Landcruiser Brushguard??
Old May 27, 2008 | 04:22 PM
greyghost4x4's Avatar
Does anyone know if a 2000 Landcruiser brushguard will fit on my 1999 4Runner? If so would it be a good fit? Thanks a lot.
Evan
Old May 27, 2008 | 04:34 PM
scuba's Avatar
i would think not, the cruisers are a bit bigger.
are you buying it off the internet or something ?
Old May 27, 2008 | 04:45 PM
I saw it on craigslist for the St. Louis area. He doesn't have any pictures of it online, but for 75 bucks I was hoping it would work.
Evan
Old May 27, 2008 | 05:46 PM
FullXTR's Avatar
FWIW I almost did the same thing a few months ago -- nearly purchased a front bumper from a old Landcruiser for my '96. He wanted a couple hundred bucks for it though and it would have been quite a drive to go get it.
I can guarantee you it will require extensive modding to fit on the truck (as indicated above the 'Cruisers are quite a lot wider), and also I think they are "taller" in the front as well, so the light hoops might look out of proportion without some mods.
I ended up NOT buying that bumper, however if you can get it for $75 then I say go for it. Really, there is probably nearly $75 worth or raw steel there. You could buy it, try to mod it, and if it doesn't work, take the whole cut up pile of scrap into a metal dealer and probably get a good portion of your 75 bucks back.
ToyotaMD
Aug 17, 2018 10:16 PM
cruisin69
Early Land Cruisers (Build-Up Section)
34
May 22, 2018 12:25 PM
HotNotch
Oct 8, 2015 06:51 AM
ToyotaMD
Sep 22, 2015 06:28 AM
