. 22RE Throttle Body Size?
  112. my pics
  113. Rear window help needed
  114. where can i find these mirrors? (pics)
  115. Light flickers
  116. Plugs for my boosted 3.4L 5VZ
  117. radiator problem
  118. Throttle Cable Help
  119. TJM turn signals, repeat question
  120. G52
  121. OME decal/sticker
  122. 3rd Gen - What size tires should I choose??
  123. Weird sound from rear when downshifting??
  124. Have a question for those who own both 1st and 2nd gen runners.
  125. 2nd gen chrome rear bumper, whats it worth?
  126. Need some help with engine.
  127. maint light
  128. steering columns ?'s
  129. New Tires and Wheels, finally...
  130. Exhaust Question
  131. 94 pick-up head gasket
  132. Whats this switch called?
  133. Grill Gaurd Pictures!
  134. Thermostat Cover Sensor
  135. Factory Manual locking hubs?
  136. If I may ask? HELP!
  137. factory keyless entry on a 93?
  138. Supra swap questions
  139. 2nd Gen Parking Brake Interior Cable
  140. torque specs?!
  141. BJ Spacers installation
  142. Transmission Fluid
  143. 3.0 or 3.4 V6 ?
  144. TJM Turn signal replacement
  145. Today when I was on top of a glacier..
  146. Took some junk off of my 4Runner during Christmas time (PICS)
  147. antenna question--not motor
  148. what tires to buy?
  149. backup sensor for the 4Runner, help please ?
  150. Inner CV boots have a small leak
  151. cambered wheels after lift
  152. 85 tranny in a 88 4Runner
  153. My tranny
  154. Will this muffler work well on my truck?
  155. Where to ocate my tps.
  156. 4 Runner...a Tax Write Off?
  157. Checking Tranny Fluid (4RUNNER)
  158. anyone ID this grill?
  159. new 3rd member
  160. Why does the 4Runner dominate this board?
  161. Tire Size and ABS
  162. Lets see your videos!
  163. Traction bars?
  164. Looking at an 85 4runner this weekend...
  165. i need help
  166. Pics of my old truck!
  167. Anyone changed their rear main seal?
  168. What brush guard is this?
  169. IFS Hub pulling and Hendrix Motorsports puller HELP WTF?!!!!!
  170. 3.0 Turbo DIESEL 4Runner 2002
  171. I'm getting Free Sirrus Radio!
  172. Plug temps with S/C?
  173. 3.0 Owners Beware
  174. Sahara Pics Please... Should I paint....
  175. Part # Help Please
  176. ARB Bullbar on 04 Tacoma Question
  177. *2005 LA AUTO SHOW*-serious dialup warning
  178. Wil 32x11.50 Tires fit?
  179. looking for pics of 2.5" lifted 3rd gen runners
  180. Throttle Body
  181. amsoil dealer
  182. newer used alternator in 82 4x4
  183. New clutch prices????
  184. 3rd Gen Front Differential Removal
  185. Oil Pressure on start up
  186. Question on Tacoma extra cab rear seat
  187. My first: "Look what the UPS guy dropped off today" post
  188. Finally!! Pictures of the Tacoma and the 4Runner
  189. help please
  190. help with lift
  191. Lets see your STUCK TRUCK!
  192. Toyota Unichip
  193. It is done!
  194. starting issues
  195. Electrical help
  196. Damaged CAT
  197. Criminal Dealers!!!! Starter probs opinions needed
  198. Need help installing alarm
  199. Tire recommendations...
  200. quick 3.0 v6 help please
  201. Front stab links broken
  202. Tjm turn signals as fog lights?
  203. Whose 4Runner pic is this guy using at eBay?
  204. Alternative to Rear Window on 1st Gen
  205. cold weather radiator thingy muh-bobs
  206. power window install
  207. RHD 4Runner Mods
  208. Help with 315's on 3rd Gen...
  209. Valve body upgrade
  210. Which Doors Will Fit My 1st Gen?
  211. Judge limits off-roading to protect desert tortoise
  212. 95 3.0L exhaust and headers
  213. really high oil pressure at idle
  214. Bentup Bumpers
  215. Need help with a supercharger question
  216. hard to turn steering
  217. Help! My power antenna is on its last limb...
  218. Another stolen truck (recovered)
  219. Cowl Hood?
  220. Setting timing on 3vze
  221. Looking for a post
  222. Supercharger for 3.4 V6
  223. Cherry pop 100K
  224. 02 Taco 6" lift w/ 35's????
  225. ECU years
  226. beating the bush for the last time
  227. Considering trading Nissan for Tacoma
  228. 4WD problem
  229. good deal on arb bullbar
  230. Annoying noise from the engine bay
  231. Aftermarket front bumper
  232. where can I get parts for my crash *pics*
  233. Steering Stabilizers...
  234. Buying advice !!!
  235. Do 3rd Gens Have A Lot Cargo Room? *Pics*
  236. Can aftermarket shocks improve ride comfort?
  237. Stooping AXLE WRAP with Dual shocks?...
  238. Ping??
  239. Official : "ITS ALIVE ! ! " thread
  240. Rear Wiper issue.
  241. 3rd Gen 4runner 275/75 KO on stock rims
  242. check this out, an 85 with a 98 front end!
  243. What Is It?
  244. Plush, comfy 4 Runner seats in a Tacoma -ahhh
  245. Heater/AC Fan Whine on 03 Runner
  246. frozen rear window
  247. '04 intake mods?
  248. Big replacement fuel tank
  249. Supra swap Q - 5m motors?
  250. Gurgling sound after flushing
