starting issues
Old Jan 6, 2005 | 01:49 PM
mp101v's Avatar
starting issues
I have a 93 truck. 22re, 5 spd tranny. Sometimes I try to start it, and the starter won't even click. I stop and try again, then it treis to start, but won't turn over. Sometimes it only clicks. Sometimes it turns over, but roughly, then I give it gas and it is fine. Any Ideas?
Old Jan 6, 2005 | 02:12 PM
Adam F's Avatar
Clean up your battery terminals, and your starter to battery connections. Then have your battery load tested.
Old Jan 6, 2005 | 02:27 PM
SoCal4Running's Avatar
Dont skip over the relay wire either, recently had the same problem with my 4runner so I swapped starter with a know good one that I have figuring it was the contacts, replace the battery, main power cable, checked all the grounds. Of course the last thing I check is the stupid relay wire at the starter , it wasnt making a good tight contact and would do the intermittent starting "click". Crimped the conector alittle and fixed it.
Old Jan 8, 2005 | 08:30 AM
mp101v's Avatar
I'll give it a try, thanks.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
