- exhaust help!
- I Got One
- how do diff drop spacers work
- I have been so careful but finally....
- No talk, straight up off-road pics!
- Locks always frozen
- Check engine light
- New-ish to YT: My '98 4Runner SR5
- CV/Half Shaft replacement 01 Taco
- Wheeler's Steering Rack Bushings Question
- Brush guard/ taillight guards
- Lower ball joint replacement
- engine shuts off
- Tailgate Question
- body lift
- Thinking of buying '00 4Runner already lifted, need advice please
- Trail-gear sliders
- 2001 Tacoma Manual Transmission Grinding
- Anyone really good with photoshop?
- What would you pay for a 2001 4Runner SR5 2WD with 215K miles?
- pitman arm hitting spring????
- Double Pole Single Throw (DPST) Rocker Switch
- So i broke this part off my radiator (pic inside)
- 4WD won't disengage on 99 4Runner LTD
- Help considering buying a 1996 4Runner
- Oops! Wrecked that one.
- Oil Light Flicker
- Rolled 4runner
- Leaning left 4Runner????
- It's christmas...S/C
- What Transmission was behind the Supercharged 3.4L?
- 3rd Gen hazard warning switch not flashing.
- Another MAF/P0171 Thread
- Bolt pattern question for 4runner vs Xterra
- break pads life?
- Suspension idea..is it possible?
- Can someone check their swaybar?
- EVAP Canister routing
- help finding old thread on ome coils
- What is this Worth? 99 3.4L S-Charged Motor + Trans
- Cold Chirping
- How hard is it to change the pinion&ring?
- Anybody add fender flares onto a 4runner without stock flares?
- Surco size me
- Transmission valve upgrade
- Finally! DIN inclinometer and gauges!
- Weird engine whine
- redline water wetter for 3.4l
- Pics!!!!
- which amsoil diff fluid..w/"ADRD" or w/o ADRD?
- Semi-OT: Anyone here thought about getting a FZJ80?
- CV Replacement Write-Up (3rd Gen)
- Tranfer Case Oil Seal Replacement
- Replaceing ECU
- 3rd Gen tailgate courtesy light not working
- i need help finding a replacement 2001 driver door
- Sonoran Steel 7.1 vs 1.1
- DieselOil
- Headlight Options
- Who's using Yakima Q towers on a 3rd gen?
- Crank pulley (Harmonic balancer) bolt hole for puller size??
- My Temporary suspension solution until spring: Your thoughts?
- Cold air intake on 3rd Gen
- 01 4Runner tires
- SR5 to 'Limited'
- 3rd gen with 4th gen shocks/springs?
- Mobil1 gear oil in Canada
- I Can Help With Toyota Parts
- Approach and departure angles 3rd gen 4runner
- Leaking Engine Oil in a strange place !!! ??
- URD Fuel Upgrade kit on ebay
- Need a Yotatech friendly dealer
- Frustrated, Need Some Help Here.please
- 75w90 or 75w140?
- This is really not cool...gas door won't open
- Tacoma HVAC controls seized up.
- E-locker issues
- Catalytic Converter
- I need advice and info on any 3" (body) lift for a 1999 4runner limited v6, please.
- ran into a stange bolt problem while removing my hitch.
- front diff drop
- Selling my baby, giving everyone a heads up
- Painted LC Wheels for my Runner
- Before I cut the wire... Please verify for DRL mod on 2002 taco
- Pulled my Error code slow o2 circuit...
- Help: Do I need to Replace Rear Actuator on 99 4runner Ltd
- Arm rest add on?
- Fender Flares/Running Board Question
- Rusty Coils
- highway drive with 5.29 and 315s
- Mileage on 2.7 vs. 3.4 4wd
- tire: i know it's been beat to death
- Another Overdrive Problem
- Dealer damaged my oil pressure sending unit!
- 99 Tacoma Starter will not shut off
- Need rear axle pix...park brake cables
- Happy thanksgiving! And a picture to celebrate
- Cutting Coils
- vortex muffler
- Brake problems...
- New 4runner and a check engine light...
- Need to add DRL to 2004 Tacoma
- Rough running (CEL) after engine bay clean
- Purchase '99 Springs
- New wheels on!! Silver TRD FJ Cruiser Wheels on 3rd Gen
- Picked up some Napa CV's.
- Part Number? I broke this....
- 97 4Runner / Vibration when breaking / but not coming from the breaks
- Testing a U-joint?
- Drivers cv won't dissengage with manual hubs?
- Rough Idle on '04 Tacoma
- rs3000 Alarm on 1996 Limited
- 3rd Gen 4runner trim levels info
- I think I broke a gear in the front diff
- 3.4L engine recall?
- 04 Tacoma Question
- 2" diff drop
- Slid into it--does it look bad?(pics)
- 2WD Runner Owners - Shock Recommendation
- Ride Difference Going 265 > 285
- Energy suspension bushings
- Intermitent clunking noise when turning .
- Custom Topout Spacer!!
- tail lights
- Aftermarket 99-02 headlights... SUCK!
- forgot head hexbolt. Have to take back appart?
- LEAKING RACK and PINION
- CV question!
- Slow Coolant Leak
- Drops of coolant on crossmember
- 2001 4runner engine, starter, alarm problems
- OME lift question
- How can I check this?...
- Who has the most capable 3rd gen?
- CV's Binding?!
- 1" coil spacers won't fit back in?!
- A few questions
- What happened to these pics?
- SS#1.1 lift
- Coils Question
- King Or Toytec Coilovers?
- 96 runner suspension question
- Right side view mirror problem
- Rebulid Specs 3.4 Liter
- Advice w/ Spare Tire in Trunk...
- BILSTEIN SHOCKS LIFT QUESTION~~~~3rd Gen 4Runner
- Weird engine knock robbing power from my 3.4..
- Sluggish starting issues
- 99 4-Runner stalling at idle
- What size are the skid plate bolts?
- Intermittent "No Start"
- Looks like a good deal on a 3rd Gen
- Time for Tires...need opinions
- 4runner rear panel
- Cel Help
- Dexron VI question for 02 tacoma
- Cleaned the ground wire connection
- Center Console
- out of gas at 1/2 tank 99 ltd
- PicRequest: Dual side exhaust please
- FJ rims on tacoma with manual hubs?
- Seat Covers
- Possible electrical probs with runner?
- Best Tacoma engine?
- Hack/Mod for 2006 Model OEM Navigation
- Question on rear spring lift issue
- Weird noises under vehicle
- Changed the interior illumination last night...
- Where To Buy Trd Tundra Coils/springs
- Questions
- Lift is on!!!
- Sonoran Steel Vs. Toytec
- What seats to get for my 96 Taco 4x4
- URD Vetrans Day Sale
- Washer resivior
- 4 wheel drive wont engage
- Bad steering rack?
- gear selector switch
- Fuel Smell
- Is this too high?
- Tundra Brakes on a 4-Runner
- bumpers?
- 02 4runner problem
- Fast help with lift install please.
- tundra/OME coil lift experianced ones!!
- Need some opinions
- Rear Bumpers??
- Finally Pictures of my 4Runner
- Same clutch kit as marlin for cheaper
- 140k miles to much for these LC coils?
- New stereo install question
- 99 runner ........Dust entering vehicle
- Whoops, left off my oil cap, did I cause any permanent damage?
- Timing Belt Cost
- Please, Give Me Your Advice...
- Tacoma Limited slip or Spool? Help me decide
- comparison pics: 265/75R16 to 285/75R16
- Shrockworks Bumpers
- Is this bumper OEM (JDM)?
- toytec lifts any opinions
- Latest Mods Pics
- New wheels = Photoshop request
- obd3 scan tool with vista?
- Anyone have a service manual for a 5Vz-FE, need firing order a.s.a.p.
- Is This The Rear Main Oil Seal?
- HVAC Controls
- 3rd Brake Light LED question...
- 4runners are a great investment!
- Automatic Transmission downshifting clunk.
- Downshifting the Automatic Transmission
- Oil Pan Gasket help
- Post your pics...
- Look what i installed this weekend :)
- Rocker Switches
- 2001 with Clicking/Ticking Sound Underneath Hood...Engine Problems?!?!
- Key stuck at ignition
- 2001+ exhaust manifold
- new to the group :)
- Please help me identify this part
- Need help: steering wheel & key is locked!
- Screwing into pillar
- 4th gen front on a 3rd gen!
- New Toys: TRD Headers + LED Tails
- o2 censer
- Retaining Spring (brake job). I put it on upside down...
- Check Engine / Trac Control
- Backwards hot/cold idle after cleaning IAC question
- Anybody got pictures of the silver FJ TRD wheels on a 3rd Gen?
- When the time comes 3.4to 3.4
- Am I crazy to want a little Tacoma?
- '04 Taco prerunner
- In a nutshell, why is the 4runner a poor HP and MPG performer? What can be done?
- New rims with pics
- Sugestions for new brakes...
- Automatic into a 5spd
- brd3 scan tool with vista
- Best way to clean & oil Trueflow air filter
- Starter Won't Quit
- An Idea of Running No Cat...
- What to look for when checking out a SC'ed 4runner
- For all you K&N haters...
- Nardi steering wheel install
- trekmaster shocks
- Exhaust and tire press. question
- I think my timing belt is pooing out.
- If you have ABS issues take a look
- Brembo rotors and Hawk LTS pads installed...
- Rear passenger drum break
- 285/75R16s (sorry, to beat a dead horse)
- 15" tires?
