Lets play guess the problem!
Old Jan 10, 2005 | 04:58 AM
PirateFins's Avatar
I you can please click on the link to view pictures of my #2 sparkplug and try and diagnose what is causing it to look like this. Plug has 10k on it and the plug I took out and replaced looked the same way. All other plugs except #3 look like normal burning plugs. See why #3 is the exception HERE
Fixed
Link to plug pics HERE
Old Jan 10, 2005 | 08:20 AM
roger's Avatar
Plug link no worky, says I need a logon
Old Jan 10, 2005 | 11:02 AM
MTL_4runner's Avatar
Next time you need to put a link from the community page to the photo.
Here is the link to the album for the rest of us:
http://community.webshots.com/album/248362596sjBfPr
Old Jan 10, 2005 | 11:10 AM
Someone correct me if I am wrong but that looks like the beginning of coolant getting into the cylinder. I would replace both headgaskets again (since you are already doing one from the snapped plug) and that should take care of any issues in that cylinder. Also soak the intake valves in top end cleaner overnight (but do not remove them) and then pour that out and use some carb cleaner to follow up and remove all the carbon that was there (if there is much at all). Should run better all around after doing so.
Old Jan 10, 2005 | 02:48 PM
PirateFins's Avatar
I fixed the link to the pics forgot that I needed to do that.
I looked at a bunch of pics on the net today and I think it was oil getting into the cyl. I did the dollar bill trick at the tail pipe and it was getting sucked in.
I have the 22RE so only one head to take off and it is done. The #2 exhaust valve has the same discoloration and burnt on stuff. So the head is out and there isn't anything obviously wrong with the gasket, but it will be changed now, along with the timming chain and front main seal.
Old Jan 10, 2005 | 04:37 PM
terryjmatthew's Avatar
I would also guess coolant for what its worth.
Old Jan 29, 2005 | 06:39 AM
PirateFins's Avatar
It turned out to be oil leaking past the valve seals. The #2 exhaust alve seal was missing the top and oil was pouring into the cylinder.
chukarhunt
Dec 8, 2019 11:39 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
v_man
Jul 23, 2015 04:01 PM
Hamonacracker
Jul 17, 2015 08:33 AM
