Testing a U-joint?
Old Nov 21, 2007 | 10:47 AM
WFO's Avatar
WFO
Testing a U-joint?
There is a squeak in my girlfreinds 4Runner. It only does it occasionaly and usualy only at speeds around 15-30mph. It sounds like its coming from the rear of the truck. Its worse when youre on the gas or slowing down. Just like a U-joint. Well I took the rear driveshaft off a couple weeks ago and checked out the U-joints and from what I can tell they seem fine. You cant hear this noise when you just jack up the rear tires and spin them.
So how can you really check a U-joint?
How else can you find a squeak that you cant hear at slow speeds?
Sorry so long thanks in advance
Old Nov 21, 2007 | 11:11 AM
MTL_4runner's Avatar
Did you try greasing the joints at all?
If this is a 2WD then nevermind.
Old Nov 21, 2007 | 12:09 PM
WFO's Avatar
WFO
Actualy no. I was out of grease and it stopped making the noise. But im planning on trying that next.
Old Nov 21, 2007 | 12:55 PM
Maj's Avatar
Maj
The joint can be dry and squeak but still not exhibit any wear (yet). To check for wear, chock front wheel, leave in gear, jack up one side of axle just enough for tire to elevate (assuming you don't have aftermarket locker), spin elevated tire back and forth and observe joint for any play.
Old Nov 23, 2007 | 04:30 PM
dirtoyboy's Avatar
u-joints dont really "squeak" per se.
Does it make the noise if u push down on the rear of the truck? I would look into maybe a squeaky shock bushing
Old Nov 23, 2007 | 04:32 PM
dirtoyboy's Avatar
the play in a u-joint should be measured by trying to move it side to side...there should be ZERO freeplay..if there is ANY...the joint is on its way downhill
Old Nov 25, 2007 | 08:12 AM
BennyTRD's Avatar
When greasing U-Joints make sure all the cups are taking grease. If there aren't then you should replace it.
Old Nov 26, 2007 | 05:08 AM
WFO's Avatar
WFO
I checked it out again the other day. Its not exactly a squeak like I said before. Its almost like a tick. But it definatly only happens when youre on the gas. Well I greased it up and it still made the noise. After a day though it stopped. Hopefuly it wont come back. If it does Ill have to look into it more. We shall see.
Old Nov 26, 2007 | 04:04 PM
dirtoyboy's Avatar
grease those babys every 2500 miles or EVERY oil change.
this is the most commonly overlooked maintenance procedure on toyotas..
if u are in the mud or off road..do it more often..
like pappy always said, "son, grease is cheap. parts aint."
moparbay
Mar 10, 2023 03:50 PM
Obmi
Oct 30, 2015 04:27 PM
accuracy
Sep 20, 2015 07:44 PM
larrys93pickup
Sep 17, 2015 07:05 PM
Boomer8404
Sep 10, 2015 09:01 AM
