PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 [153] 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Can I fit a 99+ Grill in my 97?
  2. Boring throttle body???
  3. Trim packers/extension for 5spd lift?
  4. Tire question? Need help
  5. Another Dealership Screw-Up Vent
  6. Help!!!!!!
  7. Dropping oil pan
  8. Need Rear Axel Inner and Outer Seal info.
  9. What is torque spec on diff drop M14x80 bolts?
  10. New bumper and shoe's installed.
  11. Aftermarket Spoiler for an 03 or 04 4 runner?
  12. Recent 03 TSB's
  13. Windshield removal tools
  14. CB problems...
  15. Some 2nd gen 4Runner questions....
  16. Full-size spare or not?
  17. Transmission problem??????
  18. 4 runner info?? Do you have any good pages, or info offhand i can use??
  19. I am one dirty kid
  20. how to install custom temp and oil press. gauges
  21. EGR Dustguard (deflector)
  22. Easy pcv replaced on 3vze
  23. How do I find a 4Runner w/3rd row??!
  24. ECT mod question
  25. how do i take off dash board
  26. Price to get Clutch done, and Exedy kit?
  27. IFS, to solid Question
  28. diff drop for 2 inches of lift?
  29. 2.7 exhaust man. crack
  30. Strange Stall
  31. in and out overdrive
  32. IPT Valve Body Installed!
  33. Opinions on my hood-mounted air horns...
  34. New shocks needed with lift??
  35. Toyota Axle q
  36. Roger Brown body lift problems???
  37. Dexron II or III
  38. Questions about road trip gear
  39. FS '85 EFI 4Runner Grand Junction, CO $4250
  40. Panasonic stereo questions...
  41. indiglo gauges
  42. cleaning throttle body
  43. Los Angeles Wrenchathon - Sunday 5/23
  44. Painting the ARB
  45. Commuter Car
  46. mounting rearview onto glass
  47. Overheating mystery...
  48. Finally, a pic of my Surf's IFS
  49. new CV boots
  50. Timing Chain-Thanks To U All
  51. twin stick on a '97 4runner
  52. T-case chain stretch?
  53. Does your exhaust....
  54. I want a supercharger
  55. Questions about Tires and Gears
  56. Time for new wheels! Help me choose!
  57. Slight squeek when in 4x4 and starting to roll
  58. Gears question: What is Axle Spline and Ring Gear?
  59. 1 Step forward. 2 Steps back
  60. rainy day probmems
  61. Tsb El010
  62. What effects do lifts make on 85-89 4 runners??
  63. Some Suspension Questions
  64. power steering problems......please help asap.
  65. Custom interior pics
  66. Hood Scoop: Ebay
  67. need last minute advice on suspension plans
  68. tacoma clutch, need advice.
  69. Ideas Anyone?
  70. Replacing brake pads
  71. Need help with the rear hatch release....car is apart now and the rain is coming!
  72. Tires question, searched but no answer found
  73. Where can I find torque specs?
  74. Will this look funny?
  75. Not enough back pressure,tail pipe question
  76. Quick Question Regarding Oil Change??? It is not a help question!
  77. This weekends project *pics*
  78. Weather Stripping
  79. CB? Oh yeah!
  80. Will it void warranty?
  81. Will 180* thermostat help with pinging
  82. Tune Up for a 96 Toyota 4-Runner
  83. Did they even make?
  84. Results from Auto-Rx
  85. 3.4L Supercharged - which injectors?
  86. Has anybody added airco to a 3rd gen 4runner
  87. Engine's OUT (hourly update continues)
  88. Not sure what this part is, but it makes a noise. (2nd gen)
  89. Toyota swap meet. 12 June Golden, CO
  90. what the HECK is that other handle??
  91. Scary pull under hard braking
  92. new member
  93. Where's the fuel filter?
  94. 2nd Generation Rear Recovery Points
  95. Steering play from 1st gen steering box
  96. Issues separating torque converte on seized engine
  97. torsion bars require manual hubs?
  98. squeaking over bumps
  99. My Friends 81' Yota Rolled Off A Cliff (Video)
  100. Wheel bearing question...
  101. Thermalweld Head Gasket Fix
  102. Western WA - need your Toyota dealer comments
  103. 3rd Gen. Manik...help
  104. i got in an accident
  105. URD is in AZ!!!
  106. How to Wire a 700Watt power inverter
  107. torque values
  108. 4th Gen manual hubs
  109. I have a request for everyone here...
  110. Anyone black powder coat OEM wheels
  111. Testing out my new shoes
  112. Clutch Compatability Question
  113. Want a 4runner, but which one??
  114. TJM bumpers
  115. How do you mount your Hi-Lift?
  116. Wheel questions
  117. Little help with changing all the oils
  118. How many mile's do you get?!
  119. Side sliding window question
  120. Timing belt-again
  121. Front Diff...Stupid question
  122. Anyone in Colorado Springs
  123. 1st Gen rear window problems
  124. 15" vs 16"
  125. 2nd Gen Wiring
  126. Emergency Brake Cable Breakage
  127. safety inspection...lower ball joints ??
  128. Transmission fluid through the radiator?!
  129. Pic of the Speedometer Problem I'm Dealing With
  130. 2nd Gen Alpine Stereo Questions
  131. One Dead 3.0
  132. Overheating Mystery??
  133. my power windows
  134. My First Toy
  135. New Rear Tire Carrier (pics)
  136. Replacement panel vendor
  137. Not new to the board but finally registered
  138. Not new to the board but finally registered
  139. friggin A these things are big...
  140. electrical problems
  141. Diesel in a runner???
  142. Working on an 85 camry
  143. theft = change
  144. Dual Magna-Flow Exhaust on my 99 4runner (pic inside)
  145. '94 4-runner engine swap
  146. possible 3rz-fe swap? need help
  147. Hid's ??
  148. Clutch question...
  149. Calling All So Cal Gearheads
  150. Hi-lift: 48" or 60"? Your thoughts?
  151. Looks like trouble . . .
  152. JDM clinometer for sale
  153. Another Balljoint spacer question
  154. best place to buy AMSOIL filter?
  155. will these tire rub?
  156. pcv valve on a 3vze??
  157. EGR Advice
  158. +99 Center Console Complete [Pics]
  159. Sagging Rear End
  160. Cheapest place to find tires?
  161. Website updated, Feedback???
  162. Toyota Salvage Yards?
  163. ATTN: ALL OFFROADERS!!! Bureau of Land Management Finds Pipe Bomb on Gate.
  164. Ground clearance - Tacoma 4X4 vs 4Runner
  165. warn winches $ q
  166. Tire wear & auto locker question
  167. substitute for amsoil filter oil???????
  168. Toyota Certified Vehicles
  169. MY A/C is too cold!But nice!
  170. Bragging rights: I beat a Jeep TJ
  171. Where can I get some low profile bumpstops?
  172. Any shock recomendations for rear coil spring lift?
  173. Is better on-road handling possible?
  174. Will 31x10.5R15's fit on a stock '02 4x4
  175. Cruise Control Issues on 01 Taco
  176. Finally!!!
  177. 2001 4Runner Disable DRL - High Beam Indicator
  178. From a 4runner to tacoma??
  179. Locker avail <2000, and heated seats avail >2001 (4Runners)??
  180. Tacoma with factory locker?
  181. Labor for some work needed - how much should I spend?
  182. best 2.7L exhaust
  183. Shorten the antenna?
  184. Jacob's or Plasma?
  185. adding a tranny cooler
  186. rear anit lock light
  187. Maf Air Sucking Noise
  188. tranny for 83 fit 81
  189. 2005 RX 400h
  190. Cornfed plus OME shocks
  191. FSM's-wtf ?
  192. fan shroud??
  193. Which intake mod??
  194. Mother#$4$**n Timing Chain
  195. auto tranny rad to manual rad
  196. clutch replacement
  197. i smell fuel, why?
  198. Will 2nd gen wheels fit my taco?
  199. Why not Diesel?
  200. Problem with highbeam indicator on dash
  201. Lifted!
  202. What's wrong with my limiting straps?
  203. how much did you get your tacoma for?
  204. Spacer or OME??
  205. Best way to remove old wax residue from plastic?
  206. 22re vs. newer 2.7L 4 cyl ???
  207. Oil pressure gauge question...
  208. Vents
  209. Se4rj @ Tellico
  210. Tranny Shot Need Advise
  211. First 22RE rebuild, I got some Qs
  212. Oil changes 5-10K on 22r!?!?!?!?
  213. Locking a 2wd?
  214. Am I Crazy?
  215. Question for those who have recalibrated their speedometers themselves...
  216. Does anyone know what this box thing is?
  217. Power Steering?
  218. Is it possible to move an aftermarket radio to where the cig lighter/ash tray is loca
  219. Oil filter empty on 22re?
  220. Rear diff. leak?
  221. Where to get a 170* thermostat?
  222. question about replacing upper a-arms
  223. #3 Piston not working when Enigine is cold
  224. Anybody Have Solar Power?
  225. intake and exhaust mods ..what benefits??
  226. Tranny Temp Gauge ?'s
  227. Anyone ordered a Gauge Pod from these guys??
  228. 2003 - Maintenance light
  229. OME 3rd generation lift
  230. Stero Upgrade
  231. quick keyless remote q
  232. Perf Friction Part #???
  233. just ordered 33s
  234. Separating engine and tranny
  235. Bumper Choosing
  236. Supercharger + deckplate mod question...
  237. Has anyone had problems with Xtreme Off-Road?
  238. Tune up and Maintenance?
  239. Keep Or Sell Stock Rims 91 4runner?
  240. Center Support Bearing and Vibration Question
  241. My new(old) 4Runner
  242. What front lift?
  243. What tires to buy?
  244. I Prewired my '97 4runner for E-locker
  245. What year instrument panel can I use?
  246. 2nd Gen 4Runner grease fitting size
  247. K& N air filter
  248. Tires.... size debate...
  249. grease fittings ?
  250. someone grag this deal
