HELP! Need Suggestions
Old May 21, 2008 | 04:49 PM
GONZO97's Avatar
Cool HELP! Need Suggestions
I have a 1997 toyota 4runner limited 3.4 gas, and i want to lift it........but i cant find any lifts ....... if you have any suggestions to help me out id greatly appreciate it
Old May 21, 2008 | 05:33 PM
Bighead's Avatar
1. Click on "Search" at the top of the page
2. Select "Advanced Search"
3. In the new screen, highlight "95.5-2004 Tacomas and 1996-2002 4Runners" in the Search in Forum(s) section.
4. In the Key Word(s) section type "lift"
5. Hit "Search Now".
6. Read to your heart's content.
Old May 21, 2008 | 05:35 PM
desertyodaboy's Avatar
Theres like a million lifts....what are you using it for? How much lift? and so on.........
Old May 21, 2008 | 07:32 PM
Ohio4R's Avatar
toytec.com for the OME lift front and rear coils is your best option
Old May 21, 2008 | 07:49 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
There is no "best lift" there are different types. You have budget lifts, lifts designed more for rock crawling, and lifts designed more for high speed dune running. Just search and you should be able to find a ton of info
Old May 21, 2008 | 09:47 PM
GONZO97's Avatar
Ok this is what i want to use it for..... I want to lift that way i can get those bigger tires and i also like the way it looks....i also want more clearance because when i go off roading with my buds they're climbing things that my car cant due to the clearance issues.... but i dont want to dish out a grip load of money for a lift.... but if i have to i will.... the only lifts ive found are like 3 inch lifts and im looking for a little more if possible........ive also found plenty of spacer kits which i dont necessarly want....if you can help please do, im all ears..... Thanks -Gonz
Old May 21, 2008 | 09:59 PM
nc994run's Avatar
Any lift will get you more underbody clearance, you can only get more clearance at the axles/ diffs by getting larger tires. There really aren't any lifts that offer more than 3" of lift, unless you modify a bracket lift for a Tacoma, but that would be $$$. If you want more than 3", you could also do a body lift (I would recommend 4Crawler body lifts). Depending on the amount of suspension lift/ body lift, you could probably fit 285/75/16 tires (33's), but sometimes there are fitment issues.
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Iceman4193
Oct 16, 2015 10:50 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
