Weird noises under vehicle
Old Nov 15, 2007 | 08:04 AM
ljshein's Avatar
Guys,
I have a 99 4runner limited 4x4 with the 3.4 V6 & automatic about 95000 miles on the odometer. I'm hearing two noises that are probably related but I'd like another opinion.
1. I have a dip in the road that I'm forced to traverse kind of like an inverted speed bump. funny thing is its at the bottom of a hill, kind of a valley on the road. So, when I go over it, there is some downward pressure on the suspension. There is a significant clunk under the mid section of the truck. The downward pressure and drop in the road is the only way I can consistently reproduce the clunk. I was thinking transmission mount but it appears to be solid.
2. Also in the mid section of the truck there is a rubbing noise, almost like a belt. It is not coming from the engine. It only occurs when the truck is moving and my foot is on the gas enough to maintain speed. I don't hear it during acceleration or braking. It does not occur if the transmission is in park or neutral.
Is there a bearing or some sort of carrier between the drive shaft & transmission that could cause this?
thanks in advance to your guidance!
Jeff
Old Nov 15, 2007 | 08:24 AM
mkgarrison5's Avatar
have you greased your driveshaft lately?? there are 6-10 fittings.. i cant remember how many exactly.. you need to grease this every oil change or every other oil change. thats what i was told by another tacoma owner and his has 210k miles with no major issues at all!
Old Nov 15, 2007 | 08:27 AM
Nate08's Avatar
That is the exact first thing that I thought?
Old Nov 15, 2007 | 02:32 PM
dirtoyboy's Avatar
most likely a bad u-joint and/or bearing
jashoeuh
Nov 18, 2024 08:08 AM
genuinegemini
Aug 3, 2015 04:56 PM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
razorman8669
Jul 12, 2015 12:13 PM
