which amsoil diff fluid..w/"ADRD" or w/o ADRD?
Old Nov 28, 2007 | 09:56 AM
jrock's Avatar
amsoil lists 2 different 75w-90 diff oils available for my '98 rnr(differential-front).. One is for diff w/ADRD and one shoes the fluid is w/o...i was thinkin this is referring to a locker but not sure. 4runner.org did not say he used one or the other.
thanks for the repsonses in advance!
Old Nov 28, 2007 | 10:56 AM
4Crawler's Avatar
Usually the additive oils are for use with clutch-type limited slip (positraction) typy diffs. Usually an open diffs or automatic/manual lockers are fine with plain old GL-5 gear oils. The friction modifiers are needed for the limited slip clutch packs to engage smoothly. The additives usually do not hurt an open diff, in fact you would notice no difference between the two types of oil. You could probably contact the Amsoil tech support folks for a vehicle-specific recommendation.
Old Nov 28, 2007 | 12:03 PM
jrock's Avatar
Adrd
amsoil got back to me..ADRD is automatic disconnecting differential. They recommend the 75w-90 severe gear for either one.
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
viesail
Sep 21, 2015 06:00 AM
