Timing Belt Cost
Old Nov 12, 2007 | 02:45 PM
GOH10 Runner's Avatar
Timing Belt Cost
Need a bit of info, how much did it cost yall to have your timing belt changed? I got quoted $590 for Timing Belt, Water Pump, and Drive Belts.
Old Nov 12, 2007 | 02:46 PM
Whitey13's Avatar
dealers around here charge around $750.
Old Nov 12, 2007 | 03:15 PM
Paul H.'s Avatar
Thats a good price, I was quoted $778.
Old Nov 12, 2007 | 04:50 PM
MTL_4runner's Avatar
Originally Posted by Paul H.
Thats a good price.
X2
That's a very fair price for doing all that including OEM parts.
Old Nov 12, 2007 | 05:39 PM
tntempest's Avatar
I just paid $479 at a Toyota/Lexus only shop.
Old Nov 12, 2007 | 05:41 PM
CJM's Avatar
CJM
Expect to pay about 500 bucks.
Old Nov 13, 2007 | 06:22 AM
Ian Rogers's Avatar
i think that i spend $400 + on OEM Parts (timing belt, t-stat, water pump, #1 & #2 Idlers, Drive belts, new crank bolt, Toyota red coolant.) Just buy the parts and do it your self, this way you know its done right.
Old Nov 13, 2007 | 06:45 AM
X-AWDriver's Avatar
A dealer should get it right and if they don't they do have a warranty;I wish that was something I could do but I'll leave mine to the pros.
Old Nov 13, 2007 | 07:01 AM
mt_goat's Avatar
Before leaving your truck, ask them what they will retorque the crank bolt to. (It should be retorqued to 217 ft-lbs on the 5VZFE) Even many pros don't have the correct torque spec because it changed after the early 5VZs had problems with the crank bolts coming loose and ruining the crank. The old spec was about 185 ft-lbs IIRC. And make sure they actually have the SST to hold the crank, some will cut corners and just use an impact on it hoping it will be good enough.
Old Nov 13, 2007 | 07:02 AM
Def. agree with that
Old Mar 23, 2008 | 06:34 PM
jay993rdgen's Avatar
timing belt cost
getting timing belt and water pump done tomorrow for 350.00. 4runners got 132000 on it. i will check condition of old belt and post again.
Old Mar 23, 2008 | 07:19 PM
pfdaxe's Avatar
Good price. I guess I should get mine done. There's an independent Toyota shop near me ( http://www.toyowest.com/ ) that installed my TRD headers. I'll see what they rape me for...
Old Mar 23, 2008 | 07:55 PM
24Runna's Avatar
$260 at a local dealer. Nobody beats them, and they get most of the timing belt business here.
Old Mar 24, 2008 | 07:47 AM
cackalak han's Avatar
All of my local dealerships want ~$350 for timing belt only.
Old Mar 27, 2008 | 07:26 AM
fasthorse67's Avatar
$270 including drive belts, oil change and brake inspection.
Old Mar 27, 2008 | 08:13 AM
mkgarrison5's Avatar
i bought my parts at yota of dallas by pm'ing a fella here and saved atleast $60 on parts..then i called around for labor quotes and went with the cheapest mechanic i TRUST.. i was quoted by the local dealership for everything for around $550-625 bucks and i ended up paying a total of $480 or so.. not too shabby.. heck thats with yota red coolant and everything.. btw if you do not go to a yota dealership then buy your own toyota red coolant and distilled water and let them use that.. lord knows what they put in it.. btw this is what i had done for that price
t-belt
water pump
thermo
all drive belts
that sucks around here its 229.99
Old Mar 27, 2008 | 08:25 AM
Robert Bullion's Avatar
That's a reallllly good price ! While he has the front of the engine torn apart
have the cam and crank seals replaced and new Toyota red anti-freeze
installed along with Alt/PS/AC belts replaced. Should not add more than $150
to your cost, plus you'll be worry-free for many more miles.
Old Mar 27, 2008 | 08:51 AM
michalik_piotr's Avatar
wow, those are some great prices! i'm getting the timing belt/h2o pump, front brakes, tune up, all fluids and filters, etc for $900. should be picking up truck today.
Old Mar 27, 2008 | 05:32 PM
leo the lion's Avatar
any here in md. and what price?
