Why not Diesel?
Old May 11, 2004 | 08:08 PM
terky's Avatar
Why not Diesel?
I was saving up my money to buy a 4.3L chevy but then i was thinking. You can totally submerge a diesel in water as long as it can still breath. No electrical problems to run into. Seems like a better choice for offroad. also if you can get non-taxed diesel its even better.
Now i think i am going to save for a small diesel motor instead. If anybody knows an engine that can fit easily into a 1st gen pickup please let me know.
Thanks
Old May 11, 2004 | 08:09 PM
Scofco's Avatar
Have to be careful with diesels in the winter though.
Old May 11, 2004 | 08:10 PM
terky's Avatar
Just get a block heater and some stuff so the fuel doesnt gel right? I think thats the only problem.
Old May 11, 2004 | 08:13 PM
Scofco's Avatar
Block heater doesn't protect the tank
Old May 11, 2004 | 09:14 PM
SoCal4Running's Avatar
A 4cylinder perkins, John Deer or Cummins would be perfect. Look for them in comercial forklifts and other similar equiptment.
Simple turbo charger and gobs of torque. Some times you do have to use a fuel tank heater but nothing you cant get at a truck yard for $15.00.
If it gets too cold at night you can just let it run.
Old May 11, 2004 | 09:17 PM
terky's Avatar
Thanks man
edit: nuthin on ebay
Old May 11, 2004 | 09:24 PM
Ive often wanted to do the same to my 4runner.
My uncle is a diesel wizard (retired fom Detroit) and showed me a 2-cycle 4-cylinder that reved to 9 thousand rpm, couldnt believe it, sounded like a weed wacker on steriods.
Old May 11, 2004 | 10:12 PM
firemaniac's Avatar
Has anyone actually done a diesel swap? I have been toying with the idea for a short time (the idea of maby 35 mpg, and/or running on vegitable oil is what got me thinking) I am looking for any info (print or net) to do further research
Old May 11, 2004 | 11:36 PM
IGotaQ's Avatar
That is not really what makes a diesel good offroad. They are good cause they make tons of torque at super low rpms. That is the kind of power you want for wheeling.
Old May 12, 2004 | 02:33 AM
foxtrapper's Avatar
Guest
You know Toyota used to have diesels in these trucks right? Find one and install that. They are rare, but fairly cheap, and it's a drop in fit.
Do be aware that particular engine is rather weak, so you've be going slow. But for crawling, that would be fine.
Old May 12, 2004 | 04:50 AM
Highland Runner's Avatar
foxtrapper is correct. Here is a website devoted to Toyota diesels.
http://www.toyotadieselmadness.com/
The old 2L, 2LT, are on par with the 22r as far as power. They do get much better mileage though. There is a company in Atlanta that always has half cuts with diesels in them. I'll try to find the site.
Old May 12, 2004 | 07:28 AM
okidoc's Avatar
http://www.toyotadiesel.com/phpBB2/viewtopic.php?t=128
http://d220208.u30.websitesource.net...13a95488c02023
Highland was right that is a great site. I should be working but I'm just salivating.
The first link above has pics of a recent 22re -> 2L swap.
The second deals w/ 3.0 -> to diesel and other problems.
Thank you Highland.
Old May 12, 2004 | 07:30 AM
Mossback74's Avatar
Try to find a toyota 3.0 Diesel
Old May 12, 2004 | 08:57 AM
Yea, the 1KZ-TE. It's intercooled, has close to 200 HP, and 300 ft/lbs torque. I want to drive to Costa Rico, swap one into mine, then drive home.
Old May 12, 2004 | 09:20 AM
IGotaQ's Avatar
I am not totally familiar with diesel SMOG laws but.. as far as petrol engines go, you can only swap in newer engines to be smog legal.
Also, toyota still makes diesels overseas and in canada. Snag one of these and you'll have awesome power.
Old May 12, 2004 | 11:33 AM
4runner4ever's Avatar
I have had several Hilux diesels and compared to my 7M-GE and previous 3VZE they are far more reliable and have a better torque band which is way better for offroading. It only lacks power if you are in the need for speed.
My old 2LT's (with water cooled intercooler) were good for an easy 90 mph and a top speed of about 100 mph depending on my lift and tyres.
Starting her up in the winter was easy. Just ad 10-15% gas to the diesel or add a fuel heater just before the dieselfilter. The tank is not importend, any gel in the diesel dissolves in the fuel heater.
The reason I quit diesels? A road tax for a diesel of about 3500 $ a year was killing me. So I bought the 4R, SAS'd it, put in a 7M-GE and now I pay about 1400 $ a year. :pat:
Old May 12, 2004 | 11:36 AM
kyle_22r's Avatar
that's in california, other states(like washington) don't care, i think they just do a sniffer test in the emission controlled areas here, if they do it with diesels at all
the L and 2L should bolt right up, then it's all a matter of running your fuel line and wiring the starter/fuel pump/glow plugs
i would love to have a 3L diesel in my truck. 2.8l, basically a bigger 2L
Old May 12, 2004 | 02:46 PM
Babypig's Avatar
Try going to a Hino dealer and see what they have. They make the diesels for toyota so they may have something that will fit.
presto30
Engine Swaps
Dec 10, 2015 12:01 PM
an1mal_69
Sep 8, 2015 09:40 AM
seab1209
Sep 3, 2015 05:41 PM
