When will it stop?!
Old Jan 9, 2005 | 07:17 PM
Yota4runner's Avatar
When will it stop?!
Okay so about amonth ago I came to this board with a problem with my alternator/battery not holding a charge. Well I replaced the alternator and that seemed to make everything peachy....until tonight. Both the Charge ligh and Brake light came on. I lost a bit of power (just enough to make the lights dim and heater slow down) But my radio still worked. The truck will start, the alternator is Brand new like not even 3 weeks old.
What do you guys think? I have thought about replacing the belts. any ideas?
Old Jan 9, 2005 | 10:45 PM
netgodsrdn2's Avatar
Double check your connections to the alternator. And check that the belt is tight. If they are all tight. I think I'd have the alternator tested to verify that it is charging.
Ron
Old Jan 9, 2005 | 11:51 PM
bike4miles's Avatar
Check your ground on the alternator. I forgot to ancor down my ground and the exact same thing happend to me.
Old Jan 10, 2005 | 12:20 AM
Ryan1's Avatar
what they said and your voltage regulator
Ryan
Old Jan 10, 2005 | 02:36 AM
gwhayduke's Avatar
Did you use a Toy alternator or a rebuilt one from a retail auto parts store? Several of us here have had defective "rebuilt" alternators.
Old Jan 10, 2005 | 02:45 AM
jimbo74's Avatar
im in the same boat with thinking wise about that... as soon as i read your post, you mentioned NEW alternator not even 3 weeks old, I immediately thought, bad NEW alternator, its very common with any of the reman alternaotrs that are sold through autochain stores to be new/reman and still be defective...
Old Jan 10, 2005 | 08:06 AM
I have no idea if it was rebuilt or not, to be honest. I bought it from Crappy tire. It was made by Champion. So I'm not sure. I'll look into it. I'm gonna run the volt test today. I replaced the wires and such on the back last night as one corroded off right in my hand.
We'll see what happens I guess.
Old Jan 10, 2005 | 08:12 AM
roger's Avatar
See if there's a warranty on the alt. Many autoparts stores will replace it for free. I went through 3 reman'd alts once before I got a good one.
Otherwise, perhaps you have a slow current draw somewhere? Could be a royal PITA to track that down....
Old Jan 10, 2005 | 08:38 AM
phorunninduke's Avatar
voltage regulator
make sure the connections are good
Old Jan 10, 2005 | 09:20 AM
Would my voltage regulator not be built right into my alternator?
Old Jan 10, 2005 | 12:45 PM
Okay so heres the latest update on this saga.
I changed the battery out, because it seemed I wasn't getting any power from it. I had a spare and dropped it in, and the Truck fired right up (and has done so 4 or 5 times now) So then I pulled out the Multimeter and slapped it on the Alternator and and it is outputting about 17V so thats obviously not the problem. Then I went to the battery and put it on it, and its only reading about 12 or so. Which brings me to my conclusion that I have a problem somewhere in the charging circuit.
Now, here is my dilema.I have no idea where to begin, anyone have any ideas? I have enough power at the moment to start the truck and it runs great. I just don't have any day time running lights, my wipers and heater are a tad sluggish. Other then that though Its all good. (Aside from my stupid dash lights being on) any ideas?
Old Jan 10, 2005 | 04:05 PM
Nobody has any ideas? I'm at a standstill at the moment
Old Jan 10, 2005 | 04:10 PM
superjoe83's Avatar
17 volts is a bit high, check your charge/alt fuse, it may be blown, if not, then your charge wire probably has a break in it
Old Jan 14, 2005 | 02:19 PM
So it turns out I had a few things wrong. One was a wire on the back of the alternator was repaired at some point and wasnt done properly. Two was that a wire running into the cab that connects to god knows what popped an ignition fuse.(at least thats what I think he said ) And the alternator somehow fried itself. Took it back to Canadian Tire, they gave me a new one for nothing.
I had it installed and fixed by the local Import Car shop. My dad uses them they do good work. So hears to hoping it will now behave itself.
TheBFA
Feb 15, 2020 06:55 AM
Alexdosdall
Dec 10, 2017 05:48 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
gentry
Sep 28, 2015 06:16 AM
