Question for you 22R experts.
Old Jan 10, 2005 | 08:02 PM
techhead's Avatar
After puting a head gasket on a 22R I heard what I thought was a knocking noise so I pulled the engine and put new rod bearings in it. After I put the new rod bearings in it is still making a knocking-chattering sound however it does not do it constanty. When you turn it off it makes the chattering sound (like compressed air comming out of the side) the last few revolutions of the motor shutting down. When the truck is making the noise it still runs good other than the raising hell sound. The truck has plenty of fire and good fuel. Any comments or suggestions would be appreciated.
What is wrong with this engine?
Thanks
Old Jan 10, 2005 | 08:10 PM
jimbo74's Avatar
sounds like a vacuum problem or incorrect timing, might also be the fuel cut solenoid
Old Jan 10, 2005 | 08:12 PM
techhead's Avatar
If it was a timing issue or vacuum prob why would it quit at times?
Fuel cut solenoid?
Old Jan 10, 2005 | 08:14 PM
jimbo74's Avatar
there is a solenoid that allows fuel cutoff at certain times.... also being a carb, they are really sensitive to weather changes.. whenever the weather goes from clear and sunny to rainy, or to cold, i have to do a little tinkering to get it to work better....
Old Jan 10, 2005 | 08:20 PM
bike4miles's Avatar
Any word on how old the timeing chain is?
Old Jan 10, 2005 | 08:21 PM
techhead's Avatar
It's brand spankin new. When I put the head gasket on it I changed the timing chain.
Old Jan 10, 2005 | 08:22 PM
jimbo74's Avatar
you also changed the guides also correct?
Old Jan 10, 2005 | 08:26 PM
techhead's Avatar
Yep brand new.
Old Jan 10, 2005 | 08:35 PM
jimbo74's Avatar
i am still leaning towards incorrect idle speed, or mixture adjustment, bad fuel cut solenoid, or a vacuum leak... when my truck was 180* off in timing after i did my head works, it would almost start but then make a psssshhhhh sound after i let of the starter..... found it to be part of the vacuum system making the noise..... but i flipped the dist 180* and all was fine....
Old Jan 10, 2005 | 08:39 PM
techhead's Avatar
The truck is idling higher than it did.
Old Jan 10, 2005 | 08:41 PM
jimbo74's Avatar
have you checked your vacuum lines and properly set timing and idle speed lately?
Old Jan 10, 2005 | 08:45 PM
techhead's Avatar
I put everything back where I thought it originally went. I think the timing is right but I wouldn't bet the farm. The truck is rasing hell knocking now but it didn't do this all day. This knocking-heavy chattering comes and goes so I don't understand why it would run good at times if the timing were off?
colasurdo
Jan 11, 2026 08:10 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
cars-guy
Jul 11, 2015 07:51 PM
