Little help with changing all the oils
Old May 13, 2004 | 07:59 PM
Andyman's Avatar
Hi all! I called Toyota today to see how much it would cost to get all the oils changed. Both diffs, tranny etc... Whew.. Really expensive.. I'm going to give it a go on my own. I found Bobs guide, looks good to me! The only question I really have is that I have an automatic tranny... Where do I find drain/fill plugs for it. I read also about the difference between flush and fill, should I be concerned? If I just drain, instead of flushing, should I just change it more often? I have a '97 4runner ltd..
Thanks!
Andy
Old May 13, 2004 | 09:32 PM
Bob_98SR5's Avatar
Andy,
A flush is where they hook your auto tranny to a T-Tech machine and completely flush out all of your old tranny fluid w/ new fluid. You'll need 16 quarts of ATF, not to mention around $120 bucks for the service!
A fill is where they drop your pan, clean off the filter, change the gasket and fill it w/ about 4-5 quarts. So its not a complete flush.
Someone correct me if i'm wrong here or anything that needs to be added/edited.
PM me if you need some Amsoil
Bob
Old May 13, 2004 | 09:54 PM
BajaRunner's Avatar
How often should you change the diff/AT oils?
Old May 14, 2004 | 10:36 AM
Andyman's Avatar
Thanks Bob, one more question for you...
I have the factory locker, does that make any difference to the oil change?
Thanks!
Andy
Old May 15, 2004 | 02:11 PM
User 051420's Avatar
FYI. T-Tech is only $79.99 here with fluids included. They do it at my local 76 Express Lube. I think it's the way to go..you can even bring your own fluid.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
HRDC0R19
Jul 5, 2015 06:43 PM
