Fan Problems/Seatbelt retractors
Old Jan 28, 2005 | 09:13 PM
owenwalk's Avatar
Has anyone had this problem: The dash fan for the heater/ac only works on III and HI. I replaced the switch with one I know works and it does the same thing. What do I check now?
Also, 1st gen front seatbelt retractors must be made by chevy. They do a lousy job of retracting. I took them apart and tightened the spring and they still work half assed. Do later gen retractors hold up any better and do they swap in?
Old Jan 29, 2005 | 04:12 AM
seaflea's Avatar
There is a rheostat (i think thats what it is called) that is on the passenger side by the fan motor. Its where the wires plug into I think. it needs to be replaced if you want to have the first 2 speeds back. It costs around $15.
The first gen seatbelt retractors are not very good. I'm not sure if a newer one would swap out or not.
Old Jan 29, 2005 | 07:16 AM
Babypig's Avatar
the seatbelt retreactor suck in the first two gens for sure. 90-91 seatbelts are different than 92-95 for sure. Found out the hard way. First gen i don't know about but early 2nd gen belts would be the way to go if you couldn't find a good set of 1st gens at a wreckers. There is also a spring tension adjustment that can be done to the belt retractor online somewhere. Try a google search and see what comes up.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Aaron Logan
Sep 3, 2015 08:08 AM
