dual alternator bracket for 4runner?
Old Nov 15, 2010 | 01:14 PM
irpirate's Avatar
anyone know where i can get one? i already have a high output alt that does 160-180 at idle. it puts out plenty while driving but i want more idle power. car stereo system needs more poowwaa!!!! i have a 2002 4runner 3.4 v6. thanks all!!
Old Nov 15, 2010 | 01:24 PM
xxxtreme22r's Avatar
dual alternator? never seen that before. maybe try putting a capacitor on the stereo system.
Old Nov 15, 2010 | 01:30 PM
irpirate's Avatar
extreme stereo cars often run 4-5 h/o alts. then again im not pusing 30000 watts lol. just need two. caps are more or less useless. i have 240 pounds of batteries already, plenty of reserve, just need a lil bit more juice to charge em. theres plenty of dual kits for those damn gm but our yotas get ignored
Old Nov 15, 2010 | 01:38 PM
naksukow's Avatar
I would search over on ttora.com
Old Nov 15, 2010 | 01:41 PM
irpirate's Avatar
takin a look now
Old Nov 15, 2010 | 02:05 PM
make your own.
Old Nov 15, 2010 | 02:27 PM
irpirate's Avatar
nadaaaa on ttora.com. lol i wish i could make my own, except i have 0 experience working with welding and metals and what not. if i knew how to do all that id already have 2 in.
Old Nov 15, 2010 | 03:23 PM
Aznwolf118's Avatar
Which alternator do you have now?
Old Nov 15, 2010 | 07:36 PM
irpirate's Avatar
dc power 270xp. car idles at something stupidly low, think i get 1900 alternator rpm at idle. this isnt specifically for the one i own but this is the output sheet for the alt http://sphotos.ak.fbcdn.net/hphotos-..._3219475_n.jpg
wishing i could put another one of these bad boys in
Old Nov 15, 2010 | 08:24 PM
Elton's Avatar
did you do the big 3 in 1/0 ?
Old Nov 15, 2010 | 08:28 PM
irpirate's Avatar
big 3 in 3/0 welding
Old Nov 16, 2010 | 11:42 AM
rideexileex's Avatar
if you are only concerned about power availability at idle, why not just put in a high idle switch?
Old Nov 16, 2010 | 11:56 AM
kevtek's Avatar
How did you come up with that?
Old Nov 16, 2010 | 12:02 PM
kevtek's Avatar
Also some specs on your stereo might help.
Old Nov 16, 2010 | 12:18 PM
Elton's Avatar
looks like you might need to run a 2nd battery or get something crazy from http://mechman.com/
Old Nov 16, 2010 | 12:35 PM
I want to know this too, because extra batteries are useless because the current draw from amps is very dependent on voltage. As more current is required by the amp more voltage is required. Having 4-5 batteries is still 12 volt no matter which way you look at it.
Caps have been used successfully for years and years. General rule for them is a 1 farad for every 1000W. An 1100W amp would need a 1.5-2 farad cap.
Old Nov 16, 2010 | 12:36 PM
hehe he already said he's got 240lbs worth of battery in his 4runner.
Old Nov 16, 2010 | 01:31 PM
Elton's Avatar
o i didn't see that lol
Old Nov 16, 2010 | 02:28 PM
capacitors add what is called complex power - and actually robs away peak potentials from the system, while adding in a little help during power strains on underpowered systems. Look at any competition SPL car, and you will find no capacitors in any of those systems.
btw - caps dont add voltage to the system, they simply store charge and release it rapidly when there is a strenuous draw on the system. Caps being useless? I don't agree with that. They are great for the general consumer with a 1 or 2 amp system and single stock battery/alt
in simple terms - the more batteries, the more power reserve from which the amps can come from...
Old Nov 16, 2010 | 02:33 PM
Kerby J's Avatar
Look into using back caps they are really expensive batteries that are like a battery and cap combined all competition cars use them
