Question about 4 and 5 speed trannys
Old Jan 11, 2005 | 04:35 PM
lil thumper's Avatar
I'm curious, and also did a search , but to no avail. I am doing a swap for my buddy from a 5 speed to a 4 speed transmision on an 83 Toyota truck, 22r, no mods to speak of. Now before he goes out and buys the 4 pseed transmission, I was wondering if the W56 shift handle will fit the 4 speed transmission seeing as the transmission he can get has no shift handle?
Thank you for any help in advance.
-k
Old Jan 11, 2005 | 04:44 PM
Chapman88SR5's Avatar
sry i cant help u but i was wondering whats the advantage to this?
Old Jan 11, 2005 | 04:51 PM
No advantage to speak of, more of a money situation for him. It's his only vehicle to drive, the W56 is shot and needs a rebuild, says it's going to take about a week to rebuild( his friends shop) and $150.00. He uses this truck daily as he owns a log cutting buisness. He can get the 4 speed for $100.00, and he can be up and running in no time.
-k
Old Jan 11, 2005 | 05:57 PM
Glenn's Avatar
If it doesn't fit, an aftermarket one shouldn't be too expensive.
Old Jan 11, 2005 | 06:02 PM
Yeah, I agree, He's just on a truncated timetable and we are just shadetreeing it until he gets another W56.
-keith
Old Jan 11, 2005 | 07:48 PM
kyle_22r's Avatar
to my knowledge there's no aftermarket shifters really out there for our toyota transmissions. hurst makes them for newer jeeps though, which use the AX5 and AX15 trannies(essentially a W56 and R150F respectively) so that could be a point of interest.
is the truck 2wd or 4wd? is the transmission a top loader(L45) or a side loader(L43)? might be able to help then.
Old Jan 11, 2005 | 08:09 PM
kyle,
the truck is a 4wd and the transmission that is currently in it is a top loader, I hope that helps and thank you for the response.
-k
Old Jan 11, 2005 | 08:49 PM
kyle_22r's Avatar
alright, so is the 4 speed a top loader with a non-removable iron bellhousing as well? if so, you're in luck, the sticks will swap. in fact, the trannies are EXACTLY the same except for the 4 speed is missing a 5th gear, and if it's an '83 tranny it'll have a slightly bigger input beraing
Old Jan 12, 2005 | 03:16 PM
kyle,
Thanks for the reply, that's exactly what I was looking for. I really appreciate it.
This board rocks . Thanks again guys.
-k
Old Nov 13, 2011 | 08:28 AM
crippenyota's Avatar
hello got a 83 sr5 pickup trying to swap in a trany from a 86 i beleive. Everything looks like its going to bolt up except drivelines and crossmember are off by a few inches any ideas from someone who has done a similar tranny swap?, and i have to either rebuild the bearing on the other side of the retainer plate or take it to a shop any ideas on that too?
BeMiceElf
Oct 10, 2015 09:40 PM
coffey50
Jul 28, 2015 10:55 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Iceman4193
Jul 15, 2015 04:48 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
