cambered wheels after lift
Old Jan 8, 2005 | 09:19 AM
abtbassboy's Avatar
i lifted my runner 2.5 inches with spacers and now the front two wheels camber in at the bottom... what can i do to get these straight again? is there any extension i can get for something, any help would be awesome. thank you
Old Jan 8, 2005 | 09:32 AM
mt_goat's Avatar
Adjust your LCAs out or adjust the UCAs in or some of both.
Old Jan 8, 2005 | 09:39 AM
mt_goat's Avatar
I just noticed you are in OKC. Jackie Cooper on NW expressway is a good place to get a 4x4 alignment. That is where 4WPW sends their lifted trucks for alignments. They have those new 3D laser machines there. They aligned mine after I put my ball joint spacers in and got everything within Toyota specs.
Old Jan 10, 2005 | 08:49 PM
abtbassboy's Avatar
hey thank you man! i will try to see if it all works..
Old Jan 10, 2005 | 09:32 PM
jimbo74's Avatar
yup the camber needs adjustment.. if you can see they have positvie camber, im willing to bet you have a minimum of 2* positive camber and that can lead to messing up the tires in only a couple thousand miles.....
Old Jan 10, 2005 | 10:02 PM
slyang1012's Avatar
by "2".. do u mean 2 degrees? cus i just got new tires and they adjusted the camber and they said that it is ok that its 2 degrees off. errr crap!
Old Jan 10, 2005 | 10:17 PM
jimbo74's Avatar
well 2 degrees in relation to 0* being the actual spec...... 4-5* actually looks pretty close to this \ /
Old Jan 14, 2005 | 09:54 AM
abtbassboy's Avatar
if i cant adjust is there a camber kit? that will extend the stressed pieces? i really have no clue about any of this....and haven't been able to talk to my dad about it yet.
just need as much help as i can....
Old Jan 14, 2005 | 10:06 AM
mt_goat's Avatar
No camber kits for trucks that I know of, only sports cars. You should have enough adjustment avaliable with your LCA adjustment cams to compensate for the spacers. I did anyway. I hear the stock UCAs also have a cam adjustment to adjust the camber, so between those two you shouldn't have any problems with adjustment. But that is all something you are going to want the alignment tech to do for you anyway, it would be part of the alignment. The only reason I would adjust them myself would be to get it close so the drive to the alignment shop wouldn't be so scary.
Old Jan 15, 2005 | 12:32 AM
jimbo74's Avatar
on most vehicles where there is uca adjustment points there may be no kits available, however if the cam bolts that secure the uca to the frame are already maxxed out of adjustment, some places can modify them to get them within specs... some vehicles can use a method of slotting the holes and some use aftermarket bolts with differnt washer plates
Old Jan 16, 2005 | 10:56 PM
abtbassboy's Avatar
got my cams adjusted and aligned today.. thank you for all your help
jackie cooper is awesome only costed 69.99
Old Jan 17, 2005 | 06:18 AM
mt_goat's Avatar
Good, they also have the best tire balancing in town (Hunter Road Force balancer). That's where I bought my 33" BFG Mud-T. Sometimes it takes a couple times for the tech to get it right though. Plan on it taking about 1-2 hours to get 4 tires balanced.
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
