Best way to clean & oil Trueflow air filter
Old Nov 8, 2007 | 10:48 AM
irunner's Avatar
Mine needs to be cleaned, i lost the box and the link on their website doesn't work properly, so if anyone could let me know the best way to clean it, thanks.
Old Nov 8, 2007 | 10:56 AM
Ron Helmuth's Avatar
Run lukewarm water through it from inside breathing surface to outside
let dry a long time-shake it once in a while to knock off the droplets
avoid temptation to use hair dryer or microwave to dry it out
Re-oil and let sit again. do not over oil. Shake and make sure no loose oil shakes off.
Old Nov 8, 2007 | 11:10 AM
flyfishexpert's Avatar
purchase the cleaner/oil kit!
Old Nov 8, 2007 | 11:13 AM
fly fish is right
I forgot all about the spray on cleaner, let it sit 10 minutes and them flush it out.
I just did this like 2 weeks ago, dang my mind is mush....
Old Nov 8, 2007 | 12:24 PM
Rock Slide's Avatar
Did you buy the True Flow cleaning kit and just need to know how to apply it? If not, you need to buy the kit.
EDIT: Here's a link to buy their cleaning kit and instructions on how to:
http://www.hyperformanceauto.com/sto...5891C4658.aspx
Here's another one: http://www.autoanything.com/air-filt...A1964A0A0.aspx
Old Nov 8, 2007 | 11:13 PM
rocket's Avatar
x2! I bought mine at autoanything.com ...Fast and free shipping.
Do it right and buy the kit!
Old Jan 6, 2008 | 02:19 PM
I have a dumb question, more of a clarification question. When I spray the oil back on, am I spraying the back side too? The side with the metal mesh? I know with K&N you only sprayed one side... but the instructions say to spray "inside and out" for true flow.
Old Jan 6, 2008 | 05:22 PM
rocket's Avatar
I spray both sides, more so in the front than the back. As a precaution, i'll let the oil fully absorb for about an hour before reinstalling or driving.
Old Jan 7, 2008 | 05:45 AM
trust the moderator
yes Rocket has it exactly right-do not overspray to the point of saturation-and let it sit for quite some time then check for drips so you can see if you did overspray it.
Old Jan 7, 2008 | 06:02 AM
Baloo's Avatar
Is the K&N re-oil kit the same as the trueflow? I have a kit laying around from another vehicle and am considering using on the trueflow prior to ordering the trueflow kit.
Old Jan 7, 2008 | 09:11 AM
Hey thanks guys, I appreciate the info!
Old Jan 7, 2008 | 07:51 PM
High Water Drifter's Avatar
Someone told me that too much oil may affect maf sensor? Personally I'm conservative with the oil. Don't drench it.. my 2 cents
Old Jan 8, 2008 | 06:04 AM
yes High Water Drifter has it right-too much oil can gum up the air sensor-I experienced that with K & N FIPK system on my '95Runner-2nd gen.
Old Jan 8, 2008 | 06:08 AM
different filter media
I would doubt that the chemical compound in the 2 is identical-but likely similar. The Tru Flow uses more of a foam type material for the filtering, while a K & N filter is more paper-like.
Why not just trade your old respray kit with someone with a K & N or swap for some other part with them?
between this forum and T4R.org you should be able to find someone willing to trade/buy/donate.
Old Jan 9, 2008 | 01:51 PM
Joe's Toy's Avatar
I read somewhere that "normal" air filter oils aren't to be used on the trueflow filters. I wish I could remeber where... lol
Old Jun 15, 2008 | 10:08 AM
Deceptiwave's Avatar
what would happen if I didnt re-oil my true flow?
I cant find a dealer that is open today with a recharge kit and I have to do some driving...
Old Jun 15, 2008 | 10:16 AM
crolison's Avatar
ditto
Old Jun 16, 2008 | 02:52 PM
Gerdo's Avatar
I have a K&N. I used the suff that they sell and it works OK. I now use warm to hot water and some dish soap. Works great!
Yes, oil LIGHTLY! Too much oil and you gill gum up everything past the filter.
Old Jun 16, 2008 | 03:15 PM
Joe's Toy's Avatar
Hey just incase anyone is looking http://www.xtremediesel.com/index.as...OD&ProdID=1093 has the kit for $11.95 + $7.47 shipping (deppending on where you are). It's a little cheaper then going w/ autoanything.com
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
88runnergomas
Jul 9, 2015 01:12 PM
