- how to do a compression check 3.4
- 00-02 4Runner 4x4 ?
- Temperature gauge/coolant temp sending unit
- Front bumper ends
- egr?
- 1999+ Radio/AC Bezel installed in a 1998 3rd Gen. 4Runner *PICS* PART 2
- Things to look at on a used supercharged 3.4 automatic
- 2000 Tacoma HID Ballast Placement
- CAT Coverter Question??
- Towing questions w/ my 4Runner
- i had an S10 commit suicide on the rear of my yoda
- 1.4 Kw or 1.8 Kw Starter?
- engine experts: weird 3.4L misfire
- Wheelin with new lift, sway bar went bye bye.
- gas door wont open?
- Lift idea
- Overdrive
- To SUPERCHARGE, or Not To SUPERCHARGE...
- Am I going crazy?...brake problem
- Upgraded Grille '98 to '99
- Anybody have pics of a 4" lift?
- Steering Rack bushing replacement
- Tire ? - 285/75-17 on 3rd gen 4Runner
- Fuel Injector Removal
- What will stop me best?
- 3rd GEN 4 RUNNER FRAME PROBLEMS?
- Suspension Parts ID - Help Needed, clutch Question
- Center vs. rr diff lock in 2001
- What do you think is it a deal???
- New TPS
- How hard is it to install a new clock???
- Don't you just the 'yota?!
- anybody has BudBuilt skid+bell on your 3rd gen.? mind share some pictures?
- Replacing shocks on stock height runner????
- BackSpacing
- Tacoma Stock OEM Alloy Rim Cleaning
- fan clutch torque spec
- Keyless Entry Chirp Question
- transmission sound
- New Member, Need Help FAST!!
- just inherited es6000 struts. can I use OME coils?!
- So i got bored today. Family of 4runners
- what is this half junk/half awesome 4runner worth ?
- No reverse lights
- Tapping sounds from engine, video, any ideas?
- my satoshi done..
- 3.4L V6 Auto Transmission Question
- Bilstein 5100 series question
- 3rd gen rear window ecm/ecu, HELP!
- Who says you can't have fun in a stock 4Runner?
- OEM Shock/Coil Question
- Difference in '96 and '99 intake?
- Reprogramming New key Fob
- 1999 4Runner 3.4 V6 COIL OVERS -- WHAT DO I BUY?!
- Landcruiser Brushguard??
- Safari Racks and Lights
- 2wd 4cyl Rear Diff 7.5"
- Traded the 4Runner for a Tacoma last week
- '01 Tundra Brakes installed on '98 Gen 3 4Runner
- Proper Warm-Up Method??
- P0755 Code
- Just bought an '02 Sport
- 152,000 Miles...for the tech's: Is it time for a Valve adjustment?
- Should I get these black LED tails??
- 02 4runner Swap, help needed
- 01 gauge cluster in 2000
- Looking to get new truck!!
- Loss of power, stalling
- DEAL OR NO DEAL..? Totaled Runner Drive train purchase question (not mine thank god)
- I need some advice for 2001 4runner
- Check Engine light P0125 and P0141
- Chugging, hiccuping otherwise runs fine no codes?
- My new tires 33"
- Wheel Vibration
- FJ struts on Tacoma.
- rear diff breather plugged blew out inner axle seal
- NEW! Moble 1 0w-30 full synthetic
- Brake pads and fuel filter replacement.
- Torque Specs for Body Mount Bushings
- What piece am I missing, where to find it?
- Replacing ball joints??
- seat belt locked!
- First problem with 4runner Please Help
- Change in Plans
- Drivershaft grease
- looking to buy. A few questions.
- Weird Smell
- ABS Speed Sensor Rotor Remover
- Help getting trac bar re-installed after 2" lift
- Rear Axle / Wheel Bearing Removal Question
- Rear Axle / Wheel Bearing Puller Tool
- 02 Sensor Help - Stolen Catalytic Converter
- Manual Transmission Fluid Change
- OEM vs. aftermarket rear axle bearings...
- 97 4runner wiper issues..
- Lifted Tacoma with 265/75/R16's
- 00 4Runner Lift Question
- Towing Disappointment
- Need advice! Friend is selling 4runner!!!! Should I?
- Found a lift
- 4runner bavi fitment from 01 tundra?
- When replacing Valve Cover gaskets do you need to replace the Upper Intake plenum
- OME Lift installed 3rd Gen
- Unhappy with Seafoam!
- HELP! Need Suggestions
- 3rd Gen 4Runner Steering racks
- roof rust questions
- Front Sway Bar ends broken
- Different Factory Roof rack option??
- LEAKY Front IFS Axle Seal
- electrical problems! help!
- power antenna help
- 99 Ltd - need help with my power moonroof
- Water In Cargo Area
- SRS light...Possible New problem????
- 1998 3.0 5speed
- A/C Button not responding!
- starter problems - need help / advise
- Brake pedal movement
- Newly lifted black 3rd gen!! 56k be slightly warned
- new OME 2.5, new leaky cv
- LED 3rd Brake Light for 3rd gen!!!
- Check engine light
- Bone Yard finds
- '99 headlight Install on '98
- SCORE! Got a supercharger for $325!!
- Deep water crossing - Issues ?
- trying to order pp springs have question
- Just joined the 150,000
- Cabin filter
- Getting rid of the old carpet!
- OME 881 / 906 Setup
- carr light bar
- new issue with the runner...
- P0420 Code Details - Does this mean anything to anyone(a tech??)?
- Exhaust inlet size
- Tint removal tip Maybe
- I think I did it.
- brakes
- Need some help
- help installing 5125 shocks
- Photo Shoot, New Camera, New Pix And New Vids
- Finished rear part of lift..all done (PICS)
- OEM endlinks
- Modified 3rd gen ARB with 2in RBBL(pics.)
- Recently Changed to Synthetic oil, a question
- Differential, Transfer case washers
- gearing
- Need help with OBD codes for 02 Tacoma
- Tacoma or Frontier?
- Shaking once above 65mph?
- recall... i dont know how true this is
- 285s on 2.5 spacer lift
- Bath and a lift
- Painted rear bumper, all blacked out now.
- It's real now... the 4Runner will be gone tomorrow
- battery light help
- 1996 4Runner - Is this a Good Value?
- Which Transmission
- P0325 error code for a Knock Sensor
- Going to buy a Tacoma but have ??'s
- Got new battery, failed smog check, need tips on resetting readiness monitors
- Runner guys, is this a good deal?
- Blacked out the Amber Corners
- 2 Black 3rd Gens... (56k, make a sandwich)
- Hayden transmission cooler Part#
- 96 4Runner Timing Belt Replacement
- Decal opinions
- ome3-run lift options
- Need advice about buying Tacoma
- Grrrr...another Frankenstein question...
- 99' Tacoma for towing?
- Can I swap my stock front 4.10 diff with a stock 4.56?
- Question on new tires/wheels
- Best place to buy new front bumper?? 3rd gen 4runner.
- HELP!! 3rd gen ARB owners w/ BL ???
- how long for the suspension to settle?
- commando 560 alarm help with power doors+remote start
- Do you guys think a gas tank relocation to the rear is SAFE?
- Limited 4Runner seats in a Tacoma?
- my a/c talks back to me
- Hard shift from second to 1st / Lucas Trans oil help?
- Out with the old...
- leaking right axle seal; 1997 4runner
- What's the biggest tranny cooler that will fit...
- 01 4Runner seems unstable
- Question about a '97 4runner
- Can't decide if i should grab this 1st gen Supercharger or wait for a 2nd.
- help w/ starter removal
- 3rd Generation 4Runner rear left vent question
- Installing trailer light hook up wiring question.
- 4.56's on 265-75-16?
- Anyone else breaking CVs with Toytech OME 3" Lift
- 5 speed transmission rattle
- Will Gen 4 seats fit in a Gen 3 4 runner?
- calculate my rake close as possible please
- Speed Sensor and Tcase questions
- click, click,.....start
- My Girl Friends 4Runner
- Auxilary back up lights, Optilux projectors
- Finished first half of lift today (Pics)
- Toyota Buying Tacomas
- Please help me identify this
- few mods wheels, bullbar, satoshi grill.
- To tranny flush or not
- how to remove rear tail lights?
- Brake rubbing
- Tensioner pulley, I cant get it to loosen up!
- I need a Spare Tire !!
- New Grille insert & corner/bumper lights
- Anyone know if these will fit...
- Tundra Brakes - TSB?
- Torque settings / Diff drain & fill & auto trans
- timing question
- Anyone have a skid plate like this..need help
- pulling motor..starter ?
- Value of RR DIFF LOCK?
- Heading for North Africa - Need desert tips
- Clunking noise
- anything extra i should do?
- Wierd Healight Problem
- Hardwiring heated seats.. need directions
- LTD Door moulding removal
- switched to 87 octane & truck died!
- Do I own a Frankenstein?
- 3rd gen stereo
- What's behind the plastic on interior roof/headliner?
- Vibration making hands numb!
- High Pitch squeal from rear of truck
- Some quick fix items - I hope.
- New rims, what you all think?
- Fabtech suspenstion question:
- Will 03 Tundra rims fit??
- head unit difficulties
- Anyone know where to get one of these?
- SRS light all this sudden is staying on????
- Simple Question About Dash and Gauge Lights...
- Wheel Matching photos(PSD)
- The age old question OME 890 vs 891
- Left front wheel in further than right
- Door glass question
- Radiator/Transmission problems
- First trail run of the season
- Tokico or OEM LC Shocks for Rear
- CD Player issues....
- A good place to buy a Rear Carrier Assembly?
- Speedometer - TOO FAST
- MAF Cleaning ?
- Fuel Injector Resistance
- Sport Hood Scooped Hood Scoop FAQ Write-Up
