Energy suspension bushings
Old Nov 20, 2007 | 10:33 AM
One_96TR4's Avatar
Does anyone on here know the correct energy suspension bushing part numbers to order for the swaybar endlinks? Has anyone replaced there rear sway bay bushings with energy suspension ones? They sell a complete kit for the from but nothing for the rear so I'll have to order those parts separately. Can anyone help me out with these part numbers?
Old Nov 20, 2007 | 12:57 PM
cackalak han's Avatar
You should just order it from this site:
http://www.wheelersoffroad.com/4runswaykit.htm
Comes with front sway bar/endlink bushings. That's what I got. I ordered some Energy Suspension ones last year, and they did not fit. I called them up and I had the correct part number, but the OEM brackets were too small (they said that it was supposed to be used in conjuction with the stock brackets). I got frustrated with the run-around, so I tossed them.
Old Nov 20, 2007 | 01:35 PM
One_96TR4's Avatar
That's the energy suspension kit for the front with the addition of new bumpstops. I was already planning to get that kit but I wanted the endlink bushing for the rear was well and I don't wanna have to buy the whole kit for no reason, just to get the endlink bushing in the rear.
Old Nov 20, 2007 | 01:57 PM
pfbmgd's Avatar
Are these bushing better than stock ? I think my front sway bar bushings are gone .Should I use these instead ?
Old Nov 20, 2007 | 02:51 PM
That's the Daystar kit, not ES. I believe the front endlink bushings also work in the back (someone correct me if I'm wrong). If anything, call them up and ask.
Poly Urethane bushings are harder than stock rubber ones. It will last much longer than stock. I'd just get these instead.
Old Nov 20, 2007 | 03:34 PM
One_96TR4's Avatar
I stand corrected, I know the endlink bushings from the front will work on the back but I don't want the whole kit just for those bushings.
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
ktm192k
Oct 1, 2015 08:47 AM
