PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Rear Axle Rebuild
  2. 99 4Runner "stumbling" at idle and acceleration
  3. has anyone ever run 4.88 gears and 265/75/16s
  4. Tried to engage AWD in snow...indicator still blinking...
  5. Need help tuning URD 7th Injector (Datalogs w/ Innovate LM2 will be posted)
  6. Retrofit JDM Hilux Surf Tire Carrier
  7. interior dash paint question
  8. 1999 3.4 5VZ-FE V6 4runner Manual ECU. Need HELP!
  9. 2002 S-Runner Help
  10. No overdrive - CEL code
  11. 1999 3RZ-FE 2.7 L throttle cable - how much slack in the cable ?
  12. is the scangauge worth it? for mileage monitoring?
  13. Can't find my egr 98 taco v-6
  14. Antenna Mast Replacement Help
  15. Help with 98 and 00 transmissions
  16. 97 4runner rear suspension upper link question
  17. Satoshi Grill Mod
  18. Tokico Shocks
  19. HID Install help
  20. How often do you snap 99 runner front sway bar links?
  21. Different question about using fog's as drl...
  22. Clunk in Tranny when stopping?
  23. 4Runner Bumper Valance on 01 Tacoma
  24. Driver side window
  25. Squealing Alternator Belt
  26. Roof rack leak?
  27. best place to buy center support bearing
  28. 3inch Body Lift Pics
  29. Help decide: remote starter, brakes, tires?
  30. New owner, couple of problems.
  31. Throttle Issue
  32. 4runner starts then stalls when car is warm
  33. 2000 4runner ATF fluid level
  34. 2000 4runner power seats dead
  35. 2004 Tacoma needs a new throttle body?
  36. Headlight question
  37. MAF cleaning
  38. Chriso's 98 4runner build-up thread
  39. No power to windows, door lock, sun roof, rear window
  40. LSD and R&P options
  41. Where is my vacuum/brake check valve?
  42. Question about 99s with trekmasters
  43. Hub bearing for off road? Tacoma
  44. Dash seperating?
  45. Battery dead and can't get out of park
  46. 98 4runner 4cyl-4wd not engaging
  47. Auxilary Fuel tank, 4runner, who has done it?
  48. reverse rake
  49. noises coming from under the dash
  50. 1999 4runner 2.7 L - idling low when warm in drive after mini-header install
  51. fuel injectors
  52. what tires are you runing on your 3rd gen?
  53. ARB locker
  54. VIN# etched into the glass???
  55. SAVAGE OFFROAD front bumper build
  56. Stiff Gas Pedal
  57. Wheel well liners and window locks
  58. Daystar Spacer Q?
  59. Can you bypass fuel pump relays?
  60. Installed 2 FIAMM Freeway Blaster Horns. Before/After Video.
  61. Jet Performance and 3 in. body lift (95.5 Tacoma)
  62. Rear Window Maintenance
  63. Testing a fuel injector
  64. 3.4L Not Turning Over Quickly
  65. Differences between 99 and 00?
  66. Is the radiator support in the '98 4Runner welded in or bolted in?
  67. TB Vacuum Port?
  68. Installed My Bilstein/OME suspension!!!
  69. Rough idle then stalls
  70. Replaced all the drivetrain fluids and...
  71. Can this radiator be glued back together? Casualty of crank pulley "bump start"
  72. Excessive wear on rear tires Help??
  73. Im BAAACKKK!! New 3rd gen..!
  74. Removing exhaust manifold on 2.7 L - how to remove bolt?
  75. Is this a bad estimate? -Stuck in High 4
  76. Haynes Service Manual
  77. 4Runner 4WD Auto Trans Rebuild???
  78. replacing front bearings on 2000 4runner
  79. 1998 Tacoma Problem: Hubs?
  80. New Undercoat 97 4runner
  81. All Pro Rear Lift Leafs
  82. Question about gas mileage. HELP!!
  83. p0325 Knock Sens 1 Circit Malfunction
  84. Any difference between MAF sensor for 96-98 vs 99-02?
  85. 231mm tundra calipers fitting under trd fj wheels???
  86. Great price for Tundra brake conversion...
  87. Valve Shims
  88. Stereo options: aux input or aftermarket?
  89. 09 8" 3rb member to 03 Taco 8" info needed
  90. Reset CPU -> Now CPU is not ready
  91. FuelPump Replacement Procedure
  92. 4wheel drive disengaging
  93. steering wheel hub
  94. Transmission Issue???
  95. Rolled my 96 runner... What to do now?
  96. 97 4Runner 2.7 coolant issuses
  97. 4wd problems
  98. Question concerning aerial (antennae)
  99. Exhaust manifold help
  100. Please help troubleshooting my 99 4runner 3400 V6
  101. Spare tire carrier 265 75R16
  102. Storage solution for 4Runner.
  103. Replacement CV
  104. Replaced clutch, now truck won't start
  105. Automatic 4runner transmission problem
  106. Need Help on Vacuum Line!
  107. 2.7l timing
  108. Intake oil leak
  109. 4wd Problem
  110. Lowering 1999 4runner...
  111. 99 tacoma rear sagging
  112. 99 4runner tailgate window, defroster, wiper inop...
  113. 2000 code PO171 P0171 Cel
  114. Recommended sway bar bushings?
  115. VSS wire - confirm?
  116. Changing Sway Bar Bushings
  117. Now that it's cold, my 03 taco won't stop squealing!
  118. Bogs down
  119. Remote start..
  120. Roof Mounted Light Bar
  121. 3.4 camshaft pulley timing...help!
  122. Extra 6x9 speakers
  123. Will an 02 4Runner Front end fit a 1997 4Runner?
  124. 99 runner died!!
  125. 96 tacoma heater issues
  126. Gas tank + drive shaft!
  127. Help! W/ misfire
  128. Which fr axle?
  129. Cheap lift?
  130. Reverse Glow gauges?
  131. Overheating Problems
  132. Help with fixing rearview mirror base
  133. Water Pump Recomendation and Info
  134. Info on A/C Eliminator Kits
  135. Marlin Crawler Chromo Axle Shaft ABS Capable?
  136. Front lower control arm bushings
  137. Stiff Ride after OME Springs and Shocks
  138. extreme loose steering problems
  139. dual alternator bracket for 4runner?
  140. 3.4 l engine rebuild
  141. 1999 4Runner 4WD tapping noise
  142. my first toy
  143. Starting Problem....
  144. Removing door panels
  145. Anybody use Dexron VI?
  146. 98 4runner limited rear drums to rotors
  147. Valve adjustment intervals 5VZ-FE?
  148. Short somewhere? 10A Gauge fuse popping
  149. Anyone ever put ebay headlight glass in OEM housing?
  150. Wire color of knock sensors in 2000 4R?
  151. 96 toyota 4runner v6 3.4
  152. Has anyone ever bondo'd their hood scoop?
  153. hard tu push clutch pedal
  154. Confused about what 02 sensor to buy for my 1998 4runner sr5 2wd
  155. Airlift onboard air with air shocks
  156. popping out of first gear
  157. Load Capacity of Factory Roof Rack?
  158. Fuel Gauge Problem Affects CEL? 1999 4runner
  159. 3.4 super charger swap..what parts needed?
  160. '04 tacoma shocks
  161. Installed OEM foglights now I have a problem
  162. What is this suppost to do?
  163. Where to find replacement TJM blinkers?
  164. OEM rear wheel bearings?
  165. does a 95 taco. have fuel enrichment or choke??
  166. 96 SR5 4x4 Manual
  167. TMC 1.1 Ping Fix? Does it really work?
  168. is it possible to run the stock shocks with tundra coil?
  169. Dual cat 99 Cali 4Runner
  170. Front end grinding with popping sound
  171. ONLY for guys that have installed SC in a 3rd Gen.
  172. 97 4Runner no start issue...
  173. Funky vibe after S.S 1.2 lift
  174. transmission service questions
  175. 4 cyl vs v6 trans output shaft?
  176. 98 4runner v6 auto won't shift into gear.
  177. clunk/rattle from rear
  178. Got a Toytech lift, and new wheels & tires
  179. 5vzfe performance cam suggestions
  180. Does this cat. converter look bad?
  181. Parts needed for 340f replacement?
  182. NGK equivilant to IK22 spark plug
  183. Questions about wheel stud upgrading!
  184. 4runner Inspector in Wisconsin?
  185. 3RZ AC Belt snapped!!
  186. Help with part numbers and differences in Tundra trd vs non TRD coils and 2wd vs 4wd
  187. 2002 runner bouncy ride help!
  188. Leaking Exhaust manifold gaskets?
  189. very bad shaking/vibrations.
  190. My 4runner was unaffected by the Seafoam treatment
  191. B & M Shifters for 4Runner?
  192. O2 sensor broken stud... help!!!
  193. New breather mod for the clutch aka Stage 1 weight reduction
  194. Wheel Flares for 35" Tires...Where??
  195. crank shaft bound up 98' taco 3.4 litre
  196. First start engine squeak
  197. Noise going in reverse
  198. Installing 7mgte injectors
  199. Need help with part numbers
  200. 2000 4Runner Seat Belt Lock Up
  201. stuck on Cal. CAT and EVAP in Oregon
  202. Frame recall notice
  203. 3rd Gen 4Runner Roll Bar Mod (pics)
  204. Crankshaft pulley bolt COMES OFF!!
  205. 96 4runner front hubs small cap removeable?
  206. hubs wont engage for 4wd
  207. Lubricating (?) Taurus Fan?
  208. 98 runner: clutch pedal occasionally sticks, locks up tranny
  209. Can I tow this much?
  210. Fuel injectors from other yotas flow more?
  211. Lower Control Arm Help!
  212. installed a new fuel filter; made a huge improvement
  213. weird turn signal brake light problem
  214. Tubbing a Tacoma for 35s
  215. 99 Runner automatic trans fluid.... which type?
  216. 97 4runner Limited
  217. ARB Sahara fog turn template?
  218. big brakes and wheel fitment
  219. Bucking misfire awesomeness
  220. Tacoma timing problem
  221. A/C button broke...
  222. 99 tacoma gauge bulbs
  223. Upgrade to HID?
  224. Thoughts on used steering racks..?
  225. Highway instability: Questions
  226. Calble locker conversion?
  227. timing belt question
  228. Voodoo Blue 4Runner?
  229. O2 sensor number 1
  230. Brake line question
  231. antifreeze in oil
  232. 99Runner / Strawberry milkshake / freeze out plug question
  233. Soft pedal after 4runner tundra brake upgrade?
  234. Transmission Question
  235. 4Runner 4WD engage problem
  236. abs fuse link blown
  237. jumped 1999 4runner, big spark, won't start
  238. Front Sway Bar
  239. Drivetrain clicking/ticking noise under load only in 2wd
  240. Front lift opinions needed
  241. grinding noise troubles
  242. 2000 4runner cruise control wiring diagram
  243. knocking on start up
  244. Rough start after sitting?
  245. Comment on leak on block hair-line crack. K&W?
  246. Building myself some new sway bar disconects...lets see how they come out
  247. 99' and 03' Tacoma front spindle the same?
  248. CBI Rear Bumper Installed
  249. Need A43D Trans. Help
  250. Limited flare/plastics removal
