- Electric A/C fan
- Yellow 4Runner
- transfer case and tranny. What years fit?
- 2nd gen 4Runner w/ 86 truck chassis
- 4wd problems.....
- Looseness in my steering.
- Not sure what's wrong..
- New member says hellos and asks a few questions
- VSC / TRAC defeating - is anyone closer?
- Have A Great Thanksgiving!
- question about motor options
- buying 3rd gen 4runner this weekend
- 3.0-3.4 swap questions
- help, need help with OBII and fuel trim tuning!
- Quick headlight question so I don't break an trim...
- changed u joints...now WHAT!!!!&@$%
- 4 RUNNER REAR END QUESTIONS...other posts i found in searches leave me with questions
- WRITEUP: Installing an aftermarket electric oil pressure gauge
- Hanna Air (dial-up warning)
- Checked out a new Tacoma
- Transmission fluid cooler lines
- My car whines when put in reverse...
- Winch / brush guard question
- 98 Ltd frt suspension squeak?
- Any experience w/ KargoMaster roof racks?
- throttle body cleaning question
- New tires - PICS!
- Cleaning a heater core
- 88 V-6 :: Hunting Idle while on brakes
- Flex a lite fan mishap
- Where is the a/c comonents in 3vze?
- FYI - (another) CEL w/code P0420
- Questions on TOYOTA suspensions in 1st and 2nd gen
- OEM 4Runner Parts Distributor
- 3.4L airbox assembly year compatibility?
- Good exhaust setup & sound clips?
- Just bought my first Runner!
- How many miles out of a S/C'd 3.4L?
- Solid Rear Window/Sliding Rear Window Trade
- my alarm keeps going off
- need Roof Rack education & recommendation
- I need help 1992 3.0 is making a weird noise
- Nice website for racing parts 20r 22r
- Any Suggestions on Wheel/Tire combos?
- Does any one know where to buy a hood with a scoop on a 1992 Toyota 4runner
- Windows hard to open
- Smelly brakes?
- Axle Wrap Gone
- trading in my F-250 and selling my Yota
- Brighter backup lights
- Call for help in Denver Colorado
- Bilstein, Rancho, etc, etc. - but what about OEM Shocks?
- Selling my 4th Gen - Experience with EBay?
- ?? @ roof rack leaks
- doing 3rd member swap, a few questions
- Resonator connected to breather?
- Help
- FSM gone
- What do you think these do?
- What are these?
- $18 aux reverse lights (image heavy 640x480s)
- What about automatic locks?
- Hello from Spain
- Blue foglights
- Rear Light problem on a 2000 SR5 Auto.
- Clever Installs for Aux Lighting: Lightforce 170s
- Check out this video when u get a chance
- 2wd driving in the snow,bad idea?
- ARB Bumper reinforcement?
- chirp!
- looking for a diesel landcruiser?
- There was a click then it all went black!
- 3rd gen 4runner shoes
- 2nd blown head gasket on 1 year old rebuilt 22re
- 4Runner w/ Moto tote??? (3rd Gen)
- Anyone ever do SAWS with a spacer?
- Engine and computer combo... will it work?
- Where to tap into tach signal?
- 4 wheel drive / manual hubs
- Fuel cut solenoid question
- Mechanical advance question
- Quick help needed: Rotors won't come off
- How to raise my new baby...
- Help Need More Power for my SR5 V6 92 toyota 4runner
- pics of an all white 3rd gen 4runner in az
- california dreamin'
- another roof rack question
- '92 4runner buckets......
- Need help finding flare parts
- Radiator Fit?
- 3.0 mods
- throttle cable stretch?
- Downey Mid Range Hi Pro Cam in my 22RE?
- newbie, would this work?
- Conversion Question
- 22R-E Automatic shifting problems
- Seat switching without breaking the wallet
- How much does a stock flywheel weigh?!?
- Revtek complete, Tires are next...
- Help with purchase of a 1995 4Runner
- Bull Bar modification for body lift?
- ECU questions
- 5VZ Type "O" throttle body gaskets - eliminate the "D"
- daystar spacers
- what's wrong with my runner?
- 2nd gen 4runner spare tire carrier
- S. California Gets Up to 3 Feet of Snow Yota pic
- Test drove a 2005 Pre-Runner TRD Double Cab on Saturday...
- Brief VA meet and greet last weekend ...
- Slow leak
- Bad compression, time for swap?
- my new truck
- AAL springs and lift shackles for 3.5" lift?
- Just ordered Camburg 2.5 coilovers and Wheelers 1.5 rear leaf pack...
- Probally the coolest upgrade ever
- difference between the R150 and R150F?
- Downey leaf spring question?
- Where can I find nerf bars for 88 4runner
- Clutch overheats & slips '91 4Runner
- 2OO0 Tundra coils for 97 runner?
- TRD Headers
- monster 3rd gen pic
- Header or Cam?
- Wheres a good grounding spot for lights?
- Hello
- Buzzing noise
- Daystar 4th gen 1" front lift question
- 4th Gen/DEI Immobilizer Bypass
- Speedo Cable
- help finding part
- Problem, what could it be?
- need help before christmas
- Engine Swap 3VZE
- Swapping 3rd's from an auto to a manual
- 1st signs of auto transmission failure?
- replace 3.slow with 5vzfe or 3mgte
- Help ! whining/sqqealing noise in 3rd & 5th gears
- Help! battary got hooked up backwards
- Overdrive Question
- Anyone Witha Black 3rd Gen????
- Yotatech Rules, Black Sr5 Here
- Best was to flush?
- Catalytic converter help
- need cheap radiator
- Manual Tran - Squealing/Grinding in 3rd and 5th gears..
- (Videos) Pushing the Yotatruck for all it's got!
- Selling the 4Runner to import a Hilux Surf?
- 1st gen 4runner Cup Holders
- FJ-80 TRE's on IFS?
- Speedometer / Shift problem
- Calling all 3.0 Mechanics
- Need some input regarding my rear window.
- Recent mods: Hood Scoop, Scion Radio & Clear Tail Lights
- 96 4Runner parts
- I am in DENVER!!!!!
- The best truck commercial I've ever seen....
- parts crossover manual?
- Bolts or studs
- Advantage of manual hubs?
- 1st gen roll bar
- Here is my truck..
- Lifting a 3rd gen to fit 33's
- Brembo Rotors
- Suspension Lifts? Group Buy for Tundra TRD 2wd/4wd coils?
- Very quick question for doing Body lift on 96 4runner LTD
- 3rd gen oem Tire carrier....
- Need help with front end problem
- differences in center "stack"? (radio, vents, fan switches area)
- 22re lacks power
- Engine noise
- A pic off my Tacoma double cab
- Yet another idler arm question...
- ignition problems
- 97 4runner steering wheel adapter hub..
- 3rd Gen Sr5 4WD Issue
- Black D window rims
- Supercharger & 2" body lift???anyone
- Starter probs????? Help
- Adding tow package
- Maximum Window Tint Info per State
- Daystar or Revtek for 03 4runner
- 265/75R16's anybody?
- Cylinder Head Gaskets Recall Questions
- 1997 Toyota tacoma
- Check engine light on
- Can I disable the remote rear window in my 3rd Gen?
- Keyless Entry Install Wisdom Needed
- Where to get my tranny rebuilt in San Diego??
- 8-9mm spark plug wires... where to buy?
- 1/4 tank of gas in 12 miles.
- gear ratio 4.10? (2nd gen)
- Genuine Gear what so bad?
- Ugly 4runners
- Your expierience buying new Toyota's - re: Customization
- Test drive a tacoma off road
- Lightweight aluminum rear bumpers?
- Second Gen. 4runner Manual Steering Conversion?
- UuuoOHHH Check Engine Light????????
- 4 Wheel Parts Sucks!
- Whine of engine drowns out deck plate noise
- 2nd Gen running boards??
- 3rd gen strut removal/replacement
- Backspacing ?S
- YEAH! Found the source of my vibration (pic)
- Need Clarification on Headlights
- Carbon Fiber Taillights?
- Performance Products Halogen Back-Up Lights
- 3rd Generation 4Runner 4x2 w/ SC??
- RAV4 - What's your opinion?
- 3VZE question...
- Bed Mounted Tool Boxes
- SAW fitment questions
- Hissing Air Sound
- AC compressor kicks in and....
- door hinge replacement
- Finally Got some Fender Flares
- Cheap Airtanks!
- 3.0 1KZ-TE or 1KD-FTV turbo diesel
- Hey Arkansas folks! New ORV Park?
- Calendar Poll
- 3vze timing belt change....
- Another bodylift completed!
- Newbie To Board...
- Good 22RE replacement?
- Weird cooling issue.
- New to forum.... 4Runner....
- Question about newer V6's
- Loud engine whine when cold?
- AirRaid MIT vs Plumbing end caps
- Before getting truck painted
- Rough Idle? ? ? ? ? ? ? ? ? ?
- corner lights
- Light Placement
- Just Bought my Third Toyota Today!
- Vinyl flooring for a Tacoma..
- Rear bumper question - '93 Pickup/Tacoma bumper?
- Coolant Leak
- Full Time 4WD info request
- V6 running like crap
- Speedomer cluster guage SWAP? possible?
- my eyes....they burn!
- Power Steering Pump/Pulley Squeal....help!
- Electrical Question
- Another 7mgte swap question
- 1986 Toyota Pickup Track times?
- water getting in with elbow mod
- gearhead alignment question
- Another tally for "I hate the 3.0" column
- Remove my hoses and/or vacuum lines?
- cigarette lighter assembly 1992 4runner
