Key stuck at ignition
Old Nov 11, 2007 | 03:31 AM
klwood's Avatar
I couldn't turn the key on my 96 Surf (4runner) to the "Acc" position and remove the key, after the car sent for an interior wash. It is an autobox and I suspect dirts could have got into the switch at "P" position. Would you think it is posible?
Old Nov 11, 2007 | 04:14 AM
xsvtoyz's Avatar
I would check the fuses first and then maybe the tumbler assembly.
And if you are lucky you are in the acc position the first stop after key removal position(turning clockwise). If so just remove the panel around the switch area find the little brass pin (usually at the bottom) and remove the whole tumbler assemby. Check the internals with a screw driver should be a slot inside where you removed the tumbler (be carefull this will start the vehicle) if this turns ok clean the tumbler that should be in your hand. wd or any solvent style cleaner and then follow up with graphite messy but it is the ultimate lock lube. Once you have lubed inside the housing with graphite try it again.
Old Nov 11, 2007 | 04:37 AM
KZN185W's Avatar
Try shifting slowly from P to L then back. then try to turn the key and remove it.
theking11863
Mar 19, 2016 09:36 PM
Dee Draper
Aug 23, 2015 11:54 PM
bvleonov
Aug 22, 2015 11:39 PM
TDonkey
Jul 26, 2015 10:14 AM
Hamonacracker
Jul 17, 2015 08:33 AM
