Any difference between MAF sensor for 96-98 vs 99-02?
Old Dec 1, 2010 | 08:34 AM
Jason B's Avatar
Is MAF sensor and different for 96-98 4Runners, vs 99-02???
Old Dec 1, 2010 | 09:41 AM
250000_yota's Avatar
95.5-98 uses the MAF that comes mounted in the housing.
99-02 uses the removeable MAF mounted to the intake tube just after the af housing with two screws.
Old Dec 1, 2010 | 09:52 AM
Jason B's Avatar
Ok, so I'm wondering, this intake I sell, is listed for 99-02, and do you think there is anyway this would work on 96-98 with the different maf?
see pdf:
http://www.sbfilters.com/core/media/...ee280&_xt=.pdf
Old Dec 1, 2010 | 10:25 AM
Elton's Avatar
its really not hard to switch over to a 99 style maf i did and its been running perfect ever since
Old Dec 1, 2010 | 10:33 AM
Elton's Avatar
also if its just the intake tube it should be all the same but if it replaces the entire factory air box then i doubt one for a 99 will work for a 98
Old Dec 1, 2010 | 10:38 AM
Jason B's Avatar
Yea, the whole airbox gets replaced with a new highflow box. Check out that PDF. That's the question, would it work for a 96-98. That link is pretty detailed with pics.
Old Dec 1, 2010 | 10:47 AM
Elton's Avatar
ya link didn't work for me
Old Dec 1, 2010 | 11:04 AM
Jason B's Avatar
Try right click and saving it, then open it.
Old Dec 1, 2010 | 11:39 AM
I have a '98 T100, which uses the older style MAF. The intake I got for free was for a 99-02 Tacoma. I cut the intake tube off where the MAF port was, and used a spectre silicone cuppler from autozone to attach the MAF to the tube.
Old Dec 1, 2010 | 07:31 PM
Greg_Canada's Avatar
TO run a 99+ MAF in a pre99 you need to re-pin the harness...
Old Dec 1, 2010 | 07:34 PM
Elton's Avatar
ya i couldn't figure out how to repin mine so i just cut and re soldered
Old Dec 2, 2010 | 07:41 AM
CLin9383's Avatar
Here is a link to upgrade to 99-02 MAF.
http://www.ultimateyota.com/index.ph...6&topic=3915.0
Old Dec 7, 2010 | 07:40 PM
Jason B's Avatar
Intersting...
Old Dec 10, 2010 | 06:13 AM
terminator's Avatar
Interesting indeed. Same concept of repinning applies when converting your 96-00 tails to the 01-02 style on both 4Runners and Tacomas.
krimsonone
Sep 13, 2024 09:33 AM
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
redneck17
Aug 12, 2015 08:15 PM
ty1er
Aug 1, 2015 11:53 PM
