285s on 2.5 spacer lift
Old May 16, 2008 | 06:40 PM
fr3533's Avatar
i have seen 100 different seneros will 285s fit on a 97 4runner limited with a 2.5 lift
Old May 17, 2008 | 09:20 PM
Cuthroat72's Avatar
as far as I know they should. Like I am sure you have heard, make sure that if you go to different wheels than stock that you have proper backspacing so you don't rub your tires on the upper control arms. I presently have a '99 with a spacer lift on it and I clear 285's with no problems. Good luck!!!
Old May 17, 2008 | 10:04 PM
Sloan's Avatar
99s are also the tallest coils to so the low rider years might no be able to.
Old May 18, 2008 | 01:13 AM
etan's Avatar
i run 285 75 on a 3 inch toytec lift with stock wheels on my 98 4runner with hardly any rub issues. no rub on the a-arm or fenders. it just rubs frame at full lock. which wasn't even a big deal for me untill i proper rims and maybe additional lift.
Old May 18, 2008 | 08:15 AM
pfdaxe's Avatar
No rub on my 2000 with 285's and a 2.5" lift...
Old May 18, 2008 | 10:47 AM
4X4snowRunner's Avatar
Nice 4R....I have OME 3" lift and 285's to be install on my american racing wheels (16x8). You are not using wheel spacer right! I assume I dont need it.
Old May 19, 2008 | 12:28 AM
Jdizzydub's Avatar
I ran 285/75 on my stockies wrapped in Toyo Mt's with a 2.5 coil spacer/OME set-up and got no rub, too! But I did minor trim on the inner fender well, by the pinch weld and grinded down the UCA's a bit for piece of mind. Only rubbed at full crank. No wheel adapters/spacers needed with 4.5 bs wheels.
Old May 19, 2008 | 06:48 AM
pfdaxe's Avatar
Thanks! No spacer installed. Just the 16"x8" rims...
Old May 19, 2008 | 10:54 AM
Nice
Thank you for your replied. Now less to worry about. Yeah....I got these Toyo Open Country MT's report are great on road and off road. I'll post some pics if I figure how to post multiple pics.
suppra87
Jul 15, 2021 05:15 PM
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
